πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Exported to DWG file, smooth lines disappear
19 Posts 5 Posters 7.5k Views 5 Watching
    JRSly
    I searched back a few months and did a keyword search and couldn't find a similar topic, so hopefully I'm not treading on well trodden ground.
    I do AutoCad work, working with natural gas pipeline assemblies and recently I've started creating a lot of the components in SketchUp, in the hopes that it could eventually speed up my workflow as well as providing all the benefits that having a full 3D model of the assembly could provide. So my intention was to build all the fittings in SketchUp, stick 'em together and then export a couple ortho views to DWG and hop into AutoCAD where I have my title block and the callout/dimension styles already made. I've got just about all the kinks worked out and I'm hoping I can iron out the last couple so this whole crazy endeavor won't have been for naught.
    This problem occurs in some spots in ortho views, but is most apparent in an isometric view. I figure since I'm making a 3D model, exporting an isometric image is easy and would be useful and might be a regular feature of my drawings from this point on. But when I do so, a problem quickly arises, many smoothed edges disappear in the export process causing a lot of visual problems. I've attached a cropped isometric view and a render of the same area. You can see the form of the flange is not well conveyed in the isometric at all because of the lines that are treated as non-existent. And as I say, the problem is also apparent in some spots in other views, so just foregoing the isometric view isn't an option. There would still be some clean up necessary, which isn't really acceptable if I started this whole experiment in an effort to save time.
    So I guess my questions are, is this a quickly resolvable issue? Can I adjust any settings to make these liens visible? I don't expect to SketchUp to be as as smart as the user and know exactly what they want and don't want displayed, but I was a bit surprised that this level of detail would be lost. I can understand smoothed lines being invisible, but these are points with fairly severe angles of intersection(albeit with a smooth actual point of interaction) and I thought SketchUp would recognize that. Could it be a simple fix or am I going to have to go back and do a lot of redrawing and tweaking and learn to hold off on the smoothing in the future?
    And my other question would be, would it be considered a folly to design components that will both look nice when rendered in 3D and expect them to work as well in 2D in AutoCAD? The drawing style I have in AutoCAD is fairly detailed with realistic components and not more simplified scale/shape placeholders. So I'm trying to maintain that same high level of detail, but I may be going a bit overboard in an effort to create good-looking renders.
      Are you selecting what's exported off the Options ?Capture.PNGCaptureSKP.PNGCaptureDWG.PNGCaptureDWGrender.PNG
        JRSly
        I don't seem to have the same options dialog box, I'm using SketchUp 8. Are there corresponding options here for what I'd like to do?
        Edit: Ahhh, I see yours says "Export Model", where I'm trying to export a 2d graphic. I'm exporting it again right now after tweaking the settings, but I'll check the 3d export settings when it finishes...
          Exporting a 2d version makes a mere 'graphic'... BUT 3d should work OK...
          Exporting it as 2d is doomed to failure............
            JRSly
            Yeah, I guess I was a bit naive to hope that I could export a graphic from SketchUp and have the exact same image I would've drawn if I'd started in AutoCAD as usual. I can understand not catching the lines I pointed out in my isometric view, but I am surprised that it also loses parts of the outer edge, as you can see in the sample image posted. I could probably easily save a lot of the image by going back and selectively 'unsmoothing' parts or drawing my own edges where I need to see them, but it's a pointless exercise if I'll still randomly lose bits of outer edges like that when exporting.
            Exporting to 3D could have potential, it's nice and quick and I can make all my separate views in AutoCAD instead of having to export each view from SU. But, unless I'm dumb(and that's quite possible as this is my first venture into 3D/2D interaction), it always seems to display all the hidden/smoothed edges. Just like in your example, where you can see all the segments that form the flange and pipe. Which isn't what I want either. I could explode and delete all those lines, but that would be more work, which is what I'm trying to avoid as much as possible.
            Am I accurate in that assessment, or am I ignorant of some settings when dealing with 3D in AutoCAD? I'm messing around with the Visual Style Manager and not having much luck achieving what I want.
              dedmin
              Because You don't get true solids in AutoCAD, but polyface meshes - SketchUP is a mesh modeler. And they are useless in AutCAD prior 2010 - can't do much with them. In AutCAD 2010 and 2011 You can convert them to meshes and then to solids. But all this are approximations - it is not true geometry that keeps its real size. Export a simple circle from SketchUp - You get a bunch of lines in AutoCAD.
                JRSly
                Gah, I'm afraid this just isn't going to work like I envisioned it might. I think what's so frustrating though is that it's soclose to doing what I need, and it's a few little silly things getting in the way. Like the issue with the outlining edges of objects disappearing in the isometric view. Basically every line shows up in the orthogonal views, but randomly blips out in isometric. For example as the base of this assembly, I have a frame made of I-beams. In the top view, they look perfect, But in the iso view, the top edge disappears entirely because(assumedly) it has a rounded corner. Again, I'm admittedly basically an idiot in this discipline, but it doesn't make sense that it can recognize the edge in one view and not in another. I guess it can find the flat side of the I-beam in the top view? There's no line drawn on it though, so in concept it doesn't seem that different.
                Like I said earlier, I could go a long way towards correcting the issue by bringing back some of the edges I'd smoothed, but I won't be able to fix these edges.
                I'm learning more and more I guess, even from just a couple of nights ago I've come along way towards figuring out how to make it work, so maybe I should stay positive. And I've loved learning SketchUp and was really excited about getting more experience with it. But it's to the point where I have to consider cutting my losses, know what I mean?
                  dedmin
                  Yes, You have to face it - SketchUP is not a CAD, there are no real curves, splines, circles and etc. Just lines and faces. I had to make the same move - and went to Rhino and BricsCAD.
