    Newbie's anxiety ---- simple question
    5 Posts 2 Posters 361 Views 2 Watching
    • B
      bitbugbut
      Help!
      I wanna use "bed" in "Components Sampler", get its attribute"LenZ" , than write it into a txt file.
      How to write the codes?
      I watched a book named "Automatic Sketchup Creating 3D Models in Ruby",still do nothing 😞
      anyone help?Thanks
        Not all things have attributes.
        LenZ is one that a Dynamic Component has.
        I think that 'bed' isn't a DC ?
        If you want the size of something use something like bb=entity.bounds
        and then z=bb.depth
        x id width and y is height for a bounding box...
        If you explain what you wanted this for it might help.
        Writing a value to a text file is not much use ?
        The book you refer to has lots of help parts about all of this and more...
        Don't run before you can walk... πŸ˜‰
        • B
          bitbugbut
          thanks a lot:)
          my real obstacle is : I create a component in design mode, its name : cup.
          when i write the code : bb=cup.bound , error coming:(
          bb=cup.bounds
          Error: #<NameError: undefined local variable or method `cup' for main:Object>
          (eval)
          Is my component"cup" not a entity?
          I hope you can give me the fully code segment about how to use defined componet"cup".thanks a lot!!!!! πŸ‘
            Ahhh...
            If you have definitely made a component called 'cup' [or even imported one into your SKP] then it should show up in the Component Browser > Model [small-house] icon...
            You need to make a reference to the definition thus
            model=Sketchup.active_model defs=model.definitions cup=defs["cup"]
            IF there is component called 'cup' you now have a 'reference' called 'cup' that points to it.
            If you type
            cup
            you should get a reference to it.
            Then
            bb=cup.bounds x=bb.depth
            etc ...
            If you have more questions [I'm sure you will!] post them in the Ruby forums - like the Developers' Section... πŸ€“
            • B
              bitbugbut
              It really done:)
              thanks a lot .
