    Very basic help
    13 Posts 4 Posters 843 Views 4 Watching
    • O Offline
      oslocadiz
      Here it is : ) It' connected to a line.
      ex---1.skp
        Would it be something like this?
        ex---1.skp
          Or like this?
          If it's what I did, I copied the curves up to the top of the higher "wall" and then connected the vertices with the curve at the bottom (I exploded your curve group, too.) I used the Line tool from Tools on surface to create the sloped line between the tops of the end walls but it could be done by drawing in a plane and intersecting it with the curved surface. In either case, then just delete the face above the sloped line. I repeated that for the outside curve and then manually connected vertices to skin over the roof. As Csaba said, it could all be done with plugins, too.
          ex---1.skp
            Yes, that can also be... 😒
            • O Offline
              oslocadiz
              Yes like you did Dave. Will try to do it on the other ones.
              Thank you for your help.
                Any time.
                • O Offline
                  oslocadiz
                  I had a little problem understanding the second part of your explanation: how do you make the slope line a long the surface. I tried to make a line but because of the gap to the surface I can't trim it.
                  Step by step will I learn this gem of a program!!
                  • O Offline
                    oslocadiz
                    OK I got it!! : )
                    Sorry...It's the end of my workday and my brain is not being very imaginative.
                    Thanks again
                      The plane as you show does it nicely. The other thing I referred to is a plugin called Tools on Surface which lets you just draw the line between corners.
                      Maybe it's time for you to take a rest. 😉
                      • mitcorbM Offline
                        mitcorb
                        While looking at your images, it reminded me of something I am doing at home. I needed to project some geometry normal to the curved surfaces to sort of reflect a spherical effect. I used Chris Fullmer's 3 lines tool. You can use the normal selection, specify/correct the desired length by interacting with the VCB, and a line will be drawn normal to a face or a vertex. You can then draw from point to point on the endpoints of the normals.
                        • O Offline
                          oslocadiz
                          Great advice... There nobody left in my office so it's really about time to head back home-> where SU is all about fun 👍
                          I will first learn it the hard way and come back for plugin advice...but it's written down in my list for wanted plugin.
                          Have a nice day/evening
