    [Plugin] CleanUp
    974 Posts 217 Posters 833.6k Views 217 Watching
    • bagateloB Offline
      bagatelo
      Yes, Sir.
        That is not the latest SketchUp version. There is an update to SU8 you are missing.
        Btw - 3.1.3 is working now, right?
          I'd really suggest upgrading, Alexandro. There have been some really good improvements!
          (And when you are at it, you could also update your profile so that bug hunting plugin authors are not confused)
          • bagateloB Offline
            bagatelo
            thomthom: I'm so sorry.
            I've updated Sketchup now.
            Now it worked.
            I'm a fool. Thanks for your patience.
              I don't think TT would be angry with you (more likely he's glad it works now).
              But did it (that latest Cleanup version) also work with the previous SU 8 version?
                No - I'm not angry. But that update is really worth it. Some important fixes in SketchUp.
                And 3.1.3 should work for pre M1 now.
                • bagateloB Offline
                  bagatelo
                  I tested all the new versions of cleanup with sketchup 8 outdated and did not work. Only when I upgraded to the latest version of sketchup was the plugin cleanup worked well.
                  Is there something in the working of the plugin which I think could be rethought. That is what concerns processing of edges. Is there a difference between edges that form a face and are coplanar with other faces ("Erase Coplanar Edges") AND edges who are in face without being divided into other faces ("Erase Lonely Edges"). If could be distinguished in this way I can assign keyboard shortcuts for this two situations.
                    Errors?
                    You can assign shortcuts for each function - Since 3.1 you have individual menus:
                    http://forums.sketchucation.com/download/file.php?id=63390
                    Maybe I just don't understand the question... ❓ 😕
                    • bagateloB Offline
                      bagatelo
                      A picture is more worth than a thousand words.
                        You want to erase stray edges and merge coplanar faces?
                        Just set the settings in the dialog window. Then after ward you can just use the "Clean with Last Settings" if you quickly want to repeat that cleaning operation.
                          That's and odd error message. It refers to tt_guide_tools.rb...
                          @rspierenburg said:
                          I've removed both the plugin and the TT_lib2 folder and re-installed both
                          Did you download the new version of TT_Lib2 before reinstalling TT_Lib2?
                            rspierenburg
                            Yes, I re-downloaded the latest revision of TT_Lib2 (2.5.3) and Cleanup (3.1.3). Should I try to remove and re-install the TT_Guide tools as well?
                              You could try... I'm not really sure why you get this error message.
                              What OS do you use? Windows?
                              Administrator or User account? UAC on/off?
                                rspierenburg
                                Using Windows Vista Home Premium with administrator access yes. I think it might be a conflict with another plugin perhaps. I'll check it out and let you know what I find out.
                                Rob
                                  rspierenburg
                                  I loved the first iteration of this plugin. I've tried to install the new version and receive this error on startup:
                                  Error Loading File tt_cleanup.rb
                                  undefined method is_windows?' for TT::System:Module Error Loading File tt_guide_tools.rb undefined method is_windows?' for TT::System:Module
                                  I've removed both the plugin and the TT_lib2 folder and re-installed both but no change. Any ideas? I'm really looking forward to getting this plugin to work, you do great work, keep it up.
                                  Thanks in advance,
                                  Rob
                                    rspierenburg
                                    Found out what the problem is...or rather..solution. I guessing the problem has to do with administrative rights somehow. Because if I set the Sketchup 8 Desktop shortcut to 'Run with administrative rights' then there is no error. Not sure what in the system.rb requires administration rights other than what I have but it works for now I guess.
                                    Rob
                                      Rob
                                      There shouldn't be anything. But - Vista and Win7 got something called compatibility mode where Windows place folders in a hidden location elsewhere on the system - though this is not visible to the user. It could be that this caused an older version to be loaded.
                                      When you're in the Plugins folder, do you see a Compatibility Files button in Explorer?
                                        rspierenburg
                                        Actually I do. So what exactly does this other folder do? Does it store older versions of the files that are in it? I've never noticed it before. But now that I see it I noticed there are other plugins that I couldn't find before.
                                          rspierenburg
                                          Yup, that did the trick. I just deleted the TT_Lib2 folder from the 'Compatibility' folder and everything starts up as it should. Thanks for the tip, and the wonderful plugins.
                                          Rob
                                            I'm not very familiar with it - but I've heard some reports on it.
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 48
                                            • 49
                                            • 18 / 49
