    Tgi3D SU Amorph and PhotoScan Update (v1.20)
    extensions
    34 Posts 13 Posters 28.8k Views 13 Watching
      The startup time for Sketchup is I'd guess at least doubled if not trebled when Tgi3D tools is auto-loaded... You can't disable its loading and manually load it later as you need it, because using load or require with the tgi3d.rbs file seems to give errors... πŸ˜•
      • B
        bjornkn
        @gulcanocali said:
        Hi Pixero,
        We are aware that many users now own multiple computers (at least one at home and one at work) and need to be able to use the same software on each without any additional cost. We are trying to figure out a remedy for this, we may move to a similar licensing scheme as described which will require some development time or maybe have a "2 for 1 sale" πŸ˜„.
        Of all the single-user schemes I think I like the Messiah verison best. It's like a USB dongle, but using a standard (one of your own) USB memory stick.
        Works great πŸ˜„
        • B
          bjornkn
          Sorry, but it isn't quite clear to me if Amorph is included when you buy PhotoScan?
          They both seems to be able to make good models from photos.
          I've been using Imagemodeler and Photomodeler for many years now, combined with SketchUp. Since Autodesk bought RealViz and removed Imagemodeler from open/single sales (need to buy Max or similar), and Photomodeler is not quite so good at modelling (and also quite pricey and with a very expensive licensing policy for us that don't live in USA/Canada - being forced to buy from local dealers with bloated prices), the availabilty of easy-to-use and affordable photogrammetry software is very limitied. That LockView tool looks very promising!
          It looks like PhotoScan (Amorph) will do the job fine?
          There's no calibrated cameras, but I hope that they take into account lens parameters/distortions?
          I'm downloading Amorph/Free and PhotoScan/Trial right now πŸ˜„
            Yes Amorph is included in tgi3D Photoscan. Photoscan is a standalone piece of software that exports to .skp. In fact when you choose export, SU will open with your Photoscan calibrated images loaded as scenes. It Photomatch on steroids πŸ‘
            • B
              bjornkn
              Thanks πŸ˜„
              Then I suppose that if you first buy Amorph and later want the full PhotoScan version then you could have those $150 deducted from the full price?
              I asked support the same question, but they probably don't work at weekends (like the rest of us do πŸ˜‰
              At the moment I cannot afford to spend $1000 on a tool that I currently don't really need, but Amorph I need/want right now..
                I can't answer the upgrade to Photoscan part. But if you haven't availed of the 30 day trial yet then you'll survive the weekend playing with both.
                But I do know the Tgi developers are hard at work with some user feedback suggestions been implemented. And the new UV addition looks pretty awesome.
                • B
                  bjornkn
                  I just downloaded both, but had planned to start with Amorph. A bit short of time currently..
                  I hope that the PhotoScan trial period doesn't start counting until after installing?
                  Looking forward to that too πŸ˜„
                  • G
                    gulcanocali
                    Hi bjornkn,
                    Sorry for the late reply. I do checkout SCF during the weekends and try to answer any questions as fast as I can but this weekend was a bit busy for me outside work.
                    @Rich, Thank you for answering with bjornkn's questions in the meantime.
                    Yes, Tgi3D SU PhotoScan includes ALL the capabilities of Tgi3D SU Amorph, and to answer your later question: If you want to buy PhotoScan after you have already purchased Tgi3D SU Amorph, the price of Tgi3D SU Amorph will be deducted from the purchase price of Tgi3D SU PhotoScan. However the price deduction process is not automated on our website. If and when they decide to upgrade their copies of Tgi3D SU Amorph to Tgi3D SU PhotoScan, we would appreciate our customers to contact our customer support so that their Amorph licenses can be invalidated and new PhotoScan licenses are issued to them together with the price deduction.
