    1.3k Posts 299 Posters 2.5m Views 297 Watching
      I knew you were going to type that. πŸ˜„ πŸ˜†
        bowlr
        Thanks for pointing this out, much appreciated
        • fredo6F Offline
          @mitcorb said:
          Quote:"Also, for me, it is better if users can move to latest versions because it is easier to support."
          Fredo endquote
          I agree in principle on this statement. However, I must consider more than just upgrading to SU8. My hardware is going beyond outdated, and the logistics of migrating what I have accumulated is not trivial for me. πŸ˜„
          As Dave relevantly mentioned. I was talking about my Plugins. If you use the latest version of LibFredo6 and of the scripts, it is easier for me to reproduce possible bugs and issues.
          For SU, I try as much as possible to have them working with most SU versions (most work in SU 6 and even SU5).
            Pherim
            I just successfully used Loft along Path for the first time! (That means I used it for the first time and it worked immediately, not that I have tried it several times without success)
            It is simply awesome. This has to be one of the best plugins ever!
              make.GQ.china
              Great! A useful plug-in
              • jason_marantoJ Offline
                jason_maranto
                Hey Fredo, I have a file here with some geometry that gave me a hard time -- and I also have some examples of how I got it to work to a tolerable level but certainly not what I had envisioned.
                I'm sure user error was responsible to a degree but I though I'd share it with you if it helps debug at all.
                Best,
                Jason.
                loft issue.skp
                • fredo6F Offline
                  Best,
                  Jason.
                  Jason,
                  Thanks. This is a good example which shows some limitations of Curviloft (and it's not your errors at all!).
                  You probably have to do it in 2 parts, as you did. First part should be with the option 'Line junction' and second part with Cubic Bezier, but you should simply skip the last profile before the rear face of the hull.
                  Alternatively, you can take some inspiration of what it could give with the two other methods: Skinning and Loft along Path.
                  In any case, I would suggest that you redraw the long profile to show more continuity at the junction(maybe with a single piece of spline).
                  loft issue - Fredio.skp
                    jason_maranto
                    Thank-you again... that was very helpful and led me in a different direction that worked much better.
                    I have another file for you -- I suspect this is asking for too much πŸ˜‰
                    Best,
                    Jason.
                    Interesting_loft.skp
                    • fredo6F Offline
                      Jason,
                      This is definitely too much for Curviloft. The only way to achieve it on this kind of model is to draw intermediate profiles and use Skinning.
                      Indeed, you have to figure out how these intermediate profiles should be. But anyway, there are so many solutions to skin your shape that any program would need some guidance.
                        jason_maranto
                        Thanks Fredo, this is all magic to me -- so many of the things Curviloft can do didn't seem possible in Sketchup to me just a few weeks ago... I might have gotten a bit carried away by your wizardry πŸ’š
                        I did get it to skin in a few configurations but nothing I was completely satisfied with.
                        BTW I have noticed on my system that has an ATI Firepro (workstation video card) the vertex matching function is very temperamental -- when I switch to my system that uses a Nvidia Quadro it is very smooth.
                        Best,
                        Jason.
                          Visual glitches?
                          If so - screenshots?
                            jason_maranto
                            I'll record a video example when I get to the studio.
                            Best,
                            Jason.
                              ale 3D
                              hi! your plugs are really more than better and usefull πŸ˜‰ many THANX!
                                jason_maranto
                                Here's a video showing the issue:
                                Took down the link to conserve bandwidth
                                Best,
                                Jason.
                                • W Offline
                                  wfiinch
                                  Just installed Curviloft into my SU8 and am excited as all hell about the possibilities!
                                  One question: I need to apply a directional material (wood grain) to the new surface. It applies the pattern to each individual facet, sometimes in the wrong direction. How do I change the pattern direction on a Curviloft surface?
                                  Okay another question: what exactly is the Sketchup structure of a curviloft surface? Can I explode it?
                                  Thanks!...and good job on the plugin!
                                    It comes in as a group and yes, you can explode it. Turn on hidden geometry (View menu) to se the structure.
                                    As for texturing it, you need to apply the texture to the surface itself (groups with curved geometry cannot be textured from outside without the texture being applied chaotically). Even on the surface, most probably you need to turn on hidden geometry, apply the texture on one facet; position it then sample and apply on the other facets. Depending on the complexity of the shape, it may take a while - or you can use some UV mapping tool for it.
                                    • fredo6F Offline
                                      By the way, I normally fixed this issue of coplanar contours on the horizontal plane in Curviloft 1.1.
                                      This was signaled by Pilou with a workaround by Diego-Rodriguez
                                        tulacong
                                        thank goodluck
                                        • EscapeArtistE Offline
                                          EscapeArtist
                                          Fredo,
                                          I don't know if this has already been discussed, but there seems to be an issue with "loft junctions following two paths". I create a shape using bezier curves and then convert them to polyline dividers. The script does a really nice job making the overall shape, the problem is along the seam where the profiles meet. It may be due to a mismatch in the number of segments in the edges from one side to the other, but Curviloft creates extra faces that are "folded" into the geometry and are essentially invisible until one goes in and starts moving verts around. The cause a visible seam to show up when shaded smooth. The only solution I know of is to go through and find each face and reconnect/rebuild each edge and face to remove them. Any suggestions on how to better avoid this extra work? Is it as bug or simply an issue with my modeling?
                                          The seam is visible here
                                          Grabbing and moving a vertex on the seam reveals reversed faces that are otherwise not visible.
                                          Thanks for all your hard work!
                                          • fredo6F Offline
                                            @escapeartist said:
                                            Fredo,
                                            Would have the model so that I can have a look.
                                            This seems strange, but Curviloft algorithms have some shortcuts for performance reasons which may explain a few issues like this one.
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 65
                                            • 66
                                            • 20 / 66
