    [Plugin] Export Vertices to CSV
    51 Posts 17 Posters 45.2k Views 17 Watching
      @tig said:
      BUT perhaps to turn it around... please explain clearly why TIG.exportvertices2csv would be S_O__M_U_C_H better than exportvertices2csv ?
      What terrible problems await those who do it my way ??
      Method in the global space - and extending methods which is pretty much the same as adding a method in global space - has a chance of clashing.
      We have examples of the method box being defined by two plugins in global space. And we have the Array.offset method defined by multiple plugins which has caused issues.
      Keeping everything in a namespace is safer - as picking a namespace to id you and keep all your code in there allows you much greater control and security over name-clashes.
      Take the Image class for instance, there are several snippets here on this forum that adds .definition and .instance to the Image class. I think some plugins do so. Now, the .transformation addition in all versions is flawed as you know.
      I've been trying to get Google to add .definition and .transformation to the Image class - but here is the issue. None of these snippets that extend the Image class checks if the method already exists.
      So if Google implements correct .transformation class it'll be overwritten by bugged versions.
      It's due to these kind of issues that I stopped working on the SKX project as I saw the potential for causing more clashes. Instead I now use my own library where I don't extend any base classes. It doesn't make my code look as neat as if the base classes had been extended, but it's safe. 100%.
        Update here http://forums.sketchucation.com/viewtopic.php?p=298614#p298614
        I have wrapped the code in a class to use you now type Exportvertices2csv.new in the Ruby Console or in your own menu item...
        • robertWanR
          robertWan
          Hi.
          Could you modify 😳 the plugin so that it saves vertices of all (or some) components?
          With no need of using Explode.
          The name of a component and coordinates of the vertices in SCV file are needed.
          It would be perfect if only components with, for example: "plywoodxxx", "drillxxx", in names were saved.
            It will already save the vertices in any selection - so if you edit a group or component it will save the vertices of things selected in that context.
            YOU could simply recast the code so that rather than process selected entities' vertices it goes through the entities in any selected group [or instance-definition] and returns their entities' vertices to a CSV [perhaps transformed by the group/instance's transformation] and named after the group/definition rather than the model... why not try to write it yourself ? 😕
            • robertWanR
              robertWan
              I'll have few hundred components and sub-components.
              That is why it can't be hand made.
              And I'm not able to write it myself, because I'd have to learn Ruby.
              From those coordinates I'm going to make in Exel a file to drilling machine.
              Something like a plugin CutList but with coordinates of the holes on a sheet.
              Robert
                Robert
                Just so I don't go down a blind alley here...
                What I think you'd like is that you make a 'selection of things'.
                If that selection includes raw geometry you get a 'modelname_verts.csv' file with all of those vertices in [as now].
                If its a selection within another context - e.g. a component edit, then the file's name is 'defnname_verts.csv'.
                Next, if any items selected are groups or component-instances then we 'mine down' into those and get the raw geometry's vertices in those.
                These sets of vertices' locations go into separate files as 'groupname_verts.csv' or 'defnname_verts.csv' as appropriate - the vertices' positions XYZ will be 'transformed' from their actual locations inside their context to the model coordinate system, so that all 'points' are then in the correct relationship if 'overlaid'.
                Do you need to process groups/compos inside groups/compos etc ? if you do then those transformations might get painfully convoluted but doable...
                This is all quite doable, I just want to ensure I don't do it twice... 🤓
                You speak of 'drilling' no centers will be made this way.
                You could perhaps have another tool that adds cpoints at the center-points of all arcs/circles and exports a separate CSV list of those these ❓
                • charly2008C
                  charly2008
                  Hi TIG,
                  maybe a stupid question of the practical purpose for this plugin. I have no idea at the moment. Maybe you can even give an example please.
                  Charly
                    @charly2008 said:
                    Hi TIG,
                    Charly
                    One example - if you have a mesh you can export all of its vertices as a CSV and import them into another app as a triangulated mesh.
                    Another - you can export the CSV list of points into an app that uses them to cut, drill etc...
                    • charly2008C
                      charly2008
                      HI TIG,
                      thanks for your quick response. Now I understand it.
                      Charly
                      • robertWanR
                        robertWan
                        I'm sending .skp file and an example of SCV file.
                        Drill mark has 3 vertices.
                        Vertices---line---vertices---line---vertices.
                        Hinge cylinder and plate aren't needed (many vertices) in SCV file. That is why i would like to be able to choose components. Filter? Precision of vertices' position 0.000. Now they are only integre.
                        Robert
                        exaple CSV
                        example cabinet
                          Hinge cylinder and plate aren't needed (many vertices) in SCV file. That is why i would like to be able to choose components. Filter? Precision of vertices' position 0.000. Now they are only integer.
                          Robert
                          Correct me if I misunderstand you...
                          First what looks like each 'drill mark' in your SKP seems to made from two lines - so they can then have 3 vertices ?
