    Thea Render - Interactive Rendering
    extensions
    146 Posts 23 Posters 45.9k Views 23 Watching
    • Chris FullmerC Offline
      Ooh, I had not noticed the ambient occlusion and dirt map before.....those sound fun! Thanks for the heads up. Its downloading now.
      • N Offline
        notareal
        AO & Dirt map are under development, so just some basic features are now available. Some discussion at http://www.thearender.com/forum/viewtopic.php?f=54&t=4365
        • N Offline
          notareal
          @gaieus said:
          Don't forget to mention the enhanced TR1 rendering with interiors, Notareal! That is also a very valuable improvement (and of course, region rendering!!!)
          I think I mentioned "improved efficiency of unbiased TR1 engine", but true... it's worth to emphasis; TR1 did got a serious boost, some scenes gained about 100% speed increase. It's almost like a dual core laptop jumped to quad. You may read about improvement of TR1 unbiased engine here: http://www.thearender.com/forum/viewtopic.php?f=17&t=4262
          (pop image open for animation and compare shadow areas)
          Animated gif showing renders of TR1 and TR1+ (as new enhanced TR1). Scene rendered by Pete Stoppel.
            ๐Ÿ˜ณ
            Sorry, indeed you did. Sigh... That was 4:19 a.m. here (without sleeping the night before...)
            • N Offline
              notareal
              Thea Render Beta 1.7.2 Revision 451 is released at the Thea development forum. In this revision, you will mostly find some fixes regarding animation setup. The rotation interpolation scheme has been replaced with a new one that is much more consistent when interpolating key frames. In addition to that, you can now click and drag the key frames (from the small handles on the top of the lines) having more control on the setup. There are also some network rendering improvements.
              • simon le bonS Offline
                simon le bon
                Hi Dear Pentti,
                All these new improvements sound very attractive (appreciate those focused on "network"). Thea Render brings together a wonderful team, really ๐Ÿ‘ ๐Ÿ‘
                Important note: the revision posted here is the latest development snapshot. To stay on the safe side, it is recommended to wait until some basic testing is made and version is accessible from our web site downloads section.
                Do you think we can install this new release right now ?
                Cheers,
                simon.
                  Will animation rendering work now? Mine always skips frames. If I can't get it to work, I'll take the issue over to the Thea forum.
                  • N Offline
                    notareal
                    Cheers,
                    simon.
                    There is a little IES related bug in the new RV, that should be fixed when new release is added on public download at http://www.thearender.com/cms/index.php/downloads/thea-render.html If you are using IES, it might be worth to wait for the public release - it should be available in few days.
                    @Chris, have you made a bug report? There are several bug fixes for animation and key-frames, so it may be fixed, give it a try.
                      I've got the new one downloading now. I'll give it a try and see if my animation works better. I was reading through the release notes and saw this one:
                      Fixed case when a late client was contributing a "ghost" image for a previous render. (network)
                      YES!!! That has come back to bite me so many times.... Glad to see its fixed. I'll test it later tonight I think.
                      I don't think I've really said how much I enjoy Thea. Glad my company invested in it,
                      • N Offline
                        notareal
                        Thea Render Beta 1.7.2 Revision 453 (15 January 11)
                        • Corrected opening of IES File (for point lights) from a properties panel (bug present in RV451-452). (UI)
                        • Corrected auto-detection of server in network rendering (bug present in RV451-452). (network)
                        • Automatically setting up min/max depth range in Viewport (fixing most cases where part of the scene becomes invisible). (UI)
                        Page not found - Thea Render
                        Thea Render (www.thearender.com)
                        Latest RV should be now fairly stable, one day closer to the release ๐Ÿ˜‰ I suggest that those with network rendering issues will give this release some hard beating.
                        • N Offline
                          notareal
                          Dear friends,
                          our 2011 showreel is now ready taking some of the best renders and animations that you have posted!
                          We would like to thank all creators* and all of our members for their contribution and - of course - for
                          pushing this renderer forward.
                          You can watch the showreel in our youtube page or in our facebook page where you are invited to join us.
                          best wishes
                          *credits appear at the end of the video.
                          (Attached to the first post of topic)
                            Wow. I saw something in BasCampe (on Pete's computer) and I cannot remember if this (or at least parts of it) is the same but even if so, it is definitely impressive to watch.
                            A big ๐Ÿ‘ for Giannis and the whole team (including plugin authors, beta testers, contributors and all)!
                            • soloS Offline
                              At Basecamp I had a bunch of renders strapped to a slideshow, this is something way beyond what I had, very impressive stuff here. The music works well too.
                              I'm just happy I got a few renders included in this masterpiece.
                              I'm most happy that in a small way I was able to be a part of Thea's growth.
                              • N Offline
                                notareal
                                Moving towards the release - farewell beta. Thea Render v1.0.1-RC1 Revision 460 is now available at the development forum.
                                This is our first release candidate!
