    SketchUp 8 Bugs & Troubles!
    25 Posts 8 Posters 5.2k Views 8 Watching
      AlexMozg
      SketchUp v 8.0.481 (Maintenance 1)
      Nothing has been fixed.
      • I meant from those positions which were marked by me.
      Line stipple has been fixed.
      The 3d Polyline selection has been there since SU8.0 M0. Hasn't it?
      • I have just checked up it. It not so!
        ๐Ÿ˜ž
        Jim's ContructionLine tool wasn't working correctly under M0 - I could not set custom stipple. Now it works.
          AlexMozg
          My Contruction Line tool (stipple):
          'Continuous' [-----------] stipple=65535 doesn't work!
          'Dashed-1' ['- - - - - - - - -'] stipple=49344 doesn't work!
          'Dashed-2' ['- - - - - - - - - - - -'] stipple=13107 doesn't work!
          'Dashed-3' ['โ€“ โ€“ โ€“ โ€“ โ€“ โ€“ โ€“'] stipple=62 doesn't work!
          'Dashed-4' ['โ€“โ€“ โ€“โ€“ โ€“โ€“ โ€“โ€“ โ€“'] stipple=65280 doesn't work!
          'Dashed-5' ['โ€“โ€“โ€“ โ€“โ€“โ€“ โ€“โ€“โ€“ โ€“โ€“โ€“'] stipple=65520 doesn't work!
          'Dot-1' ['ยทยทยทยทยทยทยทยทยทยทยทยทยทยทยทยทยทยทยทยท'] stipple=34952 works!
          'Dot-2' ['ยทยท ยทยท ยทยท ยทยท ยทยท ยทยท'] stipple=65 doesn't work!
          'Dot-3' ['ยทยทยท ยทยทยท ยทยทยท ยทยทยท ยทยท'] stipple=273 doesn't work!
          'Dot-4' ['ยทยทยทยท ยทยทยทยท ยทยทยทยท ยทยทยทยท'] stipple=170 doesn't work!
          'DashDot-1' ['โ€“โ€“ ยท โ€“โ€“ ยท โ€“โ€“ ยท โ€“โ€“'] stipple=65299 doesn't work!
          'DashDot-2' ['โ€“ ยท โ€“ ยท โ€“ ยท โ€“ ยท โ€“ ยท'] stipple=543 doesn't work!
          'DoubleDot' ['โ€“โ€“ยทยทโ€“โ€“ยทยทโ€“โ€“ยทยทโ€“โ€“ยทยท'] stipple=65300 doesn't work!
          Jim's ContructionLine tool (stipple):
          ["_", ".", "-", "-.-"] - works!
          ๐Ÿ˜ข
            AlexMozg
            Now, using the contextual menu "nil" printed to the ruby console...
            Why?
            โ—
              Did the other stipples work before?
              I've only ever used the ones documented: "_", ".", "-", "-.-"
              what you mean? nil is printed to the console when you right click?
              I don't see that. Must be a plugin that outputs that.
                I'm confused by your 4.1
                I have no problems with selecting 3D polylines etc... can you expand on the problem?
                Also with these guide-line stipples... all stipples were broken in the original v8 now it's fixed for the standard ones... BUT where did these 'custom cline stipples' come from by number ? I've never seen them before - and therefore I've never used them... Who compiled the list - the codes must have changed with v8 - they do work in v7...
                Does Google have a new list of number codes ? ๐Ÿ˜•
                  AlexMozg
                  I can't select normally a 3D polyline with one or double mouse click or the intersecting frame, only if all 3D polyline is inside in frame, but contextual menu not probably to see - current selection is empty.
                  ...I've never seen them before - and therefore I've never used them...
                  cline.stipple always returns the number of stipple
                  cline.stipple= also takes the values as Integer
                  And it turned out that the stipple of cline can be varied over a very wide range.
                  Unfortunately now it's not ... ๐Ÿ˜ข ๐Ÿ˜ข ๐Ÿ˜ข
                    AlexMozg
                    Yes, it is undocumented stipples, but they worked to Sketchup 7 inclusively.
