    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
    • mitcorbM Offline
      mitcorb
      I think you want to FredoBend the component, then, if needed, FredoTaper. Maybe not.
      • hellnbakH Offline
        hellnbak
        No, I don't want to bend it, I just want to lean it to the right. I know it can be done using Box Tapering, I actually did it before on an earlier version of this object, I just can't seem to get it to do it again.
          Is it possible you want to use Plane Shearing instead? That worked for me.
          • hellnbakH Offline
            hellnbak
            You are the master! 😍 Why ain't I smart like you is? Thanks.
              I keep an extra brain cell in a jar just for emergencies like this. 😆
              • hellnbakH Offline
                hellnbak
                Can I borrow it?
                  Sure but it's kind of used up, now.
                  • fredo6F Offline
                    NEW RELEASE: FredoScale 2.1a- 12 Jan 11
                    This is mostly a new release in relation with the migration to LibFredo6 3.6 and to small SU8 issues.
                    There is no functional evolution, but it is advised to upgrade when you can in order to get a better support with up-to-date code.
                    You will need to migrate to LibFredo6 3.6 or higher
                    Please see main post for download
                    • boofredlayB Offline
                      boofredlay
                      I know I have kept up with every release however I am seeing something odd.
                      I installed the latest but still have the Free Scale toolbar but now have the Fredo Scale toolbar as well. Furthermore I don't see the ZLoader__FredoScale.rb file, just the ZLoader__FreeScale.rb file. Hmmm.
                      See images.
                      • jeff hammondJ Offline
                        Hmmm.
                        probably delete freescale_dir & zloader_freescale and install the fredoscale files instead..
                        ditch the libfredo_dir_34 as well
                        [edit]
                        probably also delete the older bezierspline and toolsOnsurface as well (BZ_dir, BZ_dir_12, & TOS_dir15)
                        • fredo6F Offline
                          Yes, you need to remove ZLoader__FreeScale.rb and FREESCALE_Dir_20 folder.
                          Also, do not forget to upgrade to LibFredo6 3.6.
                            boofredlay
                            Cheers guys.
                              MartinK
                              Another GREAT plugin. Thanks.
                              • mitcorbM Offline
                                mitcorb
                                @Fredo: If FredoScale is not designed to do this currently, what are the possibilities:
                                1. FredoTaper along a centroidal axis of a non-straight tubular mesh, such as a tree limb. It might have to impose a temporary lattice like FredoBend does, or use the suitably subdivided mesh of the tube as the control lattice.
                                2. FredoStretch a mesh along a predefined or preselected non straight path such as bezier curve.
                                The intention here would be to do these changes after formation of the meshes for workflow.
                                I am sure the implementation is not a trivial exercise, so this is just something to think about.
                                  Jim57
                                  I love FredoScale/ Box Taper. It seems the way Scale should have been in the first place. It pains me to say it seems to be off.
                                  Try this:
                                  -Turn on Style/ Edges/ Color By Axis
                                  -Make a 6" square
                                  -Push-Pull it to ~18" tall
                                  -FredoScale/ Box Taper/ From Center one of the long sides to ~15° angle (30° total), about 18" wide.
                                  Now check the edges that were just lengthened for alignment to axes. I find there is not enough misalignment to measure but enough to throw things off.
                                  Hope it's an easy fix, I use this plugin a lot.
                                  Best,
                                  Jim
                                  Running SU 8.0.3161 on Mac using 10.6.5
                                  • fredo6F Offline
                                    Jim,
                                    I am unclear on what is exactly the problem.
                                    I tried to taper the shape and did not find particular issue.
                                    Could you please post your model or at least illustrate what is going wrong with a picture
                                      Jim57
                                      Fredo—
                                      A thousand apologies. When I discovered it last night I duplicated the issue several times on my model. This morning I try it three times in new windows and no problem, the alignment is perfect on all of them. I go back & try again in last night's drawing and I still get the same issue. I assume it is a problem with that window— something in it must be corrupting new data.
                                      Best,
                                      Jim
                                      • mitcorbM Offline
                                        mitcorb
                                        Your cursor may be inferencing on background edges or vertices.
                                        • pbacotP Offline
                                          Hello all,
                                          I love FredoScale! Especially Stretch. It is amazing. However some times using stretch I have these problems:
                                          1. Components within the group stretch too far. Sometime this means smaller individual components will move out of their position maybe twice as far as the objects being stretched or larger components stretch way beyond the others. I think it may even happen with components whose other instances nearby did stretch correctly.
                                          2. The stretching is sometimes "jumpy", not updating with the mouse action and releasing the mouse it stretches a little beyond where I thought I was leaving it.
                                          Thanks for any help.
                                          Peter
                                          • pbacotP Offline
                                            No, I think not. There wasn't anything in the background in two instances recently. Sometimes the tool seems smooth and demonstrates typical feedback.
                                            Thank you, Peter
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 56
                                            • 57
                                            • 26 / 57