                    Tgi3D SU Photoscan "includes" a standalone executable "called the Tgi3D SU Calibration and Metrology Tool" which does exactly what Rich describes. The second part of Tgi3D SU PhotoScan is the plugin to Google SketchUp which includes ALL of what Amorph has PLUS the "automatic 3D surface fitting to photographs" feature. (BTW our team is working on some powerful improvements to this feature as well to improve the algorithm efficiency and quality of the match)
                    That is correct but I would like to make a clarification at this point to avoid any misunderstanding. Tgi3D SU Amorph does not include the Tgi3D Calibration and Metrology Tool. So if you can get good calibrated image sets from another software into SketchUp all the tools Tgi3D SU Amorph has, together with its "view locking" feature, enables you to create 3D models from photographs. One other feature missing from Tgi3D SU Amorph is the "automatic 3D surface fitting to photographs". This feature makes it a lot easier to create surface meshes that match the surfaces accurately especially for complex, organic shapes.
                    Yes, Tgi3D SU Calibration and Metrology tool DOES take into account lens distortions and parameters. There are no calibrated cameras but we do in situ calibration for each set. This avoids errors due to environmental changes and aging.
                    Gulcan Ocali
                    Product Manager
                    http://www.Tgi3D.com
                    • B
                      bjornkn
                      Thanks a lot for your in-depth reply πŸ˜„
                      This really looks like it is the "missing link" for me, after being abandoned by Realviz/Autodesk and MetaCreations/Canoma/Adobe.
                      I wonder why you're not using the work 'photogrammetry' on your product?
                      If you did I would have found it earlier, instead of bumping into it by accident, because that's what I've been searching for as a replacement for Imagemodeler.
                      Have you ever thought about running an upgrade campaign:
                      'Abandoned by Autodesk/Realviz? - upgrade to tgi3D PhotoScan for $??? now!' ?
                      • G
                        gulcanocali
                        @bjornkn
                        Thank you for your kind remaks and suggestions. πŸ˜„ You are quite right about the word "photogrammetry", we do use it at certain places but not quite the "right" places, I guess, to generate search results.
                        BTW, we have released new versions of our plugins that include some of the most requested updates, see the announcement in the following thread:
                        http://forums.sketchucation.com/viewtopic.php?f=323&t=36051
                        @pixero,
                        This new version loads much faster now, I hope you give Tgi3D another try πŸ˜„
                        Gulcan Ocali
                        Product Manager
                          The Safeguard texture feature is amazing... πŸ‘
                          [flash=800,600:2bbhzgnd]http://www.youtube.com/v/QE0li5Cal80[/flash:2bbhzgnd]
                            muddpuddle
                            Currently we do not have a way to edit the UV map. We do have plans for additional mapping methods, other than unwrap and spherical.
                            Very much looking forward to more mapping methods! 😍
                            • P
                              publied
                              hi all,
                              i'm very interested in this plugin. a direct and simply question: what percentage of representation accuracy do you can get from a series of photos? 100%, 95%, 80%? (please don't answers depends πŸ˜‰ )
                              ciao
                              /paolo
                              hire me@ http://www.publied.it !
                              • B
                                Bertier
                                how many poly does the plugin handle at the same time ?
                                if I want to polyreduce a 65K model do I have to split it into sub-objects ?
                                • G
                                  gulcanocali
                                  Hi Bertier,
                                  If you are going to do a significant reduction, it may be able to handle 65K but in general it would be a good idea to limit to around 25K-35K polygons. The bottleneck is really the number of polygons after reduction.
                                  Gulcan Ocali
                                  Product Manager
                                  • MikeG73M
                                    MikeG73
                                    Hello,
                                    Any updates on this software, as everything is like is 10+ years, new features. etc...
                                    Cheers!
                                    • B
                                      bjornkn
                                      @mikeg73 said:
                                      Hello,
                                      Cheers!
                                      According to their pages the last update was 2023-02-23. v.1.37. But afaik know it is mainly for allowing it to work with newer versions of SketchUp.
                                      I have been retired for some years now, and rarely use it nowadays. But I'm still a big fan of both SketcUp and tgi3D's Photoscan.
                                      When I occasionally use them I'm using the SU 2016 version, mainly because I have it set up with a lot of plugins.
                                      • 2 / 2
