    [Plugin] TT_Lib²
    310 Posts 66 Posters 479.5k Views 66 Watching
      @pixero said:
      By the way I'm tired of rearrangeing my toolbars once again. How does the save toolbar in SU8 work?
      Poorly.
      View->Toolbars->Save Positions
      View->Toolbars->Restore Positions
      I've found it to not work so well when adding/removing plugins with toolbars...
        Jim
        Thom, have you generated docs for this lib? I appreciate that you are thinking in terms of re-use, and your code is clean and clear. Is this licensed so that other people can use it also?
          I have some docs generated. But the comments are not complete. It's still taking shape and some things will be changed.
          I'll try to make a note on the modules that are WIP and include more examples. If you have questions about particulars just let me know and I can push them up on the update list.
          For the brave, here is the current output: http://www.thomthom.net/software/sketchup/tt_lib2/doc/ (for TT_Lib 2.5 mind you)
          (Anyone knows how to modify YARDs templates so the constant lists will be more compact?)
            Jim
            Guess I could run yard myself... heh.
              Just a preview of one of the GUI gizmos I'm working on.
              [flash=640,385:378bq4x9]http://www.youtube.com/v/hA0H_Txfjd4?fs=1&hl=en_US[/flash:378bq4x9]
              Code to generate the windows:
              # Compatible; SketchUp 7 (PC)
              #             (other versions untested)
              # Thomas Thomassen
              # thomas[at]thomthom[dot]net
              require 'sketchup.rb'
              require 'TT_Lib2/core.rb'
              TT;;Lib.compatible?('2.4.0', 'Inputbox Test')
              module TT;;Plugins;;InputboxTest
                ### CONSTANTS ### --------------------------------------------------------
                VERSION = '1.0.0'
                ### MENU & TOOLBARS ### --------------------------------------------------
                unless file_loaded?( File.basename(__FILE__) )
                  m = TT.menu('Plugins').add_submenu('TT;;GUI')
                  m.add_item('TT;;GUI;;Inputbox')     { self.test_inputbox }
                  m.add_item('TT;;Plugins;;CleanUp')  { self.test_cleanup }
                ### MAIN SCRIPT ### ------------------------------------------------------
                def self.test_inputbox
                  options = {
                    ;title => 'TT;;GUI;;Inputbox',
                    ;pref_key => 'TT;;GUI;;Inputbox',
                    ;modal => true,
                    ;accept_label => 'Save',
                    ;cancel_label => 'Abort'
                  i = TT;;GUI;;Inputbox.new(options)
                  i.add_control( {
                    ;label => 'Hello',
                    ;value => 'World',
                    ;description => 'Lorem ipsum <b>dolor</b> sit amet.',
                  i.add_control( {
                    ;label => 'Checkbox1',
                    ;value => true
                  i.add_control( {
                    ;label => 'Checkbox2',
                    ;value => false
                  i.add_control( {
                    ;label => 'Integer',
                    ;value => 123
                  i.add_control( {
                    ;label => 'Float',
                    ;value => 1.23
                  i.add_control( {
                    ;label => 'Length',
                    ;value => 1.23.m
                  ms = Sketchup.active_model.materials
                  i.add_control( {
                    ;label => 'Dropdown List1',
                    ;value => (ms.current) ? ms.current.display_name ; nil,
                    ;options => ms.map { |m| m.display_name },
                    ;description => 'Unordered ordered.'
                  i.add_control( {
                    ;label => 'Dropdown List2',
                    ;order => 1,
                    ;natrual_order => true,
                    ;description => 'Naturally ordered.'
