    [Plugin] Hidden Manager (08.Feb.2015)
    48 Posts 19 Posters 37.5k Views 19 Watching
    • EarthMoverE Offline
      EarthMover
      Thanks Evan. Good advice. I have the same issue, presumably a conflict with Piece Tracer. I'll see if I can do it manually until the author fixes the issue.
      Content Creator at Skapeup
        cozzolino13
        this doesn't work after install scf power toolbar
        thank
          Gunny
          thank
          quote
          • schorradtS Offline
            schorradt
            Hello! I am back!
            here is an update, tested in Sketchup 2014. At the moment without new features but I'm thinking about.
            Hidden Manager 1.0.1 (21.03.2014)
            http://www.henryschorradt.de/
            • KrisidiousK Offline
              Krisidious
              SCF Toolbar has some files in it that create conflicts. There are two or three files that need to be removed as they are outdated and in the wrong location.
              By: Kristoff Rand
                schorradt
                oh right... i will check it out. thx
                do you mean "SCF Power Toolbar v1" or where can i find a new version?
                  Krisidious
                  I don't think there is a new one. I think this thread goes over the issues found in it.
                  http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=52474%26amp;p=475625%26amp;hilit=+custom+toolbar#p475625
                  By: Kristoff Rand
                    schorradt
                    I think it's more a problem of Toolbar extension. ! Or?
                    please report error message if you get a conflict with my plugin. thx
                      Krisidious
                      Yeah, this has nothing to do with your plugin Henry. This was in response to this.
                      Re: [Plugin] Hidden Manager (16.Feb.2011)
                      Postby cozzolino13 » Fri Mar 11, 2011 3:50 am
                      By: Kristoff Rand
                        Pherim
                        It doesn't seem to work with SU2015 64bit.
                          Pherim
                          Has this been updated for SU2015 64bit? It appears to be working now, though with it installed, SketchUp crashes when I use SketchUV to triangulate faces which are not inside a group or component (quite the opposite of the problem that occured with Components Manager and RoundCorner, where Sketchup would crash when RoundCorners was used inside components).
                            Jim
                            This plugin needs an audit. It is well-meant, although careless compilation of code.
                              BMoffa
                              Great plug-in idea. However, I discovered a problem when working with one of my dynamic components when your plug-in is loaded. I started getting hard crashes of Sketchup when I change a parameter that changed the number of copies of a subcomponent. It is so bad that the bug-splat screen doesn't even display. Unloading your plug-in fixes the problem for me. I can send you the dynamic component if it will help.
                              I am using the Sketchup Pro 15.3.331 64-Bit.
                              • 3 / 3
