    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    Corinthian order
    55 Posts 17 Posters 14.0k Views 17 Watching
    • michaliszissiouM Offline
      michaliszissiou
      You should lower the indirect lighting. The Ao as well. Normal maps working perfectly.
      • N Offline
        notareal
        Perhaps I need to give this another try.
        • N Offline
          notareal
          How about this? Used unbiased engine of Thea this time. Relight to balance indirect light from HDR sky and dropped AO (except what been baked in textures). Render time 10 minutes.
            michaliszissiou
            A more completed scene, blender internal render. 1 min at 2000 px.
            Aphrodite sculpted in blender-3dcoat-zbrush. Here at 40k faces + displacement and normal maps.
            http://www.mediafire.com/imgbnc.php/8799a52e70dc15e2c15779c27e68f4690c848f2bbac6577d00c429ec970ae58d6g.jpg
              KarinaGM
              Where is the clap clap clap?
              ๐Ÿ˜ excelent (as always)
              **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminarรก perdiendo ambas"
              -Benjamรญn Franklin.**
              • david57D Offline
                david57
                You got a good render there. ๐Ÿ‘
                Oh, I didnt know it was posted in October, I though
                it was rendered today, i guess i wasn't around then.
                  michaliszissiou
                  Thanks david57, the last ones are new renders, using latest builds from graphicall.
                  Another view here, now having baked all shadows-AO, render times at ~10 sec. Ready for a nice camera traveling.
                  http://www.mediafire.com/imgbnc.php/71ee49d335907d588f3c4aebfe548c1dfa69cf24444f1fb85f181b7bc4c33e256g.jpg
                    michaliszissiou
                    Thanks KarinaGM, the clap clap is in the 3dcoat forum ๐Ÿ˜†
                    Well, I used SU for very basic structure + to export the capital and retopo-resculpt it.
                    Tools like artisan couldn't help at all. Blender, 3dcoat and zbrush are of the best tools around anyway. (for digital sculpting)
                    • numbthumbN Offline
                      numbthumb
                      Where those photos were taken? ๐Ÿ˜„
                      Comfortably numb...
                      • david57D Offline
                        david57
                        You've done excellent. Renders like dont get any better then that.
                        I'm guessing your using an HDRI to light your models.
                          michaliszissiou
                          No HDRI, I'm using a generated sky and this same for AO, environment lighting.
                          All these HDRI lighting is a myth actually. Same myth for reflections via HDRI. All these are just maps projected via normal to camera or to lighting direction. The "matcaps" of zbrush work exactly the same. A spherize distortion (Ps) projection through camera. This is all. Not a big deal but it works.
                          Thanks modelhead, 3dc, right. A great app. Zbrush is a perfect app, 3dc is a unique one. My favorite apps.
                          • david57D Offline
                            david57
                            Michaliszissiou,
                            I tried that with blender but i used an hdri.
                            It looks like a toy. ๐Ÿ˜„
                            Render time was 4 minutes 48 seconds on an old single core
                            laptop.
                            Columns are from the Google Warehouse.
                              michaliszissiou
                              Nice, a tip: when using HDRI for lighting ask blender to export a RGBA (png), then use a background decent photo in Ps. Or just do similar in compositor via nodes.
                              But see how more poly I rendered in less than a minute. And the best trick is that I can bake all these AO shadows lights in UV maps (these already exist) and have similar render quality in real time. Best for animation. I'm already traveling around in blender game engine.
                              • david57D Offline
                                david57
                                Thanks, Michalis,
                                for settings and the help. I'm also
                                trying out the examples from the net.
                                I think I'm getting it.
                                • orgelfO Offline
                                  orgelf
                                  excellent work Michaliszissiou !!
                                  "as always" as a lot of people said before ๐Ÿ˜‰
                                  http://www.orgelf.com
                                    michaliszissiou
                                    Thank you orgelf
                                    Testing a new blender build here, using just one subdivision for displacement but using the same displacement map as bumps. Similar to new modo501 solution for fast renders. Not so crisp but really fast render (10 sec) Added SSS and indirect lighting.
                                    http://www.mediafire.com/imgbnc.php/ba4e594ab41c011f7c2d574380312271a62efcdcbdc8e5cecb26ec7c13872e176g.jpg
                                      Virtual stones carving at the top! ๐Ÿ˜Ž
                                      • orgelfO Offline
                                        orgelf
                                        excellent ! ๐Ÿ˜„
                                        which build did you use ?
                                          michaliszissiou
                                          thanks orgelf, r35474. have a closer look in textures palette when nor is enabled (negative values in this case)
                                          Another one, this at 40k, one sub for displ and the rest as new blender bumps. A 30 sec render.
                                          http://www.mediafire.com/imgbnc.php/18831fc3e109bc67c4c844d31fb75bc3d8c912c6bc83ab55b4479c962a8080226g.jpg
                                          • N Offline
                                            nomeradona
                                            now i cant follow the workflow. too many new things to me. nevertheless you are far far so far with your workflow. congratulations michalis/ ๐Ÿ‘
                                            • 2 / 3
