    Thea Render - Interactive Rendering
    extensions
    146 Posts 23 Posters 54.1k Views 23 Watching
      Wow. I saw something in BasCampe (on Pete's computer) and I cannot remember if this (or at least parts of it) is the same but even if so, it is definitely impressive to watch.
      A big πŸ‘ for Giannis and the whole team (including plugin authors, beta testers, contributors and all)!
      • soloS Offline
        At Basecamp I had a bunch of renders strapped to a slideshow, this is something way beyond what I had, very impressive stuff here. The music works well too.
        I'm just happy I got a few renders included in this masterpiece.
        I'm most happy that in a small way I was able to be a part of Thea's growth.
        • N Offline
          notareal
          Moving towards the release - farewell beta. Thea Render v1.0.1-RC1 Revision 460 is now available at the development forum.
          This is our first release candidate!
          Nevertheless, it has also new features and not only bug fixes. For those that work with the OpenGL Viewport
          a lot, they can now start a region render (in the darkroom) by selecting an area in the Viewport. You have to
          click on the tool drop down menu and select the Region first, then left-click and drag to select the area
          to be rendered. Even more, as a workflow optimization, you can now pin the tools/navigation drop-down
          menu (a new menu appears above the compass), so you can quickly make a selection!
          Another cool UI addition is locking camera aspect ratio; something very small, yet asked for so many times!
          There are also various fixes for Relight and also displacement mapping is now rock solid. 😎
          The point lights can now be also described in terms of Power/Unit/Efficacy, establishing a uniform
          description between point and area lights. On top of that, there is a crucial bug for all unbiased engines
          (and IR included) that was adding wrong noise when rendering with 2+ threads - this is now fixed
          and it basically means faster renders when using TR1/TR2/IR! πŸ˜‰
          You can find latest revision in our usual thread:
          http://www.thearender.com/forum/viewtopic.php?f=61&t=1849
          best wishes
            whooop!
            • N Offline
              notareal
              Second release candidate is now available for testing.
              Thea Render v1.0.2-RC2 Revision 465 (10 February 11)
              • Emitters are now normalized according to compensate for color given, i.e. a red and green emitter of same power will have the same luminance. (all engines)
              • Finer accuracy regarding emittance and color manipulation. (all engines)
              • Minor scale fix when saving in hdr/exr formats. (I/O)
              • Minor correction reading correctly Sharpness check box from a scene. (I/O)
              • Material and texture editors can now open XML files from user interface. (I/O)
              • Material editor preserves now material name after opening a file. (I/O)
              • Display/saving of an image is now consistent when changing between relight and channel images. (UI)
              • Bug fix for anisotropy mapping when textures are used. (all engines)
              • Fixed script execution (keeping normal refresh rate in the display). (UI)
              • Server is successfully stopping now when reaching max number of passes in network rendering. (net rendering)
              • N Offline
                notareal
                Thea Render RV470 v1.0.3 RC3 is available at the development forum.
                Dear friends,
                with this revision, we have basically made our big step towards final release, in fact, this release candidate could be the base for the final release. And we simply, "touched" a lot of important areas in Thea.
                First of all, and most crucial, is that we have re-calibrated the display output along with changes in sun-sky system. All lights and HDRIs have been confirmed with respect to their power. We introduced also new units Watts per nanometer (W/nm) for representing power distribution and removed the - obsolete now - multiplier for point lights. These changes won't show much difference when trying to render a scene (quality-wise), but for older scenes, sun-sky has to be regenerated (disable/enable sky) to get proper render. This is why, if you are in the middle of production rendering, that you should not jump directly to this revision, as it generally needs some re-tuning on the lights.
                Moving on, this revision is the most robust one, geometry-wise. Displacement, anisotropy, bump and normal mapping have been considerably improved. Anisotropy is now working excellent even on the most difficult meshes (mixed flat/smooth meshes). Normal and especially bump mapping are better than ever, without exhibiting the high frequency noise ("fireflies") that takes so long to clear in unbiased modes!
