    What is this icon?
    11 Posts 6 Posters 1.3k Views 6 Watching
    • dereiD Offline
      derei
      Hy, I installed some plugins and I noticed this icon: icon.png
      What is this?
        museummaker
        I saw that too, believe that it toggles the shadow strings fix that fixes the shadow bug.
        • dereiD Offline
          derei
          I did not had that bug. Is it a plugin, or a SketchUp default icon?
            museummaker
            Its a native toolbar in the some of the latest releases.
            I don't use the shadows too often but the bug bothered lots of people.
              Yes, when they fixed the Shadow bug they found cases, particular to nVidia card, where you might get some shadow artefacts some times. Toggling this button allows you to toggle a fix for this artefact.
              • mitcorbM Offline
                mitcorb
                When you mouse over the icon, you don't get a hint box?
                  Already had to use in on 3d text float in a studio setup! did the job 👍
                    I do:
                      You don't get tooltips if another window, including the toolwindows, has focus. Ensure the SketchUp window has focus when hovering over the buttons and you should get the tooltip.
                      • mitcorbM Offline
                        mitcorb
                        Thanks, thomthom:
                        When you say "has focus" you mean the active window, right?
                          @mitcorb said:
                          Thanks, thomthom:
                          Yes.
