    [Plugin] CADup
    64 Posts 28 Posters 92.6k Views 28 Watching
    • srxS Offline
      srx
      Thank you. I just needed it πŸ˜„
      www.saurus.rs
        tomislavm
        Thank You!
          Good news:
          I am going to extend CADup to include the 6 centralized sections.
          I am looking at adjusting the way it handles 'surfaces' with hidden/smoothed lines, e.g. splitting the geometry onto new layers for these and the other outermost edges etc.
          I shall be adding an example CAD template [dwg/dwt] with its layers set appropriately for heavy/medium/thin/dashed lines etc pstyles, plan view etc, that you can use to set up new sheets and import the CADup output as dwg/dxf blocks...
          I'll be writing a tutorial.
          Bad news:
          Won't have time to do it for a few days...
            dedmin
            Good news! What about handling groups also?
              Yes I will also be adding support for using CADup on a selected group [as well as its current component-instance] AND for finding all edges within groups and component-instances that are nested within the selected object's entities...
                dedmin
                πŸ‘ πŸ‘ πŸ‘
                This is in BricsCAD:
                http://www.screencast.com/users/dedmin/folders/Jing/media/67e9351d-d895-487d-849d-5424b73e1cb5
                  tfdesign
                  Great looking plugin TIG!
                  Thanks very much for this, you're going to make a lot of people, especially product designers and engineers very happy!
                  Tom
                    @dedmin said:
                    :thumb: πŸ‘ πŸ‘
                    I see it makes iso/axo views... I was also thinking about how I might incorporate that in CADup...
                      dedmin
                      @tig said:
                      @dedmin said:
                      :thumb: πŸ‘ πŸ‘
                      Maybe based on the component/group axes or world axes - as two options. Because You can't be sure what are the front/back/right and etc. for a given component.
                      • kmeadK Offline
                        kmead
                        This is a very nice addition.
                        I have tried a couple of files, the first quite simple worked well.
                        The second caused the program to get into a loop where I had to force quit SU. I am on a Mac.
                        The file I had trouble with is proprietary so I cannot post it but would be willing to send it to you.
                        Karl
                        I created Dilbertville, sorry about that...
                          Karl
                          OK... I'm about to issue an update... so wait till after that - but if there's still a problem attached it [zipped ?] to a PM to me...
                            Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=309485#p309485
                            A Group OR an Instance can now be processed.
                            Edges within any Groups/Instances nested within the Selected Object are now reproduced on appropriate layers.
                            Edges that are hidden/smooth/soft in the Selected Object are now reproduced on the HIDN layer.
                            Spacing of Views etc has been improved.
                            Makes a trial version of a SECT-BOTTOM only - for feedback purposes...
                            Makes a trial version of a AXO-SW only - for feedback purposes...SECT+AXO.PNG This is 'flat' example.
                            Feedback please...
                              dedmin
                              http://www.screencast.com/users/dedmin/folders/Jing/media/c3154fc0-6d7c-4d41-803b-345c06131ef2
                                Please retry... BUT this time move the component/group in question so that it is well out of the same space as the CADup versions... i.e. NOT near the origin... I suspect that there's 'interference' between the original and the copy...
                                I can perhaps make this a v8 only app and hide the rest of the model...
                                The idea is you have an instance off to one side and then it makes the 2d parts...
                                Because it uses raytests and project_to_plane etc it can get confused...
                                This is still in beta - thanks for the report...
                                  barsaglini
                                  every time, I tried to use the plugin in houses that had already modeled, the sketchup closed =/
                                  small objects functioned normally
                                  πŸ˜„
                                    @barsaglini said:
                                    every time, I tried to use the plugin in houses that had already modeled, sketchup closed =/
                                    small objects functioned normally.
                                    πŸ˜„
                                    It is intended to CAD up components. A 'whole house' is going to be veeeery data intensive ???
                                    Perhaps the outer 'shell' will be OK but all of the internals that have to be inspected and discounted ????
                                    Even if 'hidden/off-layer!
                                    Export what you want to CAD up [select, right-click, save_as] and process that.
                                    There will be a new version out later today - see how that does... πŸ€“
                                    • W Offline
                                      watkins
                                      Morning TIG!
                                      Sound like you have a busy day!
                                      I am watching this space with interest as it has been suggested that postgrad students use SU for small design jobs rather than AutoCAD Inventor which is way over the top for most of their needs. Also, the free version od SU is, afterall, free. We have to watch our pennies these days, and even a student copy of Inventor is around Β£300.
                                      Regards,
                                      Bob
                                      • N Offline
                                        Nick2010
                                        Another Hit from Master Tig! Thank you so much!!!
                                          barsaglini
                                          get it!
                                          Great job, hope you can run stably!
                                          Tested on a cube, which made a hole in the left side, right side view of the hole he showed too;)
                                          Thank you.
                                            Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=309485#p309485
                                            Container now made into a Component for easier export to SKP.
                                            Please read the notes with the download link... there have been changes...
                                            All SECTion and AXOnonmetric views have been added.
                                            Arrangement of the 'parts' has been adjusted and the use of the original selected object has be modified to minimize potential 'clashes'.
                                            Default file/layer name of '2CAD' now becomes 'SKAD'.
                                            Feedback please...............
                                            • 1 / 4
