    Public Beta for Obj, SolidWorks, STEP, and FBX importers
    76 Posts 19 Posters 21.8k Views 19 Watching
      Mra
      Is there a possibility that there can be an FBX plugin that exports out of SketchUp and replace the current default exporter?
      The default FBX exporter by Google is actually a couple of years out of date and very old. I think current version is FBX 2011.3, wheraes SketchUP uses FBX 6.1! Thanks
        ashraf
        Sure we can do that,
        We can add a new FBX exporter for SketchUp, this should be available soon.
          Mra
          Sounds good ashraf, thank you.
            ashraf
            Your request was fulfilled.
            We have FBX 2011 and OBJ exporters ready for SketchUp 7, 7.1 and 8.
            The plugins should work on Windows with the free and pro versions.
            FBX exporter can be found at
            http://www.simlab-soft.com/3d-plugins/FBX_Exporter_From_Sketchup-main.aspx
            OBJ exporter can be found at
            http://www.simlab-soft.com/3d-plugins/OBJ_Exporter_From_Sketchup-main.aspx
            Cheers.
            Ashraf
              Updates - sweet.
              I submitted some reports of some models that took an extremely long time to import - some never seemed to complete. Any changes in this release that would address that?
                ashraf
                The update you are looking for, should be available in January. We invested time in handling instances in the SketchUp files, which can be found extensively in Revit models, this update should be ready in January.
                The last note was about two new Exporters for (FBX and OBJ)
                Those exporters can serve a user who wants to use SketchUp models in other applications that do not have native SketchUp import capabilities
                  Oh - exporters - didn't notice that! 😳
                  I'll wait for the January release of the importer. πŸ˜„
                    Mra
                    Hi ashraf,
                    I have to thank you for the very quick response, truly appreciated. However I have to be honest. I have requested a trial licence for the FBX exporter but have noted a few pros and cons over the default FBX editor. I am importing straight into Maya.
                    Simlab Pros:
                    • Imports Sketchup's scenes and successfully converts into Maya Cameras
                    • Textures are saved into the FBX file
                    • Handles materials much better than the default except there was an instance where one material was duplicated about 100 times
                    Default FBX Pros:
                    • Groups objects as groups in Maya rather than using Maya locaters
                    • Seems to preserve geometry better
                    • Hidden geometry in Sketchup is completely discarded
                    Default and Simlab FBX Cons:
                    • FBX 2011 supports instances but neither plugins seem to preserve this on import
                    • No layers support
                    Currently I appreciate the dev work put into this but feel I cannot justify the price as I prefer the Geometry outputed by the default FBX converter even if it is an older version and has a few limitations. I think geometry preservation is a must, I found the same problem happened with the Sketchup to Maya converter too where all geo was triangulated. I post this in the best possible intentions. πŸ˜„
                      ashraf
                      Thanks for the great feedback, We will work on addressing those issues in the next update.
                      The next update will have a better handling o instances.
                        Yay!
                          Mra
                          I got an email today about an update, is there possibility to get a changelog? I'm still interested in the instances/components in FBX and the ability to not triangulate the mesh. Thanks.
                          • 4 / 4
