    Scale of Tubes ... How to get Blue Selected
    12 Posts 7 Posters 734 Views 7 Watching
      LarryTremaine
      I work with a lot of cables in my sketchups. It seems like I spend half of total time that I'm in Sketchup on step #3.
      1. Select the cable
      2. Select SCALE
      3. Find and click the Blue-Opposite alternative
      4. Perform the scale
      Most of the "wasted" time is spent magnifying so I can see the darn choice, and then unmagnifying so I can see the stuff around the cable and do my scale.
      Is there any way to either make Blue-Opposite the default or hit someother key to auto-select it after I do step #2?
      Thanks much
        Jim
        Hi Larry,
        The Dynamic Components dialog in the Pro version allows a user to limit the scaling.
        A plugin could be made to set the scale mask, although one does not exist currently. In the meantime, you can try the following code snippets in the Ruby Console.
        To limit the scaling to the Blue Axis:
        Select a Group, and enter:
        Sketchup.active_model.selection[0].entities[0].parent.behavior.no_scale_mask=251
        Or select an Instance:
        Sketchup.active_model.selection[0].definition.behavior.no_scale_mask=251
        API: Behavior.no_scale_mask=
          Jim
          Just curious, since this is only availbe in the DC dialog, are people unaware of this ability?
          • Rich O BrienR Online
            But native SU Scale tool does this? I think i missed the point
              LarryTremaine
              Thanks. I am not using PRO.
              In case my question was not clear ...
              I know how to scale Blue-Opposite. The problem is that when scaling long tubes (e.g. wires), the circumference is so tiny compared to the length of the tube that I have to do massive zooming just to be able and have my mouse movement select Blue-Opposite. I spend a lot of time trying to get the mouse to highlite Blue-Opposite as opposed to all the other scale options that pop-up as the mouse moves over the teeny-tiny end of the long tube. Of course zooming always works, but I spend so much time zooming and then unzooming on that tiny circle at the end of any tube.
              Not sure how to do the RUBY code, though it looks like it could help. I'm a programmer, so curious to try it.
              THanks
                Jim
                Yeah.
                  Sorry Jim, now i understand. It ONLY scales the Blue, very useful. But how?
                    Jim
                    Yes, sorry. It is something which can be set via the Ruby API, so a plugin could be made. (I have a rudimentary one, but it's too ugly to release. See image.)
                      Presumably you could use the API methods http://code.google.com/apis/sketchup/docs/ourdoc/behavior.html#no_scale_mask? to temporarily set the possible scaling-ways of a definition, and then set them back afterwards... πŸ˜•
                      • X Offline
                        xrok1
                        have you tried stretching with fredoscale instead? theres only one control point to find that way.
                        • gillesG Offline
                          gilles
                          hi,
                          may be you could draw just axis lines, let say a wireframe and then convert to tube with:
                          http://forums.sketchucation.com/viewtopic.php?t=12354 line2 tube.
                          just idea.
                          • Jean LemireJ Offline
                            Jean Lemire
                            Hi folks.
                            You can also use a Zoom Window to get real fast close to the cable end.
                            You can also make a scene showing all cables and their surrounding. You do this only once.
                            Then, clicking on this scene's tab would quickly get you to the big picture.
                            Of course, you can also use the Move Tool to stretch a cable after grabbing its end.
                            Just ideas.