                  i.add_control( {
                    ;label => 'List1',
                    ;order => -1,
                    ;description => 'Naturally ordered reversed.',
                    ;size => 5
                  i.add_control( {
                    ;label => 'List2',
                    ;value => ms.to_a[0..1].map { |m| m.display_name },
                    ;order => -1,
                    ;description => 'Multiple Selection.',
                    ;size => 5,
                    ;multiple => true
                  i.add_control( {
                    ;label => 'Radioboxes1',
                    ;value => 'Hello World',
                    ;options => ['Hello World', 'Lorem Ipsum', 'Foo Bar'],
                    ;type => TT;;GUI;;Inputbox;;CT_RADIOBOX
                  i.add_control( {
                    ;label => 'Radioboxes2',
                    ;value => 'Monkeys',
                    ;options => ['Cheese', 'Monkeys'],
                  i.prompt { |results|
                    puts 'Results returned;'
                    p results
                    #puts i.get_html
                  def self.test_cleanup
                  options = {
                    ;title => 'TT;;Plugins;;CleanUp',
                    ;pref_key => 'TT;;Plugins;;CleanUp',
                    ;modal => true,
                    ;accept_label => 'CleanUp',
                    ;cancel_label => 'Cancel',
                    ;align => 0.3
                  i.add_control( {
                    ;label => 'Scope',
                    ;value => 'Local',
                    ;options => ['Selected', 'Local', 'Model'],
                    ;type => TT;;GUI;;Inputbox;;CT_RADIOBOX,
                    ;group => 'General'
                  i.add_control( {
                    ;label => 'Validate Results',
                    ;value => true,
                    ;group => 'General'
                  i.add_control( {
                    ;label => 'Merge Coplanar Faces',
                    ;value => true,
                    ;group => 'Coplanar Faces'
                  i.add_control( {
                    ;label => 'Ignore Normals',
                    ;value => false,
                  i.add_control( {
                    ;label => 'Ignore Materials',
                    ;value => false,
                  i.add_control( {
                    ;label => 'Ignore UV',
                    ;value => true,
                  i.add_control( {
                    ;label => 'Remove Duplicate Faces',
                    ;value => false,
                    ;group => 'Faces'
                  i.add_control( {
                    ;label => 'Repair Split Edges',
                    ;value => true,
                    ;group => 'Edges'
                  i.add_control( {
                    ;label => 'Remove Lonely Edges',
                    ;value => true,
                    ;group => 'Edges'
                  i.add_control( {
                    ;label => 'Remove Edge Materials',
                    ;value => false,
                    ;group => 'Edges'
                  i.add_control( {
                    ;label => 'Smooth Edges by Angle',
                    ;value => 0.0,
                    ;group => 'Edges'
                    p results
                    #puts i.get_html
                ### DEBUG ### ------------------------------------------------------------
                def self.reload
                  TT;;Lib.reload
                  load __FILE__
              end # module
              file_loaded( File.basename(__FILE__) )
              Also thinking of adding more wrappers to create windows entirely from Ruby - buttons, lists, dropdowns etc...
              input_test.rb
                Jim
                This approach will win. 👍
                  When I made Vertex Tools I had a similar system for the toolbar system. A set of classes that acted as wrappers for the controls. The main classes where Container and Control - they would have most of the code. From there it was easier to create sub-classes like toolbars and buttons. I then had a very nice abstract layer where I created a toolbar class - where I added Button objects.
                  Complex systems though - but I hope to have a base system by the new year.
                    jeffschaid01
                    Hello,
                    I'm having a problem with the program crashing at 49% when exporting as a vrml. I've imported my bmp image, sized, indexed points and generated the mesh. Any suggestions?
                    Thanks,
                    Jeff
                      @jeffschaid01 said:
                      Hello,
                      Thanks,
                      Jeff
                      Are you referring to Bitmap to Mesh?
                      • GaieusG
                        Yes, he is.
                          Version 2.5.1
                          • Fixes Webdialog issues with IE7
                            Version 2.5.2
                            Important bugfix!
                            • Fixed bug in the method that repair broken edges.
                              Version 2.5.3
                              Important bugfix!
                              • Fixed again repair broken edges.
                              • GaieusG
                                TT, I got this message while overwriting the old library (meaning that the file I marked is write-protected). When I wanted to overwrite anyway, it wanted a password so I could not.
                                Is it an issue if I do not update that particular file?
                                  It's not write protected on my computer. Nor in the zip file.
                                  I have no idea what this can be. I've never seen Windows ask for that. Are you using some third party applications to manage files?
                                  What did you use to extract the files? Did you extract directly over the files?
                                  What if you delete, then extract?
                                  • GaieusG
                                    It's simply Win XP "extract (or open?) all files" when I enter the zip archive (yes, I was simply overwriting the existing install). Here is the dialog that asks for the password:
                                    I then tried to delete the file but it said omething was using it. It was obviously SU as when I closed it, I could delete it and install the library correctly. This made me think however so I tried to reinstall it (now as it had been installed the file again) and with the SU window closed, it allowed me to.
                                    So maybe a line in the front post to "close SU before installing" would be useful (people need to restart SU anyway).
                                      Csaba, I got a similar message about that .so file when I extracted the ZIP file to the Plugins folder. SketchUp was open. So I closed SketchUp and tried again. It worked fine then. I wonder if that file is write protected when SU is open and the file is in use.
                                        I sounds like SketchUp keeps a lock on the file when it's loaded. Probably because it's binary code instead of interpreted Ruby.
                                          rasstappen
                                          Sweet thanks-
                                          Rasstappen
                                            Version 2.5.4
                                            This update requires that you also update:
                                            • Edge Tools ( 2.0.3 )
                                            • Plan Tools ( 1.2.2 )
                                            • CleanUp ( 3.1.4 )
                                            • 15
                                            • 16
                                            • 2 / 16
