    Double cutting component?
    6 Posts 3 Posters 279 Views 3 Watching
    • pmolsonP Offline
      pmolson
      Could one of you explain or point me towards
      an explanation of how to make a window component
      cut both the exterior and interior skins of a wall?
      Attached is a model of a simple wall with the exact type of window I use
      often that I would like to teach to cut both skins.
      Thanks.
      p
      model
      from exterior
      from interior
        You need my 'Hole Punching Tool' which should do exactly what you want...
        http://forums.sketchucation.com/viewtopic.php?p=271170#p271170
        • pmolsonP Offline
          pmolson
          How have I managed for so long without this tool?
          Has anybody told you lately that your a genius?
          You are!
          Thanks.
          If I wanted to give you a small payment in gratitude for this and
          other plug ins I use of yours, how would I go about that?
          Paul
          I would still like to know how to modify a window component to do this
          on its own at time of insertion if that is possible.
          p
            d12dozr
            Paul
            PayPal to info @ revitrev.org πŸ˜‰
            @ TIG: I couldn't find the donation link in my plugins folder like I have before πŸ˜•
            http://goo.gl/f7ooYh
              You are!
              Thanks.
              Paul
              p
              It's not possible to cut more that one face on a component's insertion - the hole-punch is a workable solution...
              It could be possible BUT would need paired back to back components that observers would spot and explode and re-glued to their faces and magically work out where the inner face was, and somehow join them together... the punch-later is just so much easier [even though it's very complex in its own way!]. Remember that you can bulk-punch selected instances and there are all the tools you need to re-punch etc...
              You can always make PayPal.com donations to info @ revitrev.org [squeeze out the 2 spaces - they are added to avoid email-address-leech-bots here]...
              • pmolsonP Offline
                pmolson
                Thanks.
                p
