    Model "looks" solid but Sketchup says otherwise?
    4 Posts 3 Posters 6.2k Views 3 Watching
      Panic Button
      Hello there!
      I'm a bit new to Sketchup, however I have been toying around with it.
      My question is that my model "looks solid" , however when I try to use the Solid tools (such as Intersect, Trim, etc), it says it cannot be done as one of the things I'm trying to intersect it with is not a solid. It also does not tell me the volume.
      I have used the Solid Inspector tool, and see red/yellow lines, yet deleting the red and yellow lines ruins the model.
      I will use the finished model with Ponoko for 3D printing, hence the need for it to be "solid".
      Any help? πŸ˜„
      The model I have made is attached to this post. But, please ignore the small little shape (that one DOES have a volume, however.)
      Panic Button Model.skp
        Your model is 'quite small' with may small facets...
        Both SUp and OpenGL have a limitation on very small [and very large] facet sizes.
        They can 'exist' when scaled down later... BUT they cannot be 'made' initially.
        Anything with a side <~0.1mm will fail.
        I suspect that that the form you made has a tiny hole in it, so it's not reported as solid!
        Try remaking it x10 or x100 bigger and then scaling it down to suit - hopefully, it will then keep its facets and be regarded as 'solid'............
          I had a look at your model. In this case I think the problem lies with the edge between the rim structure and the body. See in the green rectangle. If you pull the large flat face back a few mm, I think you'll find it becomes solid. You'll have to delete some interior faces that will be created around that rim, too.
          http://farm6.static.flickr.com/5215/5386765195_4354b75837_z.jpg
          Of course this thing wouldn't work in reality as currently drawn. That rim wouldn't be attached to the rest.
            Dave is right.
            Volumes that overlap and share a common 'internal' face are not regarded as 'solid'.Capture3.PNG
            Volumes that overlap but have no internal faces [here they were removed] are 'solid'.Capture4.PNG
