    [Plugin] [CityGen] - Core [WIP] (0.1.3a) — 19 September 2009
    109 Posts 23 Posters 85.8k Views 23 Watching
    • F Offline
      Foun10Head-X
      Thanks, thomthom et. al. I managed to get it running smoothly.
      What I did was searching through Google and there was an Alpha installer of CityGen, but it froze my SU -- but (d'uh on my part 💚 ), I "forgot" to put the city_gen loader.rb in the plugin, the CityGen in the Citygen folder and the streetGen in the modules your stated... To make a long story short - it was a real bumpy ride, no pun intended.
      Thanks guys for all your help. I'll keep playing with this feature.
      • F Offline
        Foun10Head-X
        @jim said:
        The plug-in is not really ready for use, but I made a Windows installer for the current version. See the Downloads tab:
        Error 404 (Not Found)!!1
        (code.google.com)
        Note: both the plugin and the installer should be considered experimental. Let me know if it works.
        Yes, I did do that, and what I did I installed it, but it was the old version, and I had to uninstall it. And used thomthom's zip files.
        Thank you jim.
        • F Offline
          foleypro
          Awesome work folks...
          • utilerU Offline
            utiler
            Hi Guys, I've been trying to make time to spend playing with this plugin so I loaded it and intend to give it a whirl ovber the weekend...
            a few things:
            I loaded it OK but not really sure how you are assigning color to lines: is that by material or layer?
            Also, when I run the plugin the dialogue activates and goes blank. [see attached screen shot]
            Looking forward to giving it a run!!
            StreetGen-Issue.swf
            Just Curious...
            • F Offline
              Foun10Head-X
              @utiler said:
              not really sure how you are assigning color to lines: is that by material or layer?[see attached screen shot]
              Wondering the same thing too.
              • utilerU Offline
                utiler
                Here is a screenshot, thomthom. Any ideas?
                Many thanks,
                Just Curious...
                  What Windows, SketchUp and Internet Explorer versions do you have?
                  • utilerU Offline
                    utiler
                    Win 7, SU 8.0.4811 and Firefox 3.6.15....
                    Just Curious...
                      No - not what browser you use, what Internet Explorer version is installed? SketchUp use the Internet Explorer engine for the windows we can create with the Ruby API. The Internet Explorer engine is used by many application in similar way.
                      • utilerU Offline
                        utiler
                        Buggered if I know, Thomas!! 🤣 What should I have installed to make it work more to the point..... Then I'll go work out what I need to alter....
                        OK, back in the office now.... downloading IE 9 as i didn't have 8 loaded. maybe that was the problem... I'll see if it works now.
                        thanks Thom.
                        Just Curious...
                        • utilerU Offline
                          utiler
                          OK, IE 9 loaded and still the problem is apparent....
                          Just Curious...
                          • utilerU Offline
                            utiler
                            Thom, I have IE8 64bit loaded on my PC. Would this be conflicting with it?
                            Just Curious...
                              Sorry for the delay - I've been away in Dubai for a week.
                              So you got IE8 or IE9 ? 😕 ❓
                              • utilerU Offline
                                utiler
                                Thanks Thomas, I heard you were away...
                                I uninstalled IE9 9 because it said that a Flash plugin was not yet available.... So I'm left with IE 8 [64bit]
                                I tried it on my laptop [Windows XP, 32bit, IE 8] also and got this as a result of running Street Generator:
                                StreetGen-Issue_on_XP.swf
                                Just Curious...
                                  There's your problem. It's not installed correctly.
                                  CityGen and StreetGen is a very experimental project - it has some special extra installation requirements.
                                  See the installation notes of this thread in the first post.
                                  • utilerU Offline
                                    utiler
                                    Thanks Thomas!! Neat little tool.... 👍
                                    One thing: When you 'Define Types', the New / Edit / Delete functions do not seem to provide any options. [see attached]
                                    Questions:
                                    1. How does color get assigned to street types?
                                    2. The resulting road system creates an interpolating line which is hidden. Is there a way to be able to create the face as a whole so if you need to pushpull you only need to select on face...?
