    [Plugin] CleanUp
    974 Posts 217 Posters 1.2m Views 217 Watching
      diegog321
      Thank you:
      This is the most essential plugin of all.
      Keep up the good work!
        @3rdeye said:
        Hi TomTom,
        first of all:
        Thank you for this plugin, it´s one of my first time favorites!!!
        Anyway, after upgrading to the last released version (also updated TT Lib to the latest), i got the new cleanup dialog somehow messed up when it pos up - does anybody know how to fix this?
        I'm guessing you are still have IE6 installed? Absolute minimum supported IE is IE7 - but I strongly recommend updating to IE8. (Soon IE9)
          @bagatelo said:
          Sorry, but it's not working: 😳
          undefined method `add_group' for #<Sketchup;;Group;0xf18f5d8>
          > C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_cleanup.rb;969;in `remove_materials'
          > C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_cleanup.rb;967;in `each'
          > C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_cleanup.rb;967;in `remove_materials'
          > C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_cleanup.rb;935;in `merge_similar_materials'
          > C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_cleanup.rb;495;in `cleanup!'
          > C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_cleanup.rb;438;in `show_cleanup_ui'
          > C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb;160;in `call'
          > C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb;160;in `initialize'
          > C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb;143;in `call'
          > C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb;143;in `close'
          > C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb;143;in `initialize'
          I try to clean this component:
          http://sketchup.google.com/3dwarehouse/details?mid=4d0acb2641fa8dff27170042f46719ed&prevstart=0
          But it's not working. 😳
          Ah - you're using SketchUp 6. Seems to be an error in the SU6 spesific code for removing materials. I didn't get around to test that. I'll have a look at it.
          • bagateloB
            bagatelo
            Both my Sketchup and Internet Explorer are Eight!!
            C:/Program Files (x86)/Google/Google SketchUp 8 >>> (eight)
              But you haven't updated to the latest maintenance release, have you? Versions prior to the recent M1 release need to use a workaround to merge materials - which is where the bug lies.
                Version 3.1.3
                • Fixed bug in merge materials for SketchUp version prior to SU8M1.
                • bagateloB
                  bagatelo
                  I updated everything.
                  Do not worry,thomthom. I use the old version. Thanks.
                    What version does About SketchUp say?
                    Did you try CleanUp 3.1.3 which I just released a few minutes ago?
                    • bagateloB
                      bagatelo
                      Yes, Sir.
                        That is not the latest SketchUp version. There is an update to SU8 you are missing.
                        Btw - 3.1.3 is working now, right?
                        • GaieusG
                          I'd really suggest upgrading, Alexandro. There have been some really good improvements!
                          (And when you are at it, you could also update your profile so that bug hunting plugin authors are not confused)
                          • bagateloB
                            bagatelo
                            thomthom: I'm so sorry.
                            I've updated Sketchup now.
                            Now it worked.
                            I'm a fool. Thanks for your patience.
                            • GaieusG
                              I don't think TT would be angry with you (more likely he's glad it works now).
                              But did it (that latest Cleanup version) also work with the previous SU 8 version?
                                No - I'm not angry. But that update is really worth it. Some important fixes in SketchUp.
                                And 3.1.3 should work for pre M1 now.
                                • bagateloB
                                  bagatelo
                                  I tested all the new versions of cleanup with sketchup 8 outdated and did not work. Only when I upgraded to the latest version of sketchup was the plugin cleanup worked well.
                                  Is there something in the working of the plugin which I think could be rethought. That is what concerns processing of edges. Is there a difference between edges that form a face and are coplanar with other faces ("Erase Coplanar Edges") AND edges who are in face without being divided into other faces ("Erase Lonely Edges"). If could be distinguished in this way I can assign keyboard shortcuts for this two situations.
                                    Errors?
                                    You can assign shortcuts for each function - Since 3.1 you have individual menus:
                                    http://forums.sketchucation.com/download/file.php?id=63390
                                    Maybe I just don't understand the question... ❓ 😕
                                    • bagateloB
                                      bagatelo
                                      A picture is more worth than a thousand words.
                                        You want to erase stray edges and merge coplanar faces?
                                        Just set the settings in the dialog window. Then after ward you can just use the "Clean with Last Settings" if you quickly want to repeat that cleaning operation.
                                          That's and odd error message. It refers to tt_guide_tools.rb...
                                          @rspierenburg said:
                                          I've removed both the plugin and the TT_lib2 folder and re-installed both
                                          Did you download the new version of TT_Lib2 before reinstalling TT_Lib2?
                                            rspierenburg
                                            Yes, I re-downloaded the latest revision of TT_Lib2 (2.5.3) and Cleanup (3.1.3). Should I try to remove and re-install the TT_Guide tools as well?
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 48
                                            • 49
                                            • 14 / 49
