    How to restore a drawing in SU pro 8
    8 Posts 3 Posters 483 Views 3 Watching
    • E Offline
      Eshita13
      I was working on my drawing in SU pro 8, and suddenly the drawing just disappeared. I don't know what just happened. I could only see a blank new page there. I thought if i saved that page and reopen it i might find my drawing but it was useless. I only can see a blank new page, my drawing is not in there. What should i do now? Please help me. I need that drawing for my project and i have no time to do it again. Thanks in advance.
        If you have autosave on it should have saved a backup (.skb) in your default save location.
        Windows > Preferences > Files
        • E Offline
          Eshita13
          I have found an autosave file but that file has little contents of my actual drawing (i mean the backup file is in earlier stage). And now whatever i draw in SU it disappears. Every time i move my mouse each portion of my design disappears. Why is it happening?
            Do you mean when you orbit it vanishes? Zoom to Extenets (Shift+z) and see if it helps. How large is your drawing?
              If you are working on something really large (say 1 mile long) SketchUp has problems displaying the geometry. It's called 'Clipping'. It's very common and nothing to worry about.
              Where will i send the invoice for my services? πŸ˜‰
              • E Offline
                Eshita13
                Thank you very much. It's worked. It really has. Thanks you have saved me. Will you do me one last favor? Can you explain me why it happened? Again thank you.
                • E Offline
                  Eshita13
                  you can send it right here πŸ˜† Anyway thanks again. Hope i will repay it someday. β˜€
                  • honoluludesktopH Offline
                    honoluludesktop
                    Whenever I run into a problem, I "save as". That way the original file is preserved up to the last "save".
