    WIP - Officers Tactical Battlepod (Glaug)
    43 Posts 12 Posters 11.7k Views 12 Watching
    • StinkieS
      Stinkie
      @jason_maranto said:
      I am working on a "Google Sketchup to Maxwell Render Workflow" series, which is the culmination of my last several series (...)
      Thanks for the info. Whenever I get I back into Maxwell, I'll make sure to check your tutorials out. They look quite interesting.
      • david_hD
        david_h
        Man. .. it is so incredible what some of you guys can do with SU and how far you guys push the envelope. I've been using it for years, and I have still have trouble with hip roofs and windows cutting holes! πŸ’š
        • jason_marantoJ
          jason_maranto
          Thank-you, but don't feel bad -- this is what I do... if I had to do any real architectural work I would be exposed as a fraud very quickly πŸ˜‰
          Here's the leg components more or less done -- the dome shape at the bottom is the beginning of the feet assembly which is next.
          Best,
          Jason.
            Hi Jason,
            These are great πŸ‘
            Is that BG part of maxwell? It's kinda SciFi, I like it
            • L
              liam887
              downloading 30 day maxell trial now apparently you can get it for Β£200 if you are a student and after seeing silver shadows blackhawk in it worth a try...
              VISIT MY ONLINE GALLERY
              • jason_marantoJ
                jason_maranto
                Rich, yep that is the default Maxwell "Physical Sky" straight out of the plugin -- you can customize that to achieve many differnt atmospheric effects but I'm not to the point yet where I am ready to worry about that... I'm getting close though πŸ˜„
                Liam, I'm sure with your texturing skills you will achieve fantastic results very quickly. The key with Maxwell is the materials and on that front you can watch a bunch of my Maxwell videos for free either on the VTC site linked above or on the Maxwell THINK! site (which is a tutorial repository) here:
                http://think.maxwellrender.com/first10steps.php?categoryFS=21
                I also did a very quick(about an hour) intro to the Sketchup Plugin here:
                http://think.maxwellrender.com/first10steps.php?categoryFS=15
                They should help you get up and running very quickly.
                Best,
                Jason.
                • jason_marantoJ
                  jason_maranto
                  Here's the legs with feet -- I had some cooler looking feet made that were a bit more faithful to the design but they could not achieve the articulation I wanted so I took some liberties to make them a bit more functional for moving. I may still do some tweaking but at this point I could consider them done...
                  I've rigged the legs to get them ready to do a bit of DC animation based posing functionality (just like I built into the arms). This will allow me to "pose" each leg individually with just a click -- a very handy thing when you have a army of these guys πŸ˜‰
                  Best,
                  Jason.
                  • jason_marantoJ
                    jason_maranto
                    I'm still working on this between some other things -- here's all the parts together, at this point it is mostly little details and cleanup (as far as modelling).
                    Best,
                    Jason.
                      Yummy πŸ‘
                      Any chance of some SU output?
                      • jason_marantoJ
                        jason_maranto
                        Sure Rich, here's a shot from Sketchup... I'll make the model available to anybody who wants it after I'm done.
                        Best,
                        Jason.
                          Thanks Jason πŸ‘
                          I always like to see SU output on SCF. It deserves be shown IMO.
                          • jason_marantoJ
                            jason_maranto
                            I'm playing with the idea of using some sort of metallic finish as the base for most of this -- as opposed to the standard military matte-finish drab paint... the basic idea was to "sex" it up a bit and show off the curves a bit (the same reason they paint cars in metallic flake paint).
                            Any thoughts?
                            Best,
                            Jason.
                            • K
                              Khai
                              ooh. add some panel lines for "Factory Finish" .... or like that put it on a Desk as a toy πŸ˜„
                              • jason_marantoJ
                                jason_maranto
                                Thank-you for the feedback β˜€ for context here's a render with a matte type paint finish.
                                Best,
                                Jason.
                                • numbthumbN
                                  numbthumb
                                  Excellent work, jason! πŸ‘
                                  Both renders are very good, but I like the second more. Especially if you could give him some battle worn/weathered look. Once again, excellent work.
                                  Comfortably numb...
                                  • jason_marantoJ
                                    jason_maranto
                                    Thanks for the feedback -- I've been agonizing over which pose I should use... here's one of the better ones I think. Agree or Disagree?
                                    Best,
                                    Jason.
                                    • numbthumbN
                                      numbthumb
                                      I agree. πŸ˜„ πŸ‘
                                      But I would like to see it from a different angle - from an inferior position, more like "worm's-eye view".
                                      Comfortably numb...
                                      • jason_marantoJ
                                        jason_maranto
                                        This isn't exactly a worms-eye view because when we get too small the perspective gets a bit crazy (this thing is about 150 ft tall)... but here is a more aggressive camera angle.
                                        Best,
                                        Jason.
                                        • numbthumbN
                                          numbthumb
                                          ThatΒ΄s more like it! πŸ‘
                                          Comfortably numb...
                                          • jason_marantoJ
                                            jason_maranto
                                            I found a nice free HDRI of the milky way that I used since My ultimate goal is a space battle I thought it appropriate.
                                            Best,
                                            Jason.
                                            • 2 / 3
