    [Plugin] Hidden Manager (08.Feb.2015)
    48 Posts 19 Posters 39.2k Views 19 Watching
    • E Offline
      Evan Garmaise
      I checked with my users and fixing #2 above fixed the problem. schorradt, just create a .rb file in your subdirectory with one line: "Sketchup::require " and then the name of your scrambled file. Then load that .rb file out of your loader file using SketchupExtension. That will fix the loading problem for your users who have it.
      • EarthMoverE Offline
        EarthMover
        Thanks Evan. Good advice. I have the same issue, presumably a conflict with Piece Tracer. I'll see if I can do it manually until the author fixes the issue.
        Content Creator at Skapeup
          cozzolino13
          this doesn't work after install scf power toolbar
          thank
            Gunny
            thank
            quote
            • schorradtS Offline
              schorradt
              Hello! I am back!
              here is an update, tested in Sketchup 2014. At the moment without new features but I'm thinking about.
              Hidden Manager 1.0.1 (21.03.2014)
              http://www.henryschorradt.de/
              • KrisidiousK Offline
                Krisidious
                SCF Toolbar has some files in it that create conflicts. There are two or three files that need to be removed as they are outdated and in the wrong location.
                By: Kristoff Rand
                  schorradt
                  oh right... i will check it out. thx
                  do you mean "SCF Power Toolbar v1" or where can i find a new version?
                    Krisidious
                    I don't think there is a new one. I think this thread goes over the issues found in it.
                    404 Not Found
                    (sketchucation.com)
                    By: Kristoff Rand
                      schorradt
                      I think it's more a problem of Toolbar extension. ! Or?
                      please report error message if you get a conflict with my plugin. thx
                        Krisidious
                        Yeah, this has nothing to do with your plugin Henry. This was in response to this.
                        Re: [Plugin] Hidden Manager (16.Feb.2011)
                        Postby cozzolino13 » Fri Mar 11, 2011 3:50 am
                        By: Kristoff Rand
                          Pherim
                          It doesn't seem to work with SU2015 64bit.
                            Pherim
                            Has this been updated for SU2015 64bit? It appears to be working now, though with it installed, SketchUp crashes when I use SketchUV to triangulate faces which are not inside a group or component (quite the opposite of the problem that occured with Components Manager and RoundCorner, where Sketchup would crash when RoundCorners was used inside components).
                              Jim
                              This plugin needs an audit. It is well-meant, although careless compilation of code.
                                BMoffa
                                Great plug-in idea. However, I discovered a problem when working with one of my dynamic components when your plug-in is loaded. I started getting hard crashes of Sketchup when I change a parameter that changed the number of copies of a subcomponent. It is so bad that the bug-splat screen doesn't even display. Unloading your plug-in fixes the problem for me. I can send you the dynamic component if it will help.
                                I am using the Sketchup Pro 15.3.331 64-Bit.
                                • 3 / 3