                    I'm still puzzled as to why you don't get good results ?
                    My example exported a SKP with smoothed edges into 3D DWG no problem.
                    Is it your CAD settings - there are literally dozens of ways to display it - have you tried them all ?
                    If you PM me an example SKP/DWG I can take a look, more leisurely.......
                      dedmin
                      I think He wants the same level of smoothest in AutoCAD as in SketchUP.
                        This is really a CAD issue ?
                        AutoCAD 2010 has mesh smoothing tools these might help ?
                        Sketchup is not a solid modeler 😞
                          Anssi
                          The Autocad tools do not work well on SU exports. Every SU face is converted into a separate polyface mesh, whether smoothed or not.
                          Anssi
                            JRSly
                            Right. Maybe this would help, as a point of reference this is a little cropped page of a random drawing I've made in AutoCAD.
                            http://img821.imageshack.us/img821/6389/autocadexample.jpg
                            So the drawing's are detailed, and without the segmentation and hidden geometry that a 3D export from SU has in AutoCAD. I tried some mesh-to-solid conversion, but it wasn't going very well and..as is becoming my catchphrase..it adds too much work to rationally attempt to continue working this way.
                            In good news though, I think I have ironed out a ton of the issues I was having and have been able to export nice, clean orthogonal views, which are most important. The issues I was having with isometric views aren't nearly as prevalent in ortho views. So if I forget about iso views, I might actually be able to make this work how I wanted, knowing what I know now and that I'll need to keep some things in mind as I continue modeling in SU.
                            http://img231.imageshack.us/img231/2936/sketchupexample.jpg
                            Though, perhaps the wisest course of action would be to look more into Rhino and hop ship while I'm still relatively starting out.
                              Have you seen my CADup.rb ? Currently in beta testing but it might help make 'flattened' drawings for you ?
                                dedmin
                                Well, I know Your feelings - SketchUP is very addictive! I tried all to stay with it, but it is just not up to the task! As much as I work in Rhino I feel I made the right move. And Rhino started as a plugin to AutoCAD - it shares the same command line, the same way of work but much better and faster. β˜€
                                And if don't need to much fancy detailing tools You can make the 2d drawing inside Rhino - it has Layuots, Viewports, better Layers - You have nested layers, You can control layer's visibility per viewport and even object visibility per viewport, make 2D and I can go on and on.
                                  JRSly
                                  Verrrry interesting, this sounds like a much better fit for what I need to do. I'm a bit nervous as, outside of screwing around with Blender 10+ years ago, SketchUp is me first foray into 3d modeling and I've had a lot of fun and luck with it. It's intuitive and easy to get started, but still very robust and capable. Plus all the cool plug-ins, So I'm leery of trying to learn another package. I don't suppose Rhino could easily import the couple weeks worth of work I've done in SketchUp could it? Heh, I'd be lying if I didn't say I'm not looking forward to starting over in that regard either.
                                  Since I've made it this far, I think I'll continue with SketchUp a little while longer, put together some drawings and renders and see if my boss sees going 3D as a worthwhile task. If he doesn't see the value at this point in time, not much sense in worrying about Rhino either.
                                  I haven't. I've downloaded a couple other plug-ins, but hadn't come across this one. I'll be sure to check it out.
                                    rabbit
                                    Well, if you can use autocad, you will have no trouble learning rhino!
                                    Well, it probably can - see image & attached pdf.
                                    What you are not going to be able to get around is the fact that in SU circles are just lines, and thus the 3D curved objects made from them will not be true in another program. However, you can easily model in rhino off the mesh you import by locking it, and then snapping to it as you make the nurbs objects. Rhino will also create nurbs geometry out of the SU mesh on import if you want, but it can't automatically replace a set of lines with a curve.
                                    Rhino can also load all your autocad work, and you can do all your 2D documentation there, so I would definitely look at it if I were you. You can download it for free from http://www.rhino3d.com - it will work for 25 saves. Bear in mind that ideally you would want to be using V5, which is in a very stable open beta at present, but you have to own V4 in order to get it.
                                    Also, if I were you, I would look at MOI ( http://www.moi3d.com ) - this is a cheaper (about $200.00) nurbs modeler created by the same guy who originally coded rhino - it has a great uncluttered interface, and is very simple to model with - the sketchup of nurbs. It does not support meshes directly, so you cannot import your sketchup models, but it has a fantastic clean export to sketchup, so complex curvy stuff sketchup does not like can be modeled there and exported. You can also cut and paste models and geometry between rhino and moi, with everything lining up perfectly.
                                    I just use the three programs together, depending on what I am doing - they are all fantastic!
                                    cheers
                                    su to rhino.pdf
                                      rabbit
                                      but wait - there's more!
                                      If you export from sketchup as a 3D model, in dwg or dxf format, then circles ARE exported as true circles, and further, as well as the mesh, a set of vectors describing the edges of the mesh objects are exported also.
                                      Thus in rhino (and I presume autocad) you a have a 3D vector wireframe of your object. So you would simply select the meshes, and delete (or hide) them. You can then simply extrude the curves to create true nurbs objects...and in general use this wireframe as an accurate guide to create your 3D nurbs objects from.
                                      cheers
                                      rabbit
                                        JRSly
                                        Thanks for that additional info, rabbit. Very encouraging. Knowing my AutoCAD experience will carry over somewhat is nice to hear.
                                        I put together a little presentation, a render, some 2D drawings as I would've produced in AutoCAD, and exported a 3D PDF page where you can see the model and spin it around right there in the PDF and sent that off to my boss. I'll see what he thinks and if he's into it, I'll definitely be looking more into Rhino.
