    Toolbar toggle Fredo, Fullmer, TT, etc.
    11 Posts 4 Posters 1.9k Views 4 Watching
    • Chris FullmerC Offline
      Hi Wind-born. Sorry, I don't follow the toolbar conversations very closely. I'm not exactly sure what you're asking here. My understanding is that you used to set up shortcuts to toggle on and off toolbars (somethingI've never done or never even tried to do). Does the script need to be writtenly in a specific way to make that work? What exaclty was wrong with my scripts and how did you change them so they worked? Are there any of my scripts that you still need help to fix?
      Thanks,
        I'm also not sure if I understand the issue in question either... πŸ˜•
        • wind-borneW Offline
          wind-borne
          Hi Chris,
          Don't know what changed to cause problem but this solved.
          I just deleted the space between Extended Standard in the toolbar line, now toggles toolbar with that spelling in shortcut. Adjusted your others as shown in screenshot previous post.
          clf_extended_views = $clf_tools_menu.add_submenu("Extended Standard Views")
          	toolbar = UI::Toolbar.new "ExtendedStandard Views"
          "To read between the lines was easier than to follow the text."OSX 10.11.6
          %(#BF80BF)[SU 8 pro
            wind-borne
            Selection Toys toolbar toggled for ages, recently the shortcut heads to the tool menu shown on right instead of tool palette in view menu left.
            Never used to show up as shortcut in tool menu before. Don't know if caused by upgrading to Snow Leopard or SU maintenance release as did both almost simultaneously. If there was a slight variation as I did in Chris' problem would be solved but I am lost when looking inside your plugins.
            Here is an example why I can't do within SU, choosing one chooses all but only toggles one
            %(#BF80BF)[SU 8 pro
              What? you can assign the same shortcut key to multiple items?
              Under Windows it doesn't let you do that - it overrides.
                wind-borne
                More like a bug, only one palette will toggle, you can't select individual within SU πŸ‘Š
                %(#BF80BF)[SU 8 pro
                  But I don't understand why you need to rename the menu names, SU identifies the correct menu by it's parent menus...
                    wind-borne
                    I don't know why but this shows how shortcut aims at Tool menu rather than View menu, Tool flashes each time I tap control C.
                    Screenshot on opening post shows shortcut on both menus.
                    http://www.youtube.com/watch?v=Auz6rSXoZG8
                    %(#BF80BF)[SU 8 pro
                    • fredo6F Offline
                      Wind-borne,
                      I don't know exactly waht is the issue you try to address, but, for information, you can change the name of the toolbar for all my plugins using LibFredo6.
                      Just go to the menu "Default Options".
                        wind-borne
                        Fredo,
                        Thanks for the heads up on the ones in your collection.
                        Inside the Joint Push Pull folder I found the line to modify so that one is working again also.
                        On my Mac have never been able to set shortcuts for toolbars inside SU.
                        I usually work with only one row of toolbars down side and toggle on and off as needed.
                        I assume the problem began when I installed Snow Leopard as was problem free in this regards beforehand.
                        Many thanks for your tools.
                        %(#BF80BF)[SU 8 pro
