    [Plugin] [CityGen] - Core [WIP] (0.1.3a) — 19 September 2009
    109 Posts 23 Posters 87.7k Views 23 Watching
      The Core:
      citygen folder
      city_gen_loader.rb
      These goes into the plugins folder.
      Street Gen
      street_gen folder
      street_gen.rb
      These goes into plugins/citygen/modules/
      I don't know why any of these would be causing crashes. I've not experienced it myself.
        @jim said:
        The plug-in is not really ready for use, but I made a Windows installer for the current version.
        That's interesting. What did you use to create that?
          Jim
          Inno
          Site not found · DreamHost
          The owner of this domain has not yet uploaded their website.
          (www.jrsoftware.org)
          • F
            Foun10Head-X
            Thanks, thomthom et. al. I managed to get it running smoothly.
            What I did was searching through Google and there was an Alpha installer of CityGen, but it froze my SU -- but (d'uh on my part 💚 ), I "forgot" to put the city_gen loader.rb in the plugin, the CityGen in the Citygen folder and the streetGen in the modules your stated... To make a long story short - it was a real bumpy ride, no pun intended.
            Thanks guys for all your help. I'll keep playing with this feature.
            • F
              Foun10Head-X
              @jim said:
              The plug-in is not really ready for use, but I made a Windows installer for the current version. See the Downloads tab:
              Error 404 (Not Found)!!1
              (code.google.com)
              Note: both the plugin and the installer should be considered experimental. Let me know if it works.
              Yes, I did do that, and what I did I installed it, but it was the old version, and I had to uninstall it. And used thomthom's zip files.
              Thank you jim.
              • F
                foleypro
                Awesome work folks...
                • utilerU
                  utiler
                  Hi Guys, I've been trying to make time to spend playing with this plugin so I loaded it and intend to give it a whirl ovber the weekend...
                  a few things:
                  I loaded it OK but not really sure how you are assigning color to lines: is that by material or layer?
                  Also, when I run the plugin the dialogue activates and goes blank. [see attached screen shot]
                  Looking forward to giving it a run!!
                  StreetGen-Issue.swf
                  Just Curious...
                  • F
                    Foun10Head-X
                    @utiler said:
                    not really sure how you are assigning color to lines: is that by material or layer?[see attached screen shot]
                    Wondering the same thing too.
                    • utilerU
                      utiler
                      Here is a screenshot, thomthom. Any ideas?
                      Many thanks,
                      Just Curious...
                        What Windows, SketchUp and Internet Explorer versions do you have?
                        • utilerU
                          utiler
                          Win 7, SU 8.0.4811 and Firefox 3.6.15....
                          Just Curious...
                            No - not what browser you use, what Internet Explorer version is installed? SketchUp use the Internet Explorer engine for the windows we can create with the Ruby API. The Internet Explorer engine is used by many application in similar way.
                            • utilerU
                              utiler
                              Buggered if I know, Thomas!! 🤣 What should I have installed to make it work more to the point..... Then I'll go work out what I need to alter....
                              OK, back in the office now.... downloading IE 9 as i didn't have 8 loaded. maybe that was the problem... I'll see if it works now.
                              thanks Thom.
                              Just Curious...
                              • utilerU
                                utiler
                                OK, IE 9 loaded and still the problem is apparent....
                                Just Curious...
                                • utilerU
                                  utiler
                                  Thom, I have IE8 64bit loaded on my PC. Would this be conflicting with it?
                                  Just Curious...
                                    Sorry for the delay - I've been away in Dubai for a week.
                                    So you got IE8 or IE9 ? 😕 ❓
                                    • utilerU
                                      utiler
                                      Thanks Thomas, I heard you were away...
                                      I uninstalled IE9 9 because it said that a Flash plugin was not yet available.... So I'm left with IE 8 [64bit]
                                      I tried it on my laptop [Windows XP, 32bit, IE 8] also and got this as a result of running Street Generator:
                                      StreetGen-Issue_on_XP.swf
                                      Just Curious...
                                        There's your problem. It's not installed correctly.
                                        CityGen and StreetGen is a very experimental project - it has some special extra installation requirements.
                                        See the installation notes of this thread in the first post.
                                        • utilerU
                                          utiler
                                          Thanks Thomas!! Neat little tool.... 👍
                                          One thing: When you 'Define Types', the New / Edit / Delete functions do not seem to provide any options. [see attached]
                                          Questions:
                                          1. How does color get assigned to street types?
                                          2. The resulting road system creates an interpolating line which is hidden. Is there a way to be able to create the face as a whole so if you need to pushpull you only need to select on face...?
                                          An idea:
                                          1. Is there a way to include merging lanes such as acceleration and deceleration lanes? Maybe byway of color....? Break a line where the lane widens to two and color differently.....
                                          Anyhow, thanks for helping out getting it loaded. 🎉 I've been asked to collaborate on an Urban Renewal Proposal so I hope to give this a try for it!
                                          Cheers,
                                          StreetGen-Dialogue.swf
                                          Just Curious...
                                          • G
                                            grakeskull
                                            HI HOW ARE YOU, THIS PLUGON IS GREAT I JUST HAVE A QUESTION. IS THERE ANY WAY THAT I BE ABLE TO GENERATE BUILDING TOO? THANKS...
                                            • 5 / 6