                                    An idea:
                                    1. Is there a way to include merging lanes such as acceleration and deceleration lanes? Maybe byway of color....? Break a line where the lane widens to two and color differently.....
                                    Anyhow, thanks for helping out getting it loaded. 🎉 I've been asked to collaborate on an Urban Renewal Proposal so I hope to give this a try for it!
                                    Cheers,
                                    StreetGen-Dialogue.swf
                                    Just Curious...
                                      grakeskull
                                      HI HOW ARE YOU, THIS PLUGON IS GREAT I JUST HAVE A QUESTION. IS THERE ANY WAY THAT I BE ABLE TO GENERATE BUILDING TOO? THANKS...
                                        @Andrew: Sorry - I've yet not been able to look into this. I've gotten a leak in my ceiling I'm currently trying to deal with (along side my full time job) 😞
                                        Chris and Jim was working on a building module - though I don't think anything is released.
                                        • utilerU Offline
                                          utiler
                                          No worries Thomas. Sounds like you need a Plugon....... 😉
                                          Just Curious...
                                            mpowell1234567890
                                            Hi, I tried installing this plugin like what the instruction said in the readme file
                                            Plugins\city_gen.rb <- Core CityGen file
                                            Plugins\Gity_Gen\street_gen.rb <- Core Street Generator module file - loaded by city_gen.rb
                                            Plugins\City_Gen\Street_Gen\ <- Street Generator's support folder
                                            But, I still get the File cannot load error "Even the file is in the correct folder".. Is there a way to fix it?
                                            @thomthom said:
                                            This plugin is a work in progress. It's made public because it is a collaboration project.
                                            This is in it's very early beginning, so lots of things will change, and lots of bugs are to be expected. Feel free to share your ideas or join in on this project. See this thread for the discussion of the overall project. This thread is an overview of the related modules and the development thread for the core files.
                                            CityGen - Core
                                            Core and Installation Check
                                            This is the main file that centralise information and load the other modules.
                                            Modules are located in Plugins\CityGen\modules\.
                                            Please remove any old CityGen installations prior to installing.
                                            Menu entry is located under the Tools menu. Should this be under Plugins you think?
                                            Modules
                                            • Street Generator
                                            For Module Developers
                                            You can add this code to your module to check if the core is installed and that the module is installed in the correct location.
                                            > ### CORE & INSTALLATION CHECK ### ------------------------------------------------------------------
                                            > # Core check
                                            > if not file_loaded?('city_gen.rb')
                                            > 	if Sketchup.find_support_file('city_gen.rb', 'Plugins') == nil
                                            > 		UI.messagebox('The CityGen\'s core files is missing. Install the required core files.')
                                            > 	else
                                            > 		UI.messagebox('The CityGen\'s core files is not loaded. Ensure you installed this plugin correctly.')
                                            > 	end
                                            > 	raise 'CityGen Core error.'
                                            > end
                                            > # Correct installation check
                                            > if Sketchup.find_support_file('City_Gen/' + File.basename(__FILE__), 'Plugins') == nil
                                            > 	UI.messagebox("This module (#{File.basename(__FILE__)}) has not been installed properly. It should be installed under Plugins\\City_Gen\\")
                                            > 	raise 'CityGen Module path error.'
                                            > end
                                            > module City_Gen
                                            > 	module Some_Module
                                            > 		# stuff
                                            > 	end
                                            > end
                                            > # CHANGELOG
                                            > # 0.1.0a - 31.05.2009 (Thom)
                                            > #		 * Initial build.
                                            > # 0.1.1a - 31.05.2009 (Thom)
                                            > #		 * Change in the module error checking routine.
                                            > # 0.1.2a - 31.05.2009 (Thom)
                                            > #		 * Added version constant.
                                            > # 0.1.3a - 31.05.2009 (Thom)
                                            > #		 * Updated to the new file structure for use with Tortoise.
                                            • 5 / 6
