    [Plugin] [CityGen] - Core [WIP] (0.1.3a) — 19 September 2009
    109 Posts 23 Posters 92.2k Views 23 Watching
      Does it possible with your plug to generate "streets" with no round Corners?
      Set Angle Threshold to 180 degrees (or more).
      PS Are you interested by a little French translation of your Plug's UI?
      In the future, yes. But as it is now - this plugin is experimental and many things will change. (When I get around to work on it again.)
        here 0.01 as corner radius (Why not 0 possible)
        90° as Angle threshold
          Not possible to average for have an angle more straight?
          Because after there are some glitch when you make some functions with it
          vitraux_pour_Serge.skp
            As it is now - it does no error checking at all. But you're right - it's something that'd be nice if it did.
              In your last versions measures are not keeping from previous calculate in the dialog box 😉
              • F
                Foun10Head-X
                I'm still stumped as to where to put the plug-ins on CityGen and StreetGen. To keep my SU7 from crashing, I had to make a City_Gen folder and nothing comes up. I don't know what I'm doing wrong.
                Footnote: When I put the city_gen.rb file in Plug-ins, after clicking in to SU7, I get a crash leading to a bug repot. If only I can find out what the problem is.
                  Jim
                  The plug-in is not really ready for use, but I made a Windows installer for the current version. See the Downloads tab:
                  Error 404 (Not Found)!!1
                  (code.google.com)
                  Note: both the plugin and the installer should be considered experimental. Let me know if it works.
                    The Core:
                    citygen folder
                    city_gen_loader.rb
                    These goes into the plugins folder.
                    Street Gen
                    street_gen folder
                    street_gen.rb
                    These goes into plugins/citygen/modules/
                    I don't know why any of these would be causing crashes. I've not experienced it myself.
                      That's interesting. What did you use to create that?
                        Jim
                        Inno
                        Site not found · DreamHost
                        The owner of this domain has not yet uploaded their website.
                        (www.jrsoftware.org)
                        • F
                          Foun10Head-X
                          Thanks, thomthom et. al. I managed to get it running smoothly.
                          What I did was searching through Google and there was an Alpha installer of CityGen, but it froze my SU -- but (d'uh on my part 💚 ), I "forgot" to put the city_gen loader.rb in the plugin, the CityGen in the Citygen folder and the streetGen in the modules your stated... To make a long story short - it was a real bumpy ride, no pun intended.
                          Thanks guys for all your help. I'll keep playing with this feature.
                          • F
                            Foun10Head-X
                            (code.google.com)
                            Yes, I did do that, and what I did I installed it, but it was the old version, and I had to uninstall it. And used thomthom's zip files.
                            Thank you jim.
                            • F
                              foleypro
                              Awesome work folks...
                              • utilerU
                                utiler
                                Hi Guys, I've been trying to make time to spend playing with this plugin so I loaded it and intend to give it a whirl ovber the weekend...
                                a few things:
                                I loaded it OK but not really sure how you are assigning color to lines: is that by material or layer?
                                Also, when I run the plugin the dialogue activates and goes blank. [see attached screen shot]
                                Looking forward to giving it a run!!
                                StreetGen-Issue.swf
                                Just Curious...
                                • F
                                  Foun10Head-X
                                  @utiler said:
                                  not really sure how you are assigning color to lines: is that by material or layer?[see attached screen shot]
                                  Wondering the same thing too.
                                  • utilerU
                                    utiler
                                    Here is a screenshot, thomthom. Any ideas?
                                    Many thanks,
                                    Just Curious...
                                      What Windows, SketchUp and Internet Explorer versions do you have?
                                      • utilerU
                                        utiler
                                        Win 7, SU 8.0.4811 and Firefox 3.6.15....
                                        Just Curious...
                                          No - not what browser you use, what Internet Explorer version is installed? SketchUp use the Internet Explorer engine for the windows we can create with the Ruby API. The Internet Explorer engine is used by many application in similar way.
                                          • utilerU
                                            utiler
                                            Buggered if I know, Thomas!! 🤣 What should I have installed to make it work more to the point..... Then I'll go work out what I need to alter....
                                            OK, back in the office now.... downloading IE 9 as i didn't have 8 loaded. maybe that was the problem... I'll see if it works now.
                                            thanks Thom.
                                            Just Curious...
                                            • 4 / 6
