    [Plugin] [CityGen] - Core [WIP] (0.1.3a) — 19 September 2009
    109 Posts 23 Posters 92.2k Views 23 Watching
    • utilerU
      utiler
      Win 7, SU 8.0.4811 and Firefox 3.6.15....
      Just Curious...
        No - not what browser you use, what Internet Explorer version is installed? SketchUp use the Internet Explorer engine for the windows we can create with the Ruby API. The Internet Explorer engine is used by many application in similar way.
        • utilerU
          utiler
          Buggered if I know, Thomas!! 🤣 What should I have installed to make it work more to the point..... Then I'll go work out what I need to alter....
          OK, back in the office now.... downloading IE 9 as i didn't have 8 loaded. maybe that was the problem... I'll see if it works now.
          thanks Thom.
          Just Curious...
          • utilerU
            utiler
            OK, IE 9 loaded and still the problem is apparent....
            Just Curious...
            • utilerU
              utiler
              Thom, I have IE8 64bit loaded on my PC. Would this be conflicting with it?
              Just Curious...
                Sorry for the delay - I've been away in Dubai for a week.
                So you got IE8 or IE9 ? 😕 ❓
                • utilerU
                  utiler
                  Thanks Thomas, I heard you were away...
                  I uninstalled IE9 9 because it said that a Flash plugin was not yet available.... So I'm left with IE 8 [64bit]
                  I tried it on my laptop [Windows XP, 32bit, IE 8] also and got this as a result of running Street Generator:
                  StreetGen-Issue_on_XP.swf
                  Just Curious...
                    There's your problem. It's not installed correctly.
                    CityGen and StreetGen is a very experimental project - it has some special extra installation requirements.
                    See the installation notes of this thread in the first post.
                    • utilerU
                      utiler
                      Thanks Thomas!! Neat little tool.... 👍
                      One thing: When you 'Define Types', the New / Edit / Delete functions do not seem to provide any options. [see attached]
                      Questions:
                      1. How does color get assigned to street types?
                      2. The resulting road system creates an interpolating line which is hidden. Is there a way to be able to create the face as a whole so if you need to pushpull you only need to select on face...?
                      An idea:
                      1. Is there a way to include merging lanes such as acceleration and deceleration lanes? Maybe byway of color....? Break a line where the lane widens to two and color differently.....
                      Anyhow, thanks for helping out getting it loaded. 🎉 I've been asked to collaborate on an Urban Renewal Proposal so I hope to give this a try for it!
                      Cheers,
                      StreetGen-Dialogue.swf
                      Just Curious...
                      • G
                        grakeskull
                        HI HOW ARE YOU, THIS PLUGON IS GREAT I JUST HAVE A QUESTION. IS THERE ANY WAY THAT I BE ABLE TO GENERATE BUILDING TOO? THANKS...
                          @Andrew: Sorry - I've yet not been able to look into this. I've gotten a leak in my ceiling I'm currently trying to deal with (along side my full time job) 😞
                          Chris and Jim was working on a building module - though I don't think anything is released.
                          • utilerU
                            utiler
                            No worries Thomas. Sounds like you need a Plugon....... 😉
                            Just Curious...
                              mpowell1234567890
                              Hi, I tried installing this plugin like what the instruction said in the readme file
                              Plugins\city_gen.rb <- Core CityGen file
                              Plugins\Gity_Gen\street_gen.rb <- Core Street Generator module file - loaded by city_gen.rb
                              Plugins\City_Gen\Street_Gen\ <- Street Generator's support folder
                              But, I still get the File cannot load error "Even the file is in the correct folder".. Is there a way to fix it?
                              @thomthom said:
                              This plugin is a work in progress. It's made public because it is a collaboration project.
                              This is in it's very early beginning, so lots of things will change, and lots of bugs are to be expected. Feel free to share your ideas or join in on this project. See this thread for the discussion of the overall project. This thread is an overview of the related modules and the development thread for the core files.
                              CityGen - Core
                              Core and Installation Check
                              This is the main file that centralise information and load the other modules.
                              Modules are located in Plugins\CityGen\modules\.
                              Please remove any old CityGen installations prior to installing.
                              Menu entry is located under the Tools menu. Should this be under Plugins you think?
                              Modules
                              • Street Generator
                              For Module Developers
                              You can add this code to your module to check if the core is installed and that the module is installed in the correct location.
                              > ### CORE & INSTALLATION CHECK ### ------------------------------------------------------------------
                              > # Core check
                              > if not file_loaded?('city_gen.rb')
                              > 	if Sketchup.find_support_file('city_gen.rb', 'Plugins') == nil
                              > 		UI.messagebox('The CityGen\'s core files is missing. Install the required core files.')
                              > 	else
                              > 		UI.messagebox('The CityGen\'s core files is not loaded. Ensure you installed this plugin correctly.')
                              > 	end
                              > 	raise 'CityGen Core error.'
                              > end
                              > # Correct installation check
                              > if Sketchup.find_support_file('City_Gen/' + File.basename(__FILE__), 'Plugins') == nil
                              > 	UI.messagebox("This module (#{File.basename(__FILE__)}) has not been installed properly. It should be installed under Plugins\\City_Gen\\")
                              > 	raise 'CityGen Module path error.'
                              > end
                              > module City_Gen
                              > 	module Some_Module
                              > 		# stuff
                              > 	end
                              > end
                              > # CHANGELOG
                              > # 0.1.0a - 31.05.2009 (Thom)
                              > #		 * Initial build.
                              > # 0.1.1a - 31.05.2009 (Thom)
                              > #		 * Change in the module error checking routine.
                              > # 0.1.2a - 31.05.2009 (Thom)
                              > #		 * Added version constant.
                              > # 0.1.3a - 31.05.2009 (Thom)
                              > #		 * Updated to the new file structure for use with Tortoise.
                                You're missing the full path. Observe: Plugins\CityGen*modules*\
                                  stuartmitch
                                  Guys,
                                  I hope someone can help.
                                  I have loaded City-Gen (correctly, I think!).
                                  When I attempt to use the plug-in (for example when I click on Tools > City Generator > Streets > Define Types, I get a pop-up box stating that*"This program cannot display the webpage"*.
                                  I am not sure the plug-in would be attempting to connect to the internet.
                                  Any advice, please, on how I might be able to fix this?
                                  Cheers....Scotty
                                    Under what OS? OSX? I see your profile says you use OSX and Windows.
                                    There might be an issue under OSX - due to an Safari update that happened after this plugin as made.
                                      stuartmitch
                                      Thomas,
                                      thanks for taking the time to respond.
                                      The problem I have exists when I am using Windows 7 OSX. I haven't tried it on Mac as yet.
                                      Not sure if this helps, but my file set-up is
                                      plugins > city_gen_loader.rb
                                      plugins > citygen > city_gen.rb
                                      plugins > citygen > modules > street_gen.rb
                                      plugins > citygen > modules > webdialog > ......
                                      Many thanks again for the help.
                                      Cheers....Scotty
                                        hmmm
                                        If you open the Ruby Console before you try to use the tool? do you get errors?
                                          stuartmitch
                                          Thomas,
                                          there don't appear to be any error messages in the Ruby Console related to Citygen. Sorry!!
                                          Cheers....Scotty
                                            hmmm... this is strange...
                                            • 5 / 6