                                Nevertheless, it has also new features and not only bug fixes. For those that work with the OpenGL Viewport
                                a lot, they can now start a region render (in the darkroom) by selecting an area in the Viewport. You have to
                                click on the tool drop down menu and select the Region first, then left-click and drag to select the area
                                to be rendered. Even more, as a workflow optimization, you can now pin the tools/navigation drop-down
                                menu (a new menu appears above the compass), so you can quickly make a selection!
                                Another cool UI addition is locking camera aspect ratio; something very small, yet asked for so many times!
                                There are also various fixes for Relight and also displacement mapping is now rock solid. ๐Ÿ˜Ž
                                The point lights can now be also described in terms of Power/Unit/Efficacy, establishing a uniform
                                description between point and area lights. On top of that, there is a crucial bug for all unbiased engines
                                (and IR included) that was adding wrong noise when rendering with 2+ threads - this is now fixed
                                and it basically means faster renders when using TR1/TR2/IR! ๐Ÿ˜‰
                                You can find latest revision in our usual thread:
                                http://www.thearender.com/forum/viewtopic.php?f=61&t=1849
                                best wishes
                                  whooop!
                                  • N Offline
                                    notareal
                                    Second release candidate is now available for testing.
                                    Thea Render v1.0.2-RC2 Revision 465 (10 February 11)
                                    • Emitters are now normalized according to compensate for color given, i.e. a red and green emitter of same power will have the same luminance. (all engines)
                                    • Finer accuracy regarding emittance and color manipulation. (all engines)
                                    • Minor scale fix when saving in hdr/exr formats. (I/O)
                                    • Minor correction reading correctly Sharpness check box from a scene. (I/O)
                                    • Material and texture editors can now open XML files from user interface. (I/O)
                                    • Material editor preserves now material name after opening a file. (I/O)
                                    • Display/saving of an image is now consistent when changing between relight and channel images. (UI)
                                    • Bug fix for anisotropy mapping when textures are used. (all engines)
                                    • Fixed script execution (keeping normal refresh rate in the display). (UI)
                                    • Server is successfully stopping now when reaching max number of passes in network rendering. (net rendering)
                                    • N Offline
                                      notareal
                                      Thea Render RV470 v1.0.3 RC3 is available at the development forum.
                                      Dear friends,
                                      with this revision, we have basically made our big step towards final release, in fact, this release candidate could be the base for the final release. And we simply, "touched" a lot of important areas in Thea.
                                      First of all, and most crucial, is that we have re-calibrated the display output along with changes in sun-sky system. All lights and HDRIs have been confirmed with respect to their power. We introduced also new units Watts per nanometer (W/nm) for representing power distribution and removed the - obsolete now - multiplier for point lights. These changes won't show much difference when trying to render a scene (quality-wise), but for older scenes, sun-sky has to be regenerated (disable/enable sky) to get proper render. This is why, if you are in the middle of production rendering, that you should not jump directly to this revision, as it generally needs some re-tuning on the lights.
                                      Moving on, this revision is the most robust one, geometry-wise. Displacement, anisotropy, bump and normal mapping have been considerably improved. Anisotropy is now working excellent even on the most difficult meshes (mixed flat/smooth meshes). Normal and especially bump mapping are better than ever, without exhibiting the high frequency noise ("fireflies") that takes so long to clear in unbiased modes!
                                      Apart from the above, there are also other small fixes along with full string table for translators (to be published). As always, you can find the new revision in the usual thread: http://www.thearender.com/forum/viewtopic.php?f=61&t=1849
                                      best wishes
                                      • V Offline
                                        Vicspa
                                        SOLO, I just got Thea, and playing around with it, I'm trying something like your 2 enclosed images, but not getting shadow results, can you elaborate more or show settings, and is it possible to control size of image. Thanks much.
                                          You need to apply an infinite plane but set it to only receive shadows (not to be seen). That's actually where the shadow is cast, not the background image.
                                          Then you need to fiddle around with orbiting and zooming and all as you cannot position (or scale) the background image itself.
                                          • N Offline
                                            notareal
                                            A quick update, Thea Render RC4 is available with enhanced IES support; now, you can drag & drop an IES file to your material editor.
                                            http://www.thearender.com/forum/viewtopic.php?f=61&t=5027&start=0
                                            Changes Log
                                            Thea Render v1.0.4-RC4 Revision 472 (25 February 11)
                                            • Fixed sun being visible now in the presence of infinite plane. (unbiased/IR engines)
                                            • Sun is now present for all unbiased modes. (TR1/IR engines)
                                            • Fixed aliasing artifacts for infinite plane. (all engines)
                                            • Fixed crash when editing color temperature in color lab and using a translation. (UI)
                                            • Added ability to drag & drop ies files to material editor or apply them to scene selection (area and point lights must be already ies). (UI)
                                            • Added Multiplier for IES point and area lights. (I/O)
                                            • Bug fix for camera objects to be visible in the Viewport (bug introduced in RV470). (UI)
                                            • Text values for Combo control are now translated as well. (I/O)
                                            • 3 / 8
