    Public Beta for Obj, SolidWorks, STEP, and FBX importers
    76 Posts 19 Posters 24.0k Views 19 Watching
      ashraf
      Thanks for the great testing and feedback from all the beta testers, the plugins were released today, and the work on the first update release to incorporate the feedback and suggestions we received had already started.
      In this release SimLab added progress bar to inform the user that importers are working, added support for OBJ files with negative index values, and updated the plugins to work with SketchUp 8.
      The plugins are now supported to work with SketchUp 8, 7.1 and 7
      • 3 Offline
        3dsketchupper
        FBX import to sketchup failed? fbx was exported from Revit.
        Revit to sketchup file size approx.20mg
        One thing that we are interested with this plugin is to import revit textures into sketchup.
        Just wondering if this will solve our problem. Any help will be appreciated.
          ashraf
          The current plugin is capable of importing FBX files from Revit 2010.
          Soon it will be update to included support for FBX files from Revit 2011.
          Autodesk starting from Revit 2011 switched the material types used in FBX files exported from Revit, so instead of usual FBX materials it is using Autodesk internal description.
          This is special for Revit 2011. We are investigating a solution for this.
            Mra
            Is there a possibility that there can be an FBX plugin that exports out of SketchUp and replace the current default exporter?
            The default FBX exporter by Google is actually a couple of years out of date and very old. I think current version is FBX 2011.3, wheraes SketchUP uses FBX 6.1! Thanks
              ashraf
              Sure we can do that,
              We can add a new FBX exporter for SketchUp, this should be available soon.
                Mra
                Sounds good ashraf, thank you.
                  ashraf
                  Your request was fulfilled.
                  We have FBX 2011 and OBJ exporters ready for SketchUp 7, 7.1 and 8.
                  The plugins should work on Windows with the free and pro versions.
                  FBX exporter can be found at
                  http://www.simlab-soft.com/3d-plugins/FBX_Exporter_From_Sketchup-main.aspx
                  OBJ exporter can be found at
                  http://www.simlab-soft.com/3d-plugins/OBJ_Exporter_From_Sketchup-main.aspx
                  Cheers.
                  Ashraf
                    Updates - sweet.
                    I submitted some reports of some models that took an extremely long time to import - some never seemed to complete. Any changes in this release that would address that?
                      ashraf
                      The update you are looking for, should be available in January. We invested time in handling instances in the SketchUp files, which can be found extensively in Revit models, this update should be ready in January.
                      The last note was about two new Exporters for (FBX and OBJ)
                      Those exporters can serve a user who wants to use SketchUp models in other applications that do not have native SketchUp import capabilities
                        Oh - exporters - didn't notice that! 😳
                        I'll wait for the January release of the importer. πŸ˜„
                          Mra
                          Hi ashraf,
                          I have to thank you for the very quick response, truly appreciated. However I have to be honest. I have requested a trial licence for the FBX exporter but have noted a few pros and cons over the default FBX editor. I am importing straight into Maya.
                          Simlab Pros:
                          • Imports Sketchup's scenes and successfully converts into Maya Cameras
                          • Textures are saved into the FBX file
                          • Handles materials much better than the default except there was an instance where one material was duplicated about 100 times
                          Default FBX Pros:
                          • Groups objects as groups in Maya rather than using Maya locaters
                          • Seems to preserve geometry better
                          • Hidden geometry in Sketchup is completely discarded
                          Default and Simlab FBX Cons:
                          • FBX 2011 supports instances but neither plugins seem to preserve this on import
                          • No layers support
                          Currently I appreciate the dev work put into this but feel I cannot justify the price as I prefer the Geometry outputed by the default FBX converter even if it is an older version and has a few limitations. I think geometry preservation is a must, I found the same problem happened with the Sketchup to Maya converter too where all geo was triangulated. I post this in the best possible intentions. πŸ˜„
                            ashraf
                            Thanks for the great feedback, We will work on addressing those issues in the next update.
                            The next update will have a better handling o instances.
                              Yay!
                                Mra
                                I got an email today about an update, is there possibility to get a changelog? I'm still interested in the instances/components in FBX and the ability to not triangulate the mesh. Thanks.
                                • 4 / 4
