    [Plugin] UVprojection
    27 Posts 20 Posters 31.4k Views 20 Watching
      You solved the perpendicular problem?? how?
        Whooah! That's a clever tool, Congrats and thanks
        • PixeroP Offline
          Pixero
          Look under: def planar_map.
          I think I've explained it fairly detailed. If you need more info, PM me.
          I'm sure it can be optimized. πŸ˜’
          • PixeroP Offline
            Pixero
            I must also take the opportunity to thank both TIG and Thomthom for their help, and Whaat for his UVtools script that this script is based on.
            • V Offline
              Vicspa
              Haven't tried it yet but it sounds great, thanks Pixero
              • Chris FullmerC Offline
                I thought it was a UV Protection - sunblock. I suppose it'll still be useful anyhoww πŸ˜„
                Looks great Jan, good job!
                • honoluludesktopH Offline
                  honoluludesktop
                  Jan, Thanks, very clever.
                  • V Offline
                    vidy
                    thanks jan.. another good plugin on texturing πŸ˜„
                    one request, is it possible if its added rotate function to rotate the texture? actually we can still able to using native SU texture editing to rotate it though, but probably if its all in one place it will come in handy.. πŸŽ‰
                    thanks,
                    still so much to learn..
                      rv1974
                      Thank you Pixero!
                      Could you add 'lock bitmap propostions' feature?
                      • KrisidiousK Offline
                        Krisidious
                        sweet...
                        By: Kristoff Rand
                          RHPLUS
                          Sketchup is the perfect tool for modeling, I use it all the time in my work, but here is one main disadvantage that I can't fix UV textured meshes on vertex of triangle faces. Projected textures let me to modify shapes but UV-textures are spreading during modification.
                          I have a question to all Ruby writers. Is this possible to make a plugin which make textures fix on vertex?
                          Thank You for all your great work. With Your help, Sketchup becomes the best professional tool for architectural modeling.
                            Check out the UV Memory feature of my UV Toolkit: http://forums.sketchucation.com/viewtopic.php?f=323&t=18992&p=155759
                            (New version coming shortly)
                              RHPLUS
                              Thank You thomthom for your quick reply to my problem. I had checked this new UV toolkit, but I'm affraid that it works only with projected textures. I think rather about textures wrapped around irregular shapes (not projected) for example human models.
                              I know that this is difficult, but another 3d applications like Lightwave, Maya, MAX, Polygon Cruntcher etc. make this, so I believe that it's possible in Sketchup.
                              (sorry for my bad English)
                              • N Offline
                                notareal
                                Thanks. More UV tools the better - maybe google get's the message in some point - proper UV tools are really needed for SU.
                                  I should work with any mapping. Can you post an example of what gives you unexpected results in the UV Toolkit thread?
                                  • H Offline
                                    hgdn
                                    Thanks so much for giving a wonderful plugin, it is so great for terrain work and done so fast! Hope you or any one can figure out of how to have uv texture works on spherical or odd curvy shapes as well!
                                      indeed. Have a look at this tutorial topic where I used wrapped textures exclusively (then later on, cylindrical projection on a cylinder)
                                      and sorry Jan for littering your topic.
                                        RHPLUS
                                        Thank You Thomas & Csaba, I had check out one more time and now I know that the mesh had to be selected before chosing both commands: Remember & Restore.
                                        This is wonderful plugin - Thomas - U R Great!!
                                          RHPLUS
                                          Now, when maps are fixed on a human model, the next step should be rigging and weightmappng to make modifications easier.
                                            Ben Ritter
                                            Jan, thank you very much!
