    [Plugin] Hidden Manager (08.Feb.2015)
    48 Posts 19 Posters 40.3k Views 19 Watching
    • schorradtS
      schorradt
      Update: 16.Feb.2011
      • Change to start the observer on activate and remove on deaktivate now. i hope the bugsplash from other Plugins (ImageTrimmer or Slicer etc...) is removed...
      http://www.henryschorradt.de/
      • B
        bdbox
        Error Loading File mx_hidemanager_loader.rb
        C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/mx_hidemanager_loader.rb:58: syntax error
        mx_hiddenmanager = SketchupExtension.new "Hidden Manager", File.join ("mx_hidemanager","mx_hidemanager.rbs")
        • schorradtS
          schorradt
          I'm sorry, but it works on my computer. I can find no error.
          Perhaps the pathfunctions does not feature in Sketchup 7 !?
            Henry:
            This can confuse Ruby - you have space after the method name and the brackets. ( File.join ) On top of that you have that as one of the argument of another method call ( SketchupExtension.new ) where you don't use brackets.
            To avoid potential errors, always use brackets. But most important of all, never leave a space between the method name and the brackets.
            It's a bit odd that a SU7 user should report this error, because SU8's ruby is more strict. Regardless, this should work:
            mx_hiddenmanager = SketchupExtension.new( "Hidden Manager", File.join("mx_hidemanager","mx_hidemanager.rbs") )
            • B
              bdbox
              @thomthom said:
              Henry:
              i got this error:
              No such file to load -- mx_hidemanager/mx_hidemanager.rbsError Loading File mx_hidemanager_loader.rb
                mac1
                schorradt
                What capability does this provide vs what the outliner has now??
                • N
                  nomeradona
                  nifty tool as your hidden elements are in one place. I can see the relevance.
                  • E
                    Evan Garmaise
                    @bdbox said:
                    @thomthom said:
                    Henry:
                    i got this error:
                    Some of my users of the PieceTracer tool have reported the same mysterious "No such file to load" error, as you can see here:
                    http://forums.sketchucation.com/viewtopic.php?f=80&t=34492
                    A couple of similarities between Hidden Manager and PieceTracer:
                    1. Both have an underscore in both the directory name and the file name, as most plugins do not.
                    2. Both load the scrambled ruby file directly out of the loader file instead of using a second unscrambled file inside the sub-directory that loads the scrambled file using a 'require' statement or similar, as many plugins do.
                    Could these similarities point to a solution to the problem? Could be worth creating a test version with these things fixed to see if that solves the loading problem for those users who have it.
                    • E
                      Evan Garmaise
                      I checked with my users and fixing #2 above fixed the problem. schorradt, just create a .rb file in your subdirectory with one line: "Sketchup::require " and then the name of your scrambled file. Then load that .rb file out of your loader file using SketchupExtension. That will fix the loading problem for your users who have it.
                      • EarthMoverE
                        EarthMover
                        Thanks Evan. Good advice. I have the same issue, presumably a conflict with Piece Tracer. I'll see if I can do it manually until the author fixes the issue.
                        Content Creator at Skapeup
                        • C
                          cozzolino13
                          this doesn't work after install scf power toolbar
                          thank
                          • G
                            Gunny
                            thank
                            quote
                            • schorradtS
                              schorradt
                              Hello! I am back!
                              here is an update, tested in Sketchup 2014. At the moment without new features but I'm thinking about.
                              Hidden Manager 1.0.1 (21.03.2014)
                              • KrisidiousK
                                Krisidious
                                SCF Toolbar has some files in it that create conflicts. There are two or three files that need to be removed as they are outdated and in the wrong location.
                                By: Kristoff Rand
                                • schorradtS
                                  schorradt
                                  oh right... i will check it out. thx
                                  do you mean "SCF Power Toolbar v1" or where can i find a new version?
                                  • KrisidiousK
                                    Krisidious
                                    I don't think there is a new one. I think this thread goes over the issues found in it.
                                    404 Not Found
                                    (sketchucation.com)
                                    By: Kristoff Rand
                                    • schorradtS
                                      schorradt
                                      I think it's more a problem of Toolbar extension. ! Or?
                                      please report error message if you get a conflict with my plugin. thx
                                      • KrisidiousK
                                        Krisidious
                                        Yeah, this has nothing to do with your plugin Henry. This was in response to this.
                                        Re: [Plugin] Hidden Manager (16.Feb.2011)
                                        Postby cozzolino13 » Fri Mar 11, 2011 3:50 am
                                        By: Kristoff Rand
                                        • P
                                          Pherim
                                          It doesn't seem to work with SU2015 64bit.
                                          • P
                                            Pherim
                                            Has this been updated for SU2015 64bit? It appears to be working now, though with it installed, SketchUp crashes when I use SketchUV to triangulate faces which are not inside a group or component (quite the opposite of the problem that occured with Components Manager and RoundCorner, where Sketchup would crash when RoundCorners was used inside components).
                                            • 2 / 3