                Apart from the above, there are also other small fixes along with full string table for translators (to be published). As always, you can find the new revision in the usual thread: http://www.thearender.com/forum/viewtopic.php?f=61&t=1849
                best wishes
                • V Offline
                  Vicspa
                  SOLO, I just got Thea, and playing around with it, I'm trying something like your 2 enclosed images, but not getting shadow results, can you elaborate more or show settings, and is it possible to control size of image. Thanks much.
                    You need to apply an infinite plane but set it to only receive shadows (not to be seen). That's actually where the shadow is cast, not the background image.
                    Then you need to fiddle around with orbiting and zooming and all as you cannot position (or scale) the background image itself.
                    • N Offline
                      notareal
                      A quick update, Thea Render RC4 is available with enhanced IES support; now, you can drag & drop an IES file to your material editor.
                      http://www.thearender.com/forum/viewtopic.php?f=61&t=5027&start=0
                      Changes Log
                      Thea Render v1.0.4-RC4 Revision 472 (25 February 11)
                      • Fixed sun being visible now in the presence of infinite plane. (unbiased/IR engines)
                      • Sun is now present for all unbiased modes. (TR1/IR engines)
                      • Fixed aliasing artifacts for infinite plane. (all engines)
                      • Fixed crash when editing color temperature in color lab and using a translation. (UI)
                      • Added ability to drag & drop ies files to material editor or apply them to scene selection (area and point lights must be already ies). (UI)
                      • Added Multiplier for IES point and area lights. (I/O)
                      • Bug fix for camera objects to be visible in the Viewport (bug introduced in RV470). (UI)
                      • Text values for Combo control are now translated as well. (I/O)
                        Use IES on materials? ❓
                        • N Offline
                          notareal
                          Under emitter... πŸ’­ Enable IES file.
                          • N Offline
                            notareal
                            The first official release version of Thea Render is now available at the development forum.
                            Dear friends,
                            this is it! The first official release version. It is basically like the previous revision with only a few minor fixes.
                            We want to thank you all that contributed with one or the other way! We will continue with the same and
                            faster pace from now on and we have already some very powerful features on the way! πŸ˜‰
                            You can find the download links in the usual thread: http://www.thearender.com/forum/viewtopic.php?f=61&t=1849
                            best wishes
                            • V Offline
                              Vicspa
                              Since I missed installing revisions 2 and 3, can I just install rev 5, and that will take care of all the other revisions,
                              or do I need to go back and install in order.
                              • N Offline
                                notareal
                                Just install over the version you have. No need for incremental installations, no need to uninstall the earlier version.
                                • V Offline
                                  Vicspa
                                  Thanks notareal, I was hoping for that. πŸ‘
                                    What I don't understand is how one, for what purpose, one use IES lights as a material. The material will act as an emitter? From which point?
                                    • N Offline
                                      notareal
                                      Little heads up with latest Thea Render development: http://www.thearender.com/forum/viewtopic.php?f=61&t=5161
                                      Invisible object can now cast shadows and caustics for all engines. Great if you need to see trough wall or objects, but still need to get proper shadows and caustics from them. I imagine this also could be used also with 2.5D plants and so...
                                      Changes Log
                                      Thea Render v1.0.6 Revision 478 (11 March 11)
                                      • Added ability to build material and ies previews from Browsers. Minor fix to force preview building when material editor has auto refresh off. (UI)
                                      • Added ability to have 2 license files, one for studio and one for client. (Licensing)
                                      • Region render works correctly now with network rendering. (Network)
                                      • Fix when saving color+alpha png image without extension. (UI)
                                      • Fix when canceling saving an image. (UI)
                                      • Visible and Shadow Caster flags work now for all engines. (all engines)
                                      • Some minor adjustments for spectrum editor in color lab. (UI)
                                      • Fixed BSD artifact with thread synchronization loss when irradiance caching is used. (Adaptive BSD)
                                      • Great improvement for sampling rough glossy materials in the presence of point and area lights. (Adaptive BSD)
                                      • N Offline
                                        notareal
                                        Thea Render v1.0.7 Revision 481 (16 March 11) available at the development forum.
