    Curves push pull
    6 Posts 4 Posters 594 Views 4 Watching
      ramdelgp
      Hello there, im new here and im wondering how i can push pull a curve of a roof. thanx
      • mitcorbM Offline
        mitcorb
        Well, you need a little more description of what you wish to do. Perhaps an image example.
        I can interpret your request in several ways.
        There are folks here who will readily help you.
          Seems you must use Joint PushPull by Fredo6
          (puspush multiple + pasted faces between them
            ramdelgp
            OK men thanx for requesting here is the image im trying to replay
            http://i302.photobucket.com/albums/nn108/ramdelgp/dirk900.jpg
            But i dont know how to do in the curve roof the push pull part to make the wood roof.
            THIS IS MY IMAGE
            http://i302.photobucket.com/albums/nn108/ramdelgp/a.jpg
            And this is my result, as you can see i dont know how to do the push pull to make the separation for the wood table.. ANY HELP PLEASE
            http://i302.photobucket.com/albums/nn108/ramdelgp/c.jpg
            • Rich O BrienR Online
              Here's a quick example to look at...
              Curved roof.skp
              • mitcorbM Offline
                mitcorb
                @ramdelgp:
                quoted "as you can see i dont know how to do the push pull to make the separation for the wood table.."
                What do you mean by "separation for the wood table"? The table I see is/could be a separate component modeled, then placed in the scene.
                You show a closeup of the ceiling plank joints. Are you wondering how to round off the edges of the planks? If so, I would suggest to take one plank profile, round off the two edges to be exposed, copy the entire contoured edge of roof and walls, do a select and follow me on the profile. Then make this a component and multicopy this by Move+Control xtimes along the ground level horizontal at the specified distances.
                I probably did not understand your intent.
