    Tricky Twist
    28 Posts 13 Posters 3.1k Views 13 Watching
    • soloS Offline
      Fredoscale, pretty simple to use.
      http://img213.imageshack.us/img213/4135/capture46.gif
        JicJac
        Wow!
        *checks out Fredoscale....
        *begins plugin download
        From a quick glance at your presentation (graphic), it looks like Fredoscale uses the concept presented by Jim and automates it (the step-by-step process).
        I believe you have offered the ultimate solution.
        My hat is off,
        JJ
        • ely862meE Offline
          ely862me
          Hmm..didn't even knew that Fredo's scale has that ability..
          Anyway,the transition between the twist and the straight bar it's a bit odd.
          With a bit more work u can achieve this result.With some arcs and Curviloft it came out pretty well.
          Elisei (sketchupper)
          Come and See EliseiDesign
            JicJac
            Amazing. Perfecto. It's a lot for me (noob/novice) to grasp. Now I have two plugins to learn. Will the learning never end?
            Thank to all,
            JJ
            • ely862meE Offline
              ely862me
              Learning never ends.
              Twisted metall stripe by EliseiDesign.skp
                JicJac
                Ah! Very clever. This looks like the type of solution I would come up with during my trial and error process. I understand (thanks to the great instructional presentation you prepared) the concept. When I have time, I'll give this a solution a try and let you know how it goes.
                JJ
                • HumpmetwiceH Offline
                  Humpmetwice
                  Here is my attempt I tried the same technique as Solo but looks like his came out a lot better!
                  I was wondering Solo did you twist it all at once or did you do it in segments because I tried doing it all at once and didn't look right.Tricky Twist.png
                  Tricky Twist.skp
                    JicJac
                    Are the plugins exclusive to MAC? ~ I'm running a PC.
                    I "think" I followed the instructions.....
                    http://www.3d-documents.com/images/Plugins.png
                    but I get this error message:
                    Error Loading File ZLoader__
                    no such file to load -- LibFredo6.rb
                    Error Loading File ZLoader__FredoScale.rb
                    It looks to me like a "Lib" file is needed?
                    I don't expect anyone to spend their time and talent troubleshooting for me. I suppose there is another forum section for these matters. But if I can help someone else down the line by pointing out a problem I'm experiencing, it's a good thing.
                    JJ
                    BTW, Thanks humpmetwice for your elegant contribution. I think this was a fun exercise for all.
                    • jeff hammondJ Offline
                      ha.. no. that almost never happens.
                      you're missing the libFredo files.. get them here:
                      http://forums.sketchucation.com/viewtopic.php?t=17947
                        JicJac
                        Woot! Thanks Jeff. I have the Scale and Round Corner plugins now working.
                        I'll get the hang of it yet.
                        Thanks for helping me solve this issue,
                        JJ
                        • fuzzionF Offline
                          fuzzion
                          Industrial design without Fredoscale is like trying to ride a bike
                          without the wheels πŸ˜›
                          "Only the dead have seen the end of war" - Plato
                          • ArcA Offline
                            Arc
                            You can use Curviloft plugin make this directly.
                            • jarynzlesaJ Offline
                              jarynzlesa
                              Nice work boys πŸ‘ .
                              One question. Is any chance to make a radius on the edges?
                              http://www.vizualizaceschodiste.mypage.cz/
                              • fuzzionF Offline
                                fuzzion
                                If you mean something like a rounded edge,chamber etc......use round corner plugin. You could also use the follow me
                                tool but get ready to kick a dustbin whilst banging your head against a wall πŸ˜›
                                • ely862meE Offline
                                  ely862me
                                  well done ..very nice .. very fast
                                  Learning never ends!!
                                    JicJac
                                    Fuzzion,
                                    I believe ShetchUp is currently primarily used for architectural projects. I can certainly see where it's a big plus for industrial designers. The styles must come in real handy for you. There are probably 100 architects for every 1 industrial designers. I am a technical illustrator specializing in patent drawings. I only use SketchUp in about 2% of my projects. I expect it to climb to around 6-8%. I also use other products such as Corel Designer X5, QuadriSpace, SolidWorks, Adobe Illustrator, etc. The more "mechanical" features (plugins and functions) available in SketchUp, the more illustrators and industrial designers will be attracted. These opinions (and knee-jerk statistics) are my own guestimations.
                                    JJ
                                    • BoxB Offline
                                      Simple, just start with your flat bar having radius corners and everything flows from there.
                                        Jim
                                        Does the patent office accept 3d models? If not, wht not?
                                          JicJac
                                          Jim, No. The patent office (USPTO) requirements are very traditional (archaic). I've been in the trade for more than 40 years. My tools have changed from pencil, pen, ink, templates, 2 ply Strathmore Bristol Board, etc. to 100% digital. The final deliverables continue to look old school. If you were to patent a battle ship, all the drawings would need to fit on 8 1/2 X 11 or A4 paper (many sheets of course). Reason? Tradition and consistency I suppose. Only in the past few years have I been able to use gray scale to any extent. For an attorney to submit color renderings is a whole separate rigmarole. For the most part, the attorneys quiver and yield when an examiner presents drawing complaints. You would not believe how difficult it is to respond to and comply with an examiner's complaint when they get focused on minutia. It's a great trade though. I am self-employed, work from my home/office/studio. The overhead is minimal and pulling down 6 figures is very realistic. For these conditions, I'd draw on a shovel blade with charcoal if that's all they'll accept.
                                          I mention these examples (above) to help demonstrate how far off 3D models seem to be. No sense in arguing the sense of using 3D. The USPTO stores the images in TIFF format (go figure). To view patents online (a stride in technology), you need a TIFF viewer.
                                          Seems like the USPTO is shooting for the lowest common denominator. This makes sense if a level playing field is the objective. After all, it is the government and must be equal to all.
                                          My thoughts and observations,
                                          JJ
                                          • fuzzionF Offline
                                            fuzzion
                                            JJ
                                            Patent drawings must follow the standards provided by the USPTO, including line thickness, the material textures,etc. They are not up
                                            for negotiation with the USPTO.
                                            Part of my research thesis was on Patent Examination. The thing here is that the USPTO wants to keep the same standard of patent drawings
                                            so that disputes are not from the style of drawings but rather from the claims of the invention.
                                            Patent law is very concerned with Claims. It is not really hard to draft claims, but for non lawyers, i would suggest grabbing a patent attorney if you believe you need money and that your invention is worth more than $50,0000. Prior to that, one should conduct his or her own
                                            patent search remembering that the USPTO system works on classification of patents, so best to find your group and search.They start with electrical,mech and chem. They dont always class it right (UPSTO examiners are like monkeys and get many things wrong)
                                            In my opinion, the Patent system is dead for small and medium sized enterprises. Yes , there is now the class of 'innovation patents' but they too have severe limitations. The patent system is geared towards litigation and those with deep pockets. Hence why I believe all my product ideas are free and up for grabs.
                                            Idea's should be shared not monopolised and someday in the future, we will all realise this, even Google πŸ˜„
                                            • 2 / 2
