    [Tutorial > Modeling] Slant Ramp Tut
    27 Posts 7 Posters 13.1k Views 7 Watching
    • simon le bonS Offline
      simon le bon
      Hi guys,
      Dear Gaieus,
      It is always a pleasure to follow your tuts. (thank you to give a SU6 skp )
      As an exercise I had tried to find another solution:
      Here is my alternate way:(SU6 skp)
      Using:
      Fredo's Curviloft and Joint PushPull
      ++simon
        Thanks guys...
        Majid; maybe not accurate but back in 2007, there were not so many excellent plugins to skin a helix very easily...
        Simon: this is also the reason why it is still v. 6 - version 7 came out later (I think).
          simon le bon
          "by Gaieus on Thu Nov 15, 2007 5:55 pm"
          😮 I hadn't noticed the date 😕
          😆 simon
            by the way, Simon, why don't you upgrade to 8?
              simon le bon
              I have SU6 free and SU7 Pro on my big PC and SU8 free on my laptop...
              SU6 Is ok for everything I do; have never used dynamic component and I prefer the behavior of SU6 PushPull tool.
              I have bought for long Whaat's BoolTools, and actually nothing in SU8 free grab me more: I'm very sorry for that.
              😳 simon
                Okay but now as the shadow bug is gone in SU 8, image export is possible at a much higher resolution etc., maybe it would still be useful.
                Not to speak about some new generation plugins that may not work in earlier versions.
                Sure I still have both version 6 and 7 installed, too.
                  simon le bon
                  And Ho!
                  I was forgetting the ability to record our toolbars position in 8: what had always put a lot of people and also me very out of serenity with the previous versions.
                  😉 simon
                  • majidM Offline
                    majid
                    @gaieus said:
                    Thanks guys...
                    for sure your tut is veeeerrry handy and easy to follow 👍
                    @ simon : thanx , but the non-accuracy exists here again
                      simon le bon
                      Hi Majid,
                      Can you explain a bit more I'm not sure to understand completely what is the problem. 😲
                      ++simon
                      • majidM Offline
                        majid
                        dear Simon
                        I've attached a file that shows a real pont to point modeled rapm, and a tricky fast way ramp on(Gai trick) that clearly shows the difference.
                        helix-fast ramp.skp
                        real helix
                          simon le bon
                          Dear Majid,
                          Your "point to point modeling" is perfect to draw a real helix!
                          But in our specific case, as we need the curves to be tangent to the horizontal planes this pure helix doesn't work very well. Am I once again missing something?
                          Cheers,
                          Simon.
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thSlantRamp001.jpg
                          • charly2008C Offline
                            charly2008
                            Hi Simon,
                            The best result I achieved with the Arc tool and followme and keep. The arc was divided to 48 sectors. The end of the ramp is then still not tangential but the transition to the horizontal is optimized.
                            Charly
                            Ramp1.skp
                            • majidM Offline
                              majid
                              thanks charly.it's ok.
                              • mitcorbM Offline
                                mitcorb
                                "Slant Ramp Tut" that's bound to offend somebody somewhere, sometime. Perhaps on Tralfamadore?
                                  simon le bon
                                  Thank you Charly!
                                  ->applying your solution with FollowMeAndKeep .
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thSlantRamp002.jpg
                                  How have you made the path?
                                  Here I have applied my first solution:the 48s arc and two edges drawn on the ground, then the left edge selected and moved up!
                                  This seems to me to be good but! may be Majid will object something. There is something in the problem I don't understand. 😳
                                  Simon.
                                  • majidM Offline
                                    majid
                                    my only objection is : by moving up/dn and scaling an arc, we will not reach a helix, while mimicing it, BTW if we need a ramp that is tangented to horizon start, it is a fast way.
                                    (also I am aware of draw helix, and FaK plug) .apart from them and using native SU, there are only 2 ways in my sight, point to point , and tricky Gai way.
                                      Yeah, back then there was no Follow me and keep so one would either use helix.rb (which existed) and painstakingly connect the endpoints or do some trick to mimic something in a faster way.
                                      I ma glad though that I started to learn SU back when there were not so many, excellent plugins as nowadays. It forced me to find out workarounds and if nothing helped, there was always "had stitching". I think this approach would still be useful for many newbies before they rely themselves to the easiest methods with plugins.
                                      • majidM Offline
                                        majid
                                        yea Gai, agree with you... as somewhere Solo called plugins as "drugs"... relying on them is not always fair, specially for noobs. I've experienced that using plugs is even confusing for noobs in some cases (using "tab" ,"F3", "F4",...in different plugs is really confusing. hope we had saome "standards".)
                                        • majidM Offline
                                          majid
                                          I have prepared another "Smart" solution. as nowadays I have a trend to avoid using Plugins.
                                          hope you like it
                                          ramp.skp
