    [Plugin] (TIG) Rotate Plan View v1.1 20110316
    54 Posts 17 Posters 51.5k Views 17 Watching
      Clearly the code isn't loading properly for some reason I can't ascertain at a distance...
      Here's a ready-made rb file that should work... please remove your attempt...
      Here' v1.1
      (c) TIG 2011
      Permission to use, copy, modify, and distribute this software for
      any purpose and without fee is hereby granted, provided the above
      copyright notice appear in all copies.
      THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
      IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
      WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      File:
      Put the file Rotateplanview.rb in the Plugins folder.***
      Usage:
      To use set up your Plan [Top] view, without Perspective and
      in the Ruby Console type Rotateplanview.new to rotate the camera 45 degrees
      clockwise, repeat to rotate it another 45 degrees etc.
      The extents are zoomed after each rotation.
      To do other angles provide an angle value in degrees -
      e.g. Rotateplanview.new 10 rotates the view 10 degrees clockwise or
      Rotateplanview.new -30 rotates the view 30 degrees counterclockwise.
      When you are happy with it save the view to a new Scene tab so you can
      return to it later.
      Note: v1.1 includes a View Menu > 'Rotate Plan View' item and there is
      also a 'Rotate Plan View' toolbar that can be activated from the
      View > Toolbar menu, ***this needs the icon Rotateplanview.png in the
      ../Plugins/TIGtools subfolder.
      If you use one of these tools this way you will get a dialog asking for
      the angle, the default is +45 degrees. otherwise it works as above...
      Donations: by PayPal to info @ revitrev.org PayPalButtonVersion:
      1.0 20110304 First issue.
      1.1 20110316 Menu/Dialog/Toolbar item added.
      Download/install this Plugin's latest RBZ from the PluginStore...http://sketchucation.com/pluginstore?pln=Rotateplanview
      • L
        leminilab
        Here's a ready-made rb file that should work... please remove your attempt...[attachment=0:seezsr87]<!-- ia0 -->Rotateplanview.rb<!-- ia0 -->[/attachment:seezsr87]
           :heart_eyes:  :sunglasses:  :tada:  :sunny:  :smile:  :laughing:
        This is soooooooooooooooooooooooooooooooooooooooooooo great!
        For your info and for the sake of my own public humiliation, I had pasted the rb file in my SKetchup 8 plugins folder... And was usin SU7! 😳 😳 😳 😳
        Thank you so much! πŸ‘
        • "Live every day as if it were your last and then some day you'll be right."
        • "ThomThom rules!!!"
        • GaieusG
          • L
            leminilab
            TIG, this is really a must for me! Thank you so much! This should be a default option in Sketchup.
            And it really saved my life on this :
            BTW it's also a nice new animation tool for Sketchup! To be continued...
            and a not-so-well rendered view
            Oh and by the way Gaieus, I had read one of your post on a google forum (http://www.google.com/support/forum/p/sketchup/thread?tid=6300098d9b1e63b7&hl=en) before posting my question but for some reason I couldn't make my head to apply your suggestions to my situation...
            I just didn't understand if this post relates to my problem or not... (I know it's scary... I scare myself very often πŸ˜•)
            Again, I wish my the world would be as effective and generous as this community... πŸ˜’
            Thanks everyone!
            Nicolas
            • C
              cobb89
              how can i use this rotate plan view plugin??
                Copy/paste it into a file named Rotateplanview.rb in the Plugins folder.
                To use set up your Plan [Top] view, without Perspective and in the Ruby Console type Rotateplanview.new to rotate the camera 45 degrees clockwise, repeat to rotate it another 45 degrees etc. The extents are zoomed after each rotation.
                To do other angles provide an angle value in degrees - e.g. Rotateplanview.new 10 rotates the view 10 degrees clockwise or Rotateplanview.new -30 rotates the view 30 degrees counterclockwise.
                When you are happy with it save the view to a new Scene tab so you can return to it later.
                  Thank you, TIG. This offers some interesting options for scene creation.
                    No problem Dave, glad I could help... 😎
                    • C
                      cobb89
                      can anyone create a toolbar button for this plugin??
                        As well as a toolbar you'd need a dialog for the angle ?
                          Seems to me entering the text into the console works very nicely. And I don't have to find room for another toolbar.
                          Oh, and Rich, I very happy to have your assistance while your wife is ironing. πŸ˜‰
                            Prioritize Dave...Prioritize πŸ˜‰
                            • C
                              cobb89
                              yeah....whatever is possible.... πŸ˜’
                                Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=313264#p313264
                                It includes View menu item and toolbar with dialog entry of angles - the Ruby Console version works as before for those of you not wishing clutter... The toolbar only gets made if there's a png file so that's a simple way to stop that being created if you don't want it!
                                  Michaelv
                                  TIG, can I use it to include into a tool I'm working on. It's an easy simple rotate tool, and I'd like to include this as planview rotation when hovering over the origin.
                                    No problem, just give some acknowledgment in the header πŸ˜„
                                    • C
                                      cobb89
                                      Thanks a lot!! πŸ˜„
                                      • Bob JamesB
                                        Bob James
                                        It seems that whenever I go to parallel projection and top view the scene is never at the angle I want it, so this plugin is really handy.
                                        Okay, so I'm lazy, but it would be very nice to speed up workflow if the plugin did the preliminary steps automatically: set camera to parallel projection and set to top view 😎
                                        • EarthMoverE
                                          EarthMover
                                          Great idea and very useful. Thanks TIG!! πŸ‘
                                          Content Creator at Skapeup
                                            dan19936
                                            Also available is the free Camera Controls by Smustard
                                            http://www.smustard.com/script/CameraControls
                                            Dan
                                            • 1 / 3
