    Mouse on a Mac (orbiting)
    33 Posts 13 Posters 12.5k Views 13 Watching
      What mouse is she using? The latest Mac mouse doesn't even have a center mouse wheel/button. When I bought my MacBook Pro, I also bought the cheapest wireless Logitech mouse I could find (about $200) and use that instead. I just plugged it in and didn't install the driver and it works perfectly. We replaced the Mac mouse that came with the iMac with a Microsoft USB mouse which also works perfectly and much better than the Mac mouse with the tiny little ball.
      I would suggest to your student that she switch to a PC-type mouse.
      • leedeeteeL Offline
        leedeetee
        I have no idea, d'oh. 😳 It's definitely got a middle button though.
          I'd guess it's the Mac mouse with the little ball. I didn't enjoy that mouse at all.
          http://www.macinthebox.com/images/products/apple mighty mouse.jpg
            leedeetee
            Hmmm, no, tbh, from what I can remember it's a wireless PC style mouse must be more observant.
              I wonder if its a mouse driver issue. I don't install mouse drivers on any computer.
                leedeetee
                Do you know if there's an option on the Mac for changing mouse settings, like there is in control panel > mouse, on windows?
                  There are some basic settings under System Preferences but nothing for assigning center mouse button behavior, at least on my MacBook Pro.
                    leedeetee
                    Ok, Dave. Thanks very much for taking the time to try to help me out.
                      Any time. Good luck.
                      • tbdT Offline
                        tbd
                        if you have MagicMouse you can use BetterTouchTool and have a middle button for orbit setup
                        http://plugins.ro
                          leedeetee
                          Just found out the mouse is a Logitech M505 if that makes any difference to proceedings?
                          http://p.gzhls.at/450578.jpg
                            Next thing to find out is if she installed the Logitech driver software.
                            • jeff hammondJ Offline
                              that's the mouse i use with the laptop and the mmb does work for orbiting if the logitech driver isn't installed (and i don't have it installed)..
                              if she does have it installed, you'll have to go to the logitech control panel (or whatever it's called) in system preferences..
                              you'll want to select the 'custom' option for the middle mouse button then assign it to function as ^⌘LMB (control - command - left mouse button)
                                leedeetee
                                Thanks guys, will give it a go. πŸ˜„
                                • Jean LemireJ Offline
                                  Jean Lemire
                                  Hi folks.
                                  After four years of use, my wireless Mighty Mouse (with the small round roller) started acting badly, with the roller nor working for scroll up. None of the tricks that I knew to clean it works anymore. Except for that problem, this mouse has always been a pleasure to use. I enabled the center roller as the third button in the Mouse Preference Panel and it worked perfectly with SketchUp (SU).
                                  Unable to find a replacement since Apple do not make Wireless Migthy Mouse any more, only wired one and I prefer wireless since it save on desktop clutter, I decided to try the Apple Magic Mouse. It works but, without a third button, it is useless for SU. However, before going to buy the Magic Mouse, I had read about the BetterTouchTools software. I installed it and created a center button (3rd button if you prefer). It works but, since this mouse do not gives a tactile feedback, I need to peek at the mouse to make sure that my index is in its center to be able to use the virtual 3rd button. Also, with SU, it stops working from time to time so, I decided to buy a Logitech 505 wireless mouse with a classic roller. It worked like a charm. At first, I did not install the driver since, it did not required it to work. However, the speed is too great and I need to go to the mouse controp panel to slow it down a little. After a couple of weeks, I discovered that the wheel of this mouse can also be pushed sideway. But, you need to install the Logitech Mouse Driver to enable this feature as well as the use of the two additional buttons on the side of the mouse. I did and I discovered that the mouse reaction, especially with SU is now quite sluggish. You must note that I also have the Magic Trackpad hooked wirelesly on my iMac. I don't know if it may have an effect. So, after fighting for an hour or so, trying to draw with SU, I gave up and removed the Logitech driver. I dont have the sideway click and cannot use the additional buttons but at least, it is usable with SU.
                                  Just ideas.
                                  • jgbJ Offline
                                    jgb
                                    Not sure if this applies to a Mac, but I upgraded my Logitech mouse last year and had the devil of a time getting the wheel down click to work like my previous mouse.
                                    Try this; Open your Logitech mouse settings dialog and redefine the wheel down as "Middle Button".
                                    jgb
                                      Or uninstall the Logitech driver altogether. It isn't needed. The mouse will work just fine without it.
                                      • O Offline
                                        otb designworks
                                        I have a logitech mouse that did not start up with the scroll wheel button working as expected.
                                        I purchased http://plentycom.jp/en/steermouse/ and used it to set my middle button, as well as a slew of other settings. Works perfectly.
                                        Cheers, Chuck
                                        OTB Designworks is on Youtube
                                          Chuck, did you have problems with the Logitech mouse without the logitech driver installed?
                                          • jgbJ Offline
                                            jgb
                                            But only if you have a simple mouse, ie: 2 buttons and a wheel that Windows built-in drivers recognizes.
                                            If you have a complex mouse; like my Logitech MX-600, with 5 additional buttons, Win will not recognize those extra buttons. The Logitech drivers allow you to redefine any of the 10 available buttons & wheel to do pretty much anything you want, as well as read the battery status.
                                            Unfortunately SU still does not recognize any more than the 2 main buttons and the wheel.
                                            jgb
