    Windowizer
    7 Posts 5 Posters 1.3k Views 5 Watching
    • Didier BurD Offline
      Didier Bur
      Sorry for the newbie question 😳 , but after windowizing a face, I'm getting no frame extrusion (no back face and side faces of frame. Is this normal ?
      DB
      • massimoM Offline
        massimo Moderator
        Hi Didier. No, you should end with something like this. (Windowizer 4, starting with just a single face)
          Yes with the basic one
          Take a wall first, draw a face on this volume
          Drill the wall with this face
          Redraw a face over the hole
          select this face
          apply the plug
          • EdsonE Offline
            Edson
            I think this used to happen with the versions prior to windowizer 4. I never get this when I use the plugin.
            http://www.mahfuz.arq.br
              pitrak
              That's the default behaviour of the free Windowizer indeed.
              4 looks amazing, I especially like that you can input proportions for the different panes. Albeit unfortunately only in the horizontal division if I understand correctly.
              It does cost 10 bucks though. I think I'll order it, seems well worth the cost.
                Didier Bur
                Thanks for all the advice. So v4 is the answer. β˜€
                @Pilou: your process doesn't work, at least with v3.05b...
                DB
                • EdsonE Offline
                  Edson
                  you can also input proportions for the vertical divisions.