                          Does your drilling machine then know the 'vector' of the drilling from some of those and then the start or end of a pair is the point it drills at whilst the second line's vertex gives the depth to drill - how are 'we' to 'know' which vertex is which when it's written into the CSV file ?
                          Are they vertices always 'drawn' in the same order ?
                          It might be a lot easier if you have a few standard drill-points to simply use a component instance that has some attributes that we read - when you add the drill-point at a point [used for the drilling] you set a diameter and depth - later when the CSV is compiled we can get the drill-points location and direction from its own transformation in 3D and then read the attributes to get its diameter and depth... The nesting of the drill-point then has to be applied to the location/direction to set it into the model's coordinates - unless of course you really want these applying to a particular panel's transformation - I assume the drilling machine is fixed and the panels passed beneath it - so it's little use knowing if the hole's direction is 'left' when actually it's 'down' on the jig ? 😕
                          To choose particular 'types' of component would be possible but how would you do this ? A list would quickly become unwieldy. In your example - shown above - we have:
                          Three 'Hinge 35' instances in the model and each
                          'Hinge 35' contains
                          'Hinge' which contains
                          'two drill mark 2mm' which itself contains two instances of
                          'Drill Mark 2mm'
                          AND
                          'two drill mark 5mm' which itself contains two instances of
                          'Drill Mark 5mm'
                          So you only wants this starting with 'Drill Mark' AND the side/door reporting in the CSV ?
                          Or put another way anything starting with 'Hinge' is ignored in the CSV report, BUT things within 'Hinges' are reported if they are 'Drill Marks'....
                          This nesting of drill marks within the Hinge components makes getting the transformations of each drill-point awkward but not impossible... We have to get the transformation of each instance of the Hinge 35, and the transformation of each Hinge within that instance's definition and the transformation of the 'two drill mark...' instances within that instance's definition and finally the transformation of each 'Drill Mark...' instance within each of those instances 😒
                          I have to think about how to iterate all of this...
                          Can you write a simple step sheet on how you would hope to use this... For example
                          I open the SKP
                          I select the assembled cabinet
                          I run the reporter
                          I specify what parts are to be reported [or perhaps ignored?]
                          A CSV file is written... etc
                          The tolerance of the reported CSV numbers should be the same as you have set in your Model Info > Units, so if you work in mm and only report dims etc to the nearest mm then that's what the CSV has in it too. It could be possible to remember you current setting then temporarily rewrite them to say 3 d.p. [1.234] while the CSV is made and reset back again afterwards... using Sketchup.active_model.options["UnitsOptions"]["LengthPrecision"]
                          I notice your example SKP has 0.00mm set. So you should get 1.23 in the CSV if the length actually is 1mm it should still format to 1.00 ? If it isn't doing that it can certainly be made to. Read the CSV in Notepad to check - if you open it in Excel it will usually not display trailing zeros or unneeded decimal-points in its cells?
                          • robertWanR
                            robertWan
                            Only because that one vertice's components can't be created. At least 3 vertices and 2 lines.
                            Drill mark
                            It will be like that. Only a vertice in the middle will be used. If there are less thank 3 vertices a component can't be created.
                            Yes. Only those which have in the beginning of a name some phrase. For instance Drill, Door, etc.
                            Or every that beginns with some character, e.g. "*".
                            So as in the file there are no unnecessary components, like lamp, floor, ceiling, dishwasher etc.
                            I open the SKP
                            I run the reporter
                            After thinking it over
                            Open SKP
                            run the plugin
                            only parts beginning with, for example "*" will be reported.
                            a CSV file is written
                            In SU 500,6 but in CSV 500,0 😞
                            box  500,6 x 500,6 x 100,6
                            Thank you for your help and involvement.
                            Robert
                              ACP
                              Dear Sir:
                              How do I make Exportvertices2csv.new work on Sketchup Pro 8....?
                              Is it not supposed to work on version *, or what is the problem with the script.
                              I am new using Rubi Scripts, but it seems like there is something wrong with the script. here is the message I get on the Rubi Console:
                              exportvertices2csv
                              Error: #<NameError: undefined local variable or method `exportvertices2csv' for main:Object>
                              (eval)
                              I very much appreciate an answer either here on this forum or by email at:
                              antonio @ synergyamericas.com
                              Thank you very much!
                              Antonio
                                @ACP
                                The way to make it run is - in a saved SKP, select faces/edges etc that you want to export the vertices from, then in the Ruby Console bottom line type [OR copy/paste]:
                                then press <enter>
                                It must be written exactly as written above.
                                It must start with a capital 'E' and end with '.new'
                                Your example shows you are using a 'lowercase' version, with no terminating '.new' - so only a miracle would make it work in any version of Sketchup !
                                • P
                                  pichuneke
                                  Tig, sorry to say that, but I have the same problem as the rest of some people here.