                    "nil" printed to the ruby console if there are assigned hot keys on the user tools allocated in the shortcut menu. Like so...
                      The 'numbers' for the stipples have probably changed that's all - we need a new list ?
                      I CAN select a polyline [curve] using the correct mouse-clicks and by a fence [right-left] so some part of it is inside that fence.
                      The ability to select it isn't affected by how much of it I can see in the main window [frame?]
                      When it's selected Entity Info correctly lists it as a 'Curve'.
                      What is your reference to a 'context-menu' - how is that related to a selected Curve ? Explode Curve - is there ??
                      ๐Ÿ˜•
                        AlexMozg
                        No, the numbers remained the same, it can be verified at the time of insertion of these clines (Ctrl + C, Ctrl + V)
                        I CAN select a polyline [curve] using the correct mouse-clicks and by a fence [right-left] so some part of it is inside that fence...
                        Not polyline [curve] and the 3D polyline!!! Look at the attached file.
                        3D polilines sample
                          At last I understand...
                          A 'Curve' drawn by the Freehand tool is called a '3d Polyline'.
                          A 'Curve' made by other means is a 'Curve'.
                          The Freehand-type '3d Polyline' does display the problems you listed.
                          If you select it and use the main Edit menu to Explode it and immediately 'Weld' it back into a 'Curve' the problems are gone.
                          Why do you use so many '3d Polylines' ?
                          I can't see any benefit in using them for many of the edges you have in your example SKP ?? ๐Ÿ˜•
                          OK it needs fixing BUT it is workaround-able - I have never had the problem as I rarely use these types of edges as there are easier things to do and to edit alternatives...
                          On checking I find that in v8 at least all of my Freehand generated curves are made as 'Curves' NEVER '3d Polylines'... UNLESS I hold down the 'Shift' key - then they do come out as 'thin' 3d Polylines ????? BUT why would I ever want to do that ๐Ÿ˜• ๐Ÿ˜•
                            AlexMozg
                            3D polylines are slightly extend the capabilities of the drawing.
                            I use them when necessary so that the edges and curves were with thickness (profiles > 2 in style of drawing), and 3D polylines are thin.
                            File with an example (in my post above) - is only an example of 3D Polylines and not an example of my work.
                            • T
                              TriciaS
                              Hi all,
                              Yes - we do have a known bug with selecting 3d polylines (created by holding Shift down when using the Freehand tool) which was introduced in 7.1 with the changes to speed up rendering/selection. It didn't make the cut for 8.0 or 8.0 M1 as it is not an easy fix and we haven't heard lots of reports about it (probably given that it is a pretty hidden feature).
                              I added this thread to the bug we have though and will designate it in a way that will give it more visibility.
                              Thanks for bringing it up,
                              Tricia
                              Google SketchUp
                              • Chris FullmerC
                                For the 3dpolylines, I found that you can select them by using the selection tool, making a window from upper left to lower right, crossing over just the end point of the polyline. So the entire line does not necessarily need to be in the window, just the end point, and you have to drag the selection window in the correct direction.
                                • Dan RathbunD
                                  Dan Rathbun
                                  That selection mode is butt-backwards! If I face away from the computer does it work correctly ? ๐Ÿ˜›
                                  I'm not here much anymore.
                                  • Chris FullmerC
                                    That depends on which hemisphere you are in. I think that is accurate for the northern hemisphere, but in the southern, you might also need to stand on your head. ๐Ÿ˜„
                                      I find scarifying a chicken to give good results.
                                      • Dan RathbunD
                                        Dan Rathbun
                                        I didn't know you were a sadist, Thom.
                                        http://dictionary.reference.com/browse/scarifying
                                        • bradB
                                          brad
                                          I can respond to the Construction Line Stipple issue. I have verified the custom line stipple patterns worked in SketchUp 7 and not in SketchUp 8. I'm not sure if the integer value for the Stipple patterns have changed or not. If and when I find out I will respond here. I have logged a bug in database about the stipple problem, thank you.
                                          Brad
                                          SketchUp QA
                                            Jim
                                            Thanks Brad! As far as I know, only the 4 stipple types have been documented. If other types are supported, it would be great to get those documented and to be able to use them.
