    Thea Render - Interactive Rendering
    extensions
    146 Posts 23 Posters 62.9k Views 23 Watching
    • Chris FullmerC
      Will animation rendering work now? Mine always skips frames. If I can't get it to work, I'll take the issue over to the Thea forum.
      • N
        notareal
        @simon le bon said:
        Do you think we can install this new release right now ?
        Cheers,
        simon.
        There is a little IES related bug in the new RV, that should be fixed when new release is added on public download at http://www.thearender.com/cms/index.php/downloads/thea-render.html If you are using IES, it might be worth to wait for the public release - it should be available in few days.
        @Chris, have you made a bug report? There are several bug fixes for animation and key-frames, so it may be fixed, give it a try.
        • Chris FullmerC
          I've got the new one downloading now. I'll give it a try and see if my animation works better. I was reading through the release notes and saw this one:
          Fixed case when a late client was contributing a "ghost" image for a previous render. (network)
          YES!!! That has come back to bite me so many times.... Glad to see its fixed. I'll test it later tonight I think.
          I don't think I've really said how much I enjoy Thea. Glad my company invested in it,
          • N
            notareal
            Thea Render Beta 1.7.2 Revision 453 (15 January 11)
            • Corrected opening of IES File (for point lights) from a properties panel (bug present in RV451-452). (UI)
            • Corrected auto-detection of server in network rendering (bug present in RV451-452). (network)
            • Automatically setting up min/max depth range in Viewport (fixing most cases where part of the scene becomes invisible). (UI)
            http://www.thearender.com/forum/viewtopic.php?f=61&t=1849
            Latest RV should be now fairly stable, one day closer to the release πŸ˜‰ I suggest that those with network rendering issues will give this release some hard beating.
            • N
              notareal
              Dear friends,
              our 2011 showreel is now ready taking some of the best renders and animations that you have posted!
              We would like to thank all creators* and all of our members for their contribution and - of course - for
              pushing this renderer forward.
              You can watch the showreel in our youtube page or in our facebook page where you are invited to join us.
              best wishes
              *credits appear at the end of the video.
              (Attached to the first post of topic)
              • GaieusG
                Wow. I saw something in BasCampe (on Pete's computer) and I cannot remember if this (or at least parts of it) is the same but even if so, it is definitely impressive to watch.
                A big πŸ‘ for Giannis and the whole team (including plugin authors, beta testers, contributors and all)!
                • soloS
                  At Basecamp I had a bunch of renders strapped to a slideshow, this is something way beyond what I had, very impressive stuff here. The music works well too.
                  I'm just happy I got a few renders included in this masterpiece.
                  I'm most happy that in a small way I was able to be a part of Thea's growth.
                  • N
                    notareal
                    Moving towards the release - farewell beta. Thea Render v1.0.1-RC1 Revision 460 is now available at the development forum.
                    This is our first release candidate!
                    Nevertheless, it has also new features and not only bug fixes. For those that work with the OpenGL Viewport
                    a lot, they can now start a region render (in the darkroom) by selecting an area in the Viewport. You have to
                    click on the tool drop down menu and select the Region first, then left-click and drag to select the area
                    to be rendered. Even more, as a workflow optimization, you can now pin the tools/navigation drop-down
                    menu (a new menu appears above the compass), so you can quickly make a selection!
                    Another cool UI addition is locking camera aspect ratio; something very small, yet asked for so many times!
                    There are also various fixes for Relight and also displacement mapping is now rock solid. 😎
                    The point lights can now be also described in terms of Power/Unit/Efficacy, establishing a uniform
                    description between point and area lights. On top of that, there is a crucial bug for all unbiased engines
                    (and IR included) that was adding wrong noise when rendering with 2+ threads - this is now fixed
                    and it basically means faster renders when using TR1/TR2/IR! πŸ˜‰
                    You can find latest revision in our usual thread:
                    best wishes
                      whooop!
                      • N
                        notareal
                        Second release candidate is now available for testing.