                                  I am trying to export the points to import them with a software of topography, and I have this csv (sample):
                                  142.0 120.0 -0.0
                                  142.0 122.0 -0.0
                                  143.0 120.0 -0.0
                                  140.0 120.0 -1.0
                                  140.0 122.0 -0.0
                                  141.0 122.0 -0.0
                                  138.0 120.0 -2.0
                                  137.0 121.0 -2.0
                                  137.0 122.0 -2.0
                                  As you see, no decimals at all. I have chosen meters, "decimal" and precision 0,000 . No 0,000m extension.
                                  I don't know what to do. I've read this thread and other similar to this: ExportCpointstoCSV (http://sketchucation.com/forums/viewtopic.php?f=323&t=40061). I don't like to ask for help and importunate you, but... can you help me?
                                  Forgive my spanglish...
                                    What format does your Topo software need.
                                    The format:
                                    137.0 122.0 -2.0
                                    Looks to have the standard '.' as the decimal-point NOT ',' as you might use in Spain... and is separated by a space OR a TAB ? Using a ',' wouldn't work with that in the numbers too !
                                    Also what units are expected etc?
                                    The numbers after the decimal point truncate to .0 if there are no more ?
                                    There are various ways of exporting things like this around the forums.
                                    For example, do you really want to export 'vertices' ?
                                    • P
                                      pichuneke
                                      The format:
                                      137.0 122.0 -2.0
                                      It's separated by a ","; and the '.' is the decimal separator. Anyway the software used to read it it's not a problem. I mean, I have copied the text numbers from a text editor. Anyway, if you want, you have here from notepad:
                                      142.0,120.0,-0.0
                                      142.0,122.0,-0.0
                                      143.0,120.0,-0.0
                                      140.0,120.0,-1.0
                                      140.0,122.0,-0.0
                                      So the text editor is not a problem. Sketchup generated that file as you read it.
                                      I would like something like 142.24, 129.89, -0.025 (at least 2 decimals, or cm). It's for a topographical map I made by photogrametry. I am experimenting, to be honest, trying to find if this way of making maps is useful for my work.
                                      I have to leave to go to lunch in 20 minutes, see you this evening. (The spanish lunch, a lot of food. But no siesta.) 😄
                                        If I load the original .rb from the first post of this thread and then type Exportvertices2csv.new etc; then with the Model Info > Units set as 'meters', with 0.000 and no 'm' suffix etc, it works fine on the selected geometry's vertices.
                                        Vertices with exact 'm' values report as whole numbers
                                        1,2,3
                                        but when with 'mm' parts they appear as
                                        1.234,5.67,8.9
                                        etc...
                                        So I don't see how you are getting these results 😕
                                        With the same Model Units setting as above, as a test preselect a simple face [but one that is NOT 'flat' in 3d] and copy/paste this code-snippet into the Ruby Console + <enter> and report the output.
                                        Sketchup.active_model.selection[0].vertices.each{|v|puts v.position.x.to_s.gsub(/^~ /,'').to_f.to_s+','+v.position.y.to_s.gsub(/^~ /,'').to_f.to_s+','+v.position.z.to_s.gsub(/^~ /,'').to_f.to_s}
                                        Are the values as you might measure 'on screen' ???
                                        • P
                                          pichuneke
                                          Before doing what you told me (copy and paste your code), and after reading you, I selected mm instead of m.
                                          These were the results for the first 5 lines:
                                          142416.0 120527.0 -532.0
                                          142416.0 122200.0 -13.0
                                          143444.0 120527.0 -13.0
                                          140002.0 120527.0 -1720.0
                                          140002.0 122941.0 -965.0
                                          After that, I selected again "m" (meters), and these were the results:
                                          142.0 120.0 -0.0
                                          142.0 122.0 -0.0
                                          143.0 120.0 -0.0
                                          140.0 120.0 -1.0
                                          140.0 122.0 -0.0
                                          A workaround would be to obtain the results in millimetres, and divide them by 1000, so I can obtain 142.416 and so on.
                                          Now I am going to do what you told me.
                                          With "meters" as the selected unit, I choose a face (a triangle):
                                          Sketchup.active_model.selection[0].vertices.each{|v|puts v.position.x.to_s.gsub(/^~ /,'').to_f.to_s+','p+v.position.y.to_s.gsub(/^~ /,'').to_f.to_s+','+v.position.z.to_s.gsub(/^~ /,'').to_f.to_s}
                                          Error: #<SyntaxError: (eval):155: compile error
                                          (eval):155: syntax error, unexpected tIDENTIFIER, expecting '}'
                                          ....gsub(/^~ /,'').to_f.to_s+','p+v.position.y.to_s.gsub(/^~ /,...
                                          (eval):155
                                          With "millimetres" as the selected unit:
                                          (eval):155
                                          Hope it helps.
                                            Out of curiosity, to what is 'Precision' set when you are using metres as the units?
                                            • 1 / 3
