    Testing /Largeaddressaware property in SU 8
    extensions
    25 Posts 9 Posters 6.0k Views 9 Watching
    • jeff hammondJ
      @al hart said:
      Are you guys trying to hijakck this thread? ❓
      yeah.. doing my best to prevent you from finding the answer to your question..
      i'll stay away though.
      • Al HartA
        Al Hart
        AHA! I found the answer to one of my questions - How to enable Vista and Windows 7 to use more address space:
        Note: This will make sense for 32-bit processors with 3GB or 4GB RAM
        Windows Vista and Windows 7 no longer use the BOOT.INI file, so there is a different method for setting the "3GB" switch which enables to use 3GB of RAM for applications in 32-bit Windows (otherwise they use just 2GB - maximum).
        If you want to make accessible 3GB RAM for your CAD applications in Vista/Win7, use the BCDedit.exe tool (Boot Configuration Data Editor). The 3GB memory mode can be enabled with the command:
        bcdedit /set IncreaseUserVa 3072
        and disabled by the command:
        bcdedit /deletevalue IncreaseUserVa
        Run this command from a command window with Administrator priviledge - i.e. (in the Start menu) type CMD and press Ctrl+Shift+Enter, or select "Command Prompt" (Accessories), right-click on it and choose "Run as Administrator".
        Restart your PC after this change.
        I just made the setting. Now I need to reboot to see if it let me use more address space.
        Al Hart
        IRender nXt from Render Plus
        • StinkieS
          Stinkie
          Just kidding around, Al. 😉
            @al hart said:
            This implies to me that LAA is of some value on 32 but processors as well.
            If you enable the 3G switch - but you won't get the full advantage as running under 64bit does.
            • Al HartA
              Al Hart
              Yes, but I tried to throw a switch on my 32-bit machine to make it run in 64-bit mode, but I couldn't find the switch. 😄
              Al Hart
              • honoluludesktopH
                honoluludesktop
                Al, What about the warnings regarding use on 32 bit systems: "...........kernel to only 1 GB which may cause some drivers and/or services to fail. ...............). The remainder of 4 GB is allocated to the kernel and can result in failing driver and service configurations....... ". Don't see the value in failing services and drivers, or do I misunderstand?
                • Al HartA
                  Al Hart
                  I was explaining this whole thing to one of our clients:
                  In general, LAA is not going to make things any faster. The only time it comes into play is when SketchUp actually runs out of memory, which would cause a Bug Splat, or error message. In that case LAA might help you process the larger database.
                  There have been reports that SketchUp is simply faster for large models with LAA. But I would be surprised if this were true.
                  Is is very hard to test any of this.
                  Al Hart
                  • honoluludesktopH
                    honoluludesktop
                    OK got it. Thanks.
                      When I has 32bit windows and tried teh 3G switch I found the system to become a bit flakey.
                        jhauswirth
                        Its like putting a bigger gas tank in your car- it will make you go further, but tell me why this would make your car faster?
                          I like how everything can be explained in car analogies. 😄
                          • EvanE
                            Evan
                            Increasing the amount of application memory at the expense of system memory isn't likely to address memory problems in Windows XP 32 bit. It isn't the general application paged pool memory that runs out in most cases. Applications that have a Graphical User Interface must allocate GDI OBJECTS and USER OBJECTS (GDI=Graphics Device Interface). There are limits on the number of such objects that may be created by any single process and there is also an overall per session limit. Per session means a session desktop for a logged on user.
                            SketchUp makes heavy use of such objects. Other applications such as Windows Explorer and Internet Explorer are also very heavy users. When the maximum limit for User Object or GDI Objects is approached the system will begin to degrade. It doesn't usually crash but certain functions such as the clipboard and right-click context menus will stop working.
                            You can see here how many objects are being allocated by various processes:
                            http://ixian.ca/pics8/process_exp.gif
                            The only way to recover the ram used by these objects is to close the apps that are using the space available. Internet explorer is particularly bad in this respect. Firefox isn't any better. The best browser that I have tested is Opera. It uses far fewer objects when multiple tabs are open.
                            Existing allocated GDI and USER objects will not be deallocated until all instances of an application are closed. The situation becomes even worse if Terminal Services is running. Then the GDI ram is allocated from the unpaged system pool instead of the general application paged pool and the number of allowable objects drops dramatically. In fact, if Terminal Services is running then using the Large Address switch on XP will make the situation much worse.
                            Bottom line: There is no benefit to using the Large address switch on Windows XP 32 bit and that probably includes the 64 bit version although I am not certain of that.
                            References:
                            Process explorer is a part of the Sysinternals Suite available here:
                            http://technet.microsoft.com/en-us/sysinternals/bb842062
                            • 2 / 2