                                        Dear friends,
                                        this is another quick revision with small fixes here and there.
                                        Quality-wise, there is a small improvement when rendering non-power-of-2 textures (for example, 200x200 instead of 256x256); they will appear sharper. The difference will be negligible though for high-resolution textures. Additionally, an important bug on MacOSX reading XML files from SU plugin has been now resolved.
                                        One nice addition in this revision, is that you can place (manually) the sun so that it matches the image used for sky illumination. This was asked in the past as a means to "align" the sun and IBL. This is possible because - starting from this revision - the image, in the IBL slot, is displayed in the OpenGL gizmo, whenever the sun is selected. Check the description page below, to see the series of steps needed to take advantage of this feature.
                                        As always you can find the download links and changes log in the following thread:
                                        best wishes
                                        • N Offline
                                          notareal
                                          Thea Render v1.0.8 Revision 486 is available at the Thea development forums.
                                          This revision has also 2 major improvements.
                                          First is the improved sampling of diffuse and rough glossy surface in the presence of IBL for Adaptive BSD method. Especially, when the lighting in the IBL has a lot of variation.
                                          Second, a big workflow improvement has been added. We can now save Sky/IBL/Sun settings with a few clicks and easily apply them later in another scene. This way, you can easily now create your sky libraries (including your sun settings) and restore them with a simple drag & drop in the Viewport.
                                          Changes Log
                                          Thea Render v1.0.8 Revision 486 (30 March 11)
                                          • Fix for evaluation of grayscale non-power-of-2 bitmaps (bug introduced in previous public revision RV481). (all engines)
                                          • Hemisphere gizmo in OpenGL Viewport displaying HDRI is now independent of IBL intensity. (UI)
                                          • Added ability to save sky settings (through browser context menu) and restore by simple drag & drop into Viewport. (UI-I/O)
                                          • Browser icons have now 3 sizes (the previous 2 plus a higher resolution 150x150). Scene previews are also saved now in (higher) 150x150 resolution. (UI)
                                          • Corrected renaming and removal of IES files in browser. (UI)
                                          • Fixed chromaticity for sky previews and hemisphere gizmo. (UI)
                                          • Building of adaptive bitmap resolutions (for trilinear interpolation) is now taking place on demand (it is used only by Adaptive BSD). (memory management)
                                          • Some code refactoring with respect to resources. (refactoring).
                                          • Addition of secondary browser in studio, it can be accessed from Window > Browser #2. (UI)
                                          • Fixed minor bug where interpolation of HDR bitmaps was used as None despite having set to Bilinear/Trilinear. (all engines)
                                          • Vast improvement of diffuse and rough reflection sampling in the presence of IBL. (Adaptive BSD)
                                          • Added ability to save and restore backup files. (I/O)
                                          • Added automation for materials set selected ones to default min and max blurred subdivs. (UI)
                                          • Added Planar and Charles-Loop subdivision methods. (modeling)
                                          • Corrected tone mapping operations when used for bump mapping. (all engines)
                                          • Added ability to draw in OpenGL Viewport with full triangulation, key '' is the default one. (UI)
                                          • Fixed min/max emitter rays taken correctly into account now by direct light estimator. (Adaptive BSD)
                                          • Fixed render region brightness when Progressive (BSD) is used in darkroom rendering. (Progressive BSD)
                                          • Fixed peculiar crash when saving scene. (I/O)
                                          • Corrected time stamping of signed installers. (Windows/Installation)
                                          • N Offline
                                            notareal
                                            Thea Render Revision 491 is available at the development forum.
                                            Thea is now improved in terms of noise when it comes to IBL lighting with Reflection and/or Refraction maps defined. Affecting both, the unbiased core as well as Adaptive BSD.
                                            Another important addition in this revision is network rendering for Adaptive BSD! This works for still images (like unbiased modes) in a bucket rendering fashion.
                                            • 3 / 8
