    Panoramic render from Thea
    extensions
    11 Posts 5 Posters 2.8k Views 5 Watching
    • massimoM Offline
      massimo Moderator
      @simon said:
      I haven't found such a choice in Thea
      Just select a camera then in the Content panel go to Properties-->Lens-->Projection and choose Spherical in the menu on the right.
      Moderator edit: split from this topic:
      http://forums.sketchucation.com/viewtopic.php?f=81&t=33722&p=302524#p302524
      • N Offline
        notareal
        @simon le bon said:
        the spherical image is made in Twilight,
        1. Set Camera type to Spherical
          I haven't found such a choice in Thea. What is the focal length for a Spherical image? In Thea we can go to 1mm!!
        ++simon
        It's there... First select the camera, then under Content Properties -tab, Change Lens>Projection to Spherical. It's good to use 2:1 aspectration for spherical images.
        Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
          Here is another one - Thea (and a different panorama software):
          http://www.gaieus.hu/TheaPanorama/Karmelita.swf
          • simon le bonS Offline
            simon le bon
            (Following a thread referencing to a way to achieve panoramas with Twilight)
            http://i274.photobucket.com/albums/jj245/Spendauballet/TheaRender/Spherical.jpg
            Excellent! thank you Massimo
            *s
              simon le bon
              Well-done Dear Gaieus,
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thGaieus_Karmelita.jpg
              @gaieus said:
              Simon, if you don't mind, I split the posts about the Thea panoramas off.
              (This remark from Gaieus is referencing to a Fletch thread:A Day at the Museum (Natural History Museum - London))
              Good! Dear Gaieus,
              this way we can talk about panoramas, without bumping to much the beautiful work of our nice fellow (here and in KerkyThea, Twilight and TheaRender forums), Fletch.
              My links about how make panoramas pictures: (haven't yet tested nothing but big search for the best free stuff)
              Three tools can be used together(successively)
              Autopano-SIFTit will automatically find points of correspondence between following pictures and giving information to Hugin.
              Hugin will retrieve this information, will adjust accurately these points, will make perspective corrections.
              Enblend will look to refine the seams between images.
              To make pano from SketchUp:
              cubicpanoout by J. Wehby
              ref:Who knows a 3D Panorama freeware prog. (virtual tour) ?
              and may be to use with?:
              PanoCube: a utility for creating QuickTime cubic movies from equirectangular panoramas.
              To be followed, 😉 simon.
                That's an old model I made when I had not even used SU for half a year... 😳
                I will make some more panos when I finish with some of my current projects.
                As for rendering them, you always need to take it into consideration that you can only see about 1/3 (or even less) of the panorama at a time - and there is also zooming to the details. So the bigger the panorama, the better it is.
                Equirectangular panoramas (like what Fletch made or this one I lined) always have to have a 2:1 aspect ratio (just like spherical background images). So it is sometimes better to export a cubic panorama because then you can go with higher resolution per image and the result will be "super high". Also, if you have a look at the top and bottom of my panorama above, you can see that it is distorted at the "poles". This is the panorama software but it does not do it with cubic panoramas.
                  simon le bon
                  👍 nice intro
                  This is a new concept for me.
                  Here a first link found to explain it:
                  Panottools Wiki/Equirectangular
                  And I can't resist to put a set of links coming from Cambridge 😎
                  http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/cambridge.jpg
                  Photo Stitching Digital Panoramas, Part 1: Overview & Capture
                  Photo Stitching Digital Panoramas, Part 2: Using Stitching Software
                  Photo Stitching Digital Panoramas: Image Projections -> Equirectangular panoramas
                  😉 simon
                    Interesting read there, Simon!
                    (As usual, if you become interested in something, you go after every detail of the issue!)
                    • daleD Offline
                      dale
                      Wow, thanks Simon (again)
                      There is a set of really interesting calculators on the bottom of http://www.cambridgeincolour.com/tutorials/image-projections.htm.
                      Check them out as they could be of use.
                      (Gaieus can you add an always follow Simon's posts button to the forum? 😄 )
                        simon le bon
                        Dear Dale, 😄 😳...
                        In fact I hadn't paid so much attention to the calculators but you're right they are great!
                        And also have you noticed the simple and nice clickable reminder on the top about the various types of projection:
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/2011-01-21_205758.jpg
                        ++Simon.
                        • daleD Offline
                          dale
                          No Simon, I saw them but didn't realize they were interactive. This is a brilliant website. 👍