                        Thea Render v1.0.2-RC2 Revision 465 (10 February 11)
                        • Emitters are now normalized according to compensate for color given, i.e. a red and green emitter of same power will have the same luminance. (all engines)
                        • Finer accuracy regarding emittance and color manipulation. (all engines)
                        • Minor scale fix when saving in hdr/exr formats. (I/O)
                        • Minor correction reading correctly Sharpness check box from a scene. (I/O)
                        • Material and texture editors can now open XML files from user interface. (I/O)
                        • Material editor preserves now material name after opening a file. (I/O)
                        • Display/saving of an image is now consistent when changing between relight and channel images. (UI)
                        • Bug fix for anisotropy mapping when textures are used. (all engines)
                        • Fixed script execution (keeping normal refresh rate in the display). (UI)
                        • Server is successfully stopping now when reaching max number of passes in network rendering. (net rendering)
                        • N
                          notareal
                          Thea Render RV470 v1.0.3 RC3 is available at the development forum.
                          Dear friends,
                          with this revision, we have basically made our big step towards final release, in fact, this release candidate could be the base for the final release. And we simply, "touched" a lot of important areas in Thea.
                          First of all, and most crucial, is that we have re-calibrated the display output along with changes in sun-sky system. All lights and HDRIs have been confirmed with respect to their power. We introduced also new units Watts per nanometer (W/nm) for representing power distribution and removed the - obsolete now - multiplier for point lights. These changes won't show much difference when trying to render a scene (quality-wise), but for older scenes, sun-sky has to be regenerated (disable/enable sky) to get proper render. This is why, if you are in the middle of production rendering, that you should not jump directly to this revision, as it generally needs some re-tuning on the lights.
                          Moving on, this revision is the most robust one, geometry-wise. Displacement, anisotropy, bump and normal mapping have been considerably improved. Anisotropy is now working excellent even on the most difficult meshes (mixed flat/smooth meshes). Normal and especially bump mapping are better than ever, without exhibiting the high frequency noise ("fireflies") that takes so long to clear in unbiased modes!
                          Apart from the above, there are also other small fixes along with full string table for translators (to be published). As always, you can find the new revision in the usual thread: http://www.thearender.com/forum/viewtopic.php?f=61&t=1849
                          best wishes
                          • V
                            Vicspa
                            SOLO, I just got Thea, and playing around with it, I'm trying something like your 2 enclosed images, but not getting shadow results, can you elaborate more or show settings, and is it possible to control size of image. Thanks much.
                            • GaieusG
                              You need to apply an infinite plane but set it to only receive shadows (not to be seen). That's actually where the shadow is cast, not the background image.
                              Then you need to fiddle around with orbiting and zooming and all as you cannot position (or scale) the background image itself.
                              • N
                                notareal
                                A quick update, Thea Render RC4 is available with enhanced IES support; now, you can drag & drop an IES file to your material editor.
                                http://www.thearender.com/forum/viewtopic.php?f=61&t=5027&start=0
                                Changes Log
                                Thea Render v1.0.4-RC4 Revision 472 (25 February 11)
                                • Fixed sun being visible now in the presence of infinite plane. (unbiased/IR engines)
                                • Sun is now present for all unbiased modes. (TR1/IR engines)
                                • Fixed aliasing artifacts for infinite plane. (all engines)
                                • Fixed crash when editing color temperature in color lab and using a translation. (UI)
                                • Added ability to drag & drop ies files to material editor or apply them to scene selection (area and point lights must be already ies). (UI)
                                • Added Multiplier for IES point and area lights. (I/O)
                                • Bug fix for camera objects to be visible in the Viewport (bug introduced in RV470). (UI)
                                • Text values for Combo control are now translated as well. (I/O)
                                  Use IES on materials? ❓
                                  • N
                                    notareal
                                    Under emitter... πŸ’­ Enable IES file.
                                    • N
                                      notareal
                                      The first official release version of Thea Render is now available at the development forum.
                                      Dear friends,
                                      this is it! The first official release version. It is basically like the previous revision with only a few minor fixes.
                                      We want to thank you all that contributed with one or the other way! We will continue with the same and
                                      faster pace from now on and we have already some very powerful features on the way! πŸ˜‰
                                      You can find the download links in the usual thread: http://www.thearender.com/forum/viewtopic.php?f=61&t=1849
                                      best wishes
                                      • V
                                        Vicspa
                                        Since I missed installing revisions 2 and 3, can I just install rev 5, and that will take care of all the other revisions,
                                        or do I need to go back and install in order.
                                        • N
                                          notareal
                                          Just install over the version you have. No need for incremental installations, no need to uninstall the earlier version.
                                          • V
                                            Vicspa
                                            Thanks notareal, I was hoping for that. πŸ‘
                                            • 3 / 8
