    1.5k Posts 477 Posters 4.2m Views 477 Watching
    • I
      Ike
      I am having similar problems installing this plugin.
      Has anybody been successful installing it and using on a Mac.
      If there is, can someone please send a screenshot of the hireacy
      of the plugins folder so, we can have a visual reference
      Your help is very much appreciated
      Ike
      • V
        Vicspa
        The plugin I use the most.
        Thanks so much
        • jeff hammondJ
          @ike said:
          Ike
          Ike,
          here's a mac installer for round corner which will work with su7 & 8
          http://web.me.com/jeffhammond/su/RoundCorner.zip
          • I
            Ike
            @ike said:
            Ike
            Ike,
            That was easy πŸ˜„
            Thanks Jeff, I am so grateful
            Ike
            • StinkieS
              Stinkie
              Does anyone know how the max amount of, er, bevel segments (? sorry - not a native speaker) can be upped? Currently the maximum amount is 30. I've been going through the code, but truth be told, I'm not much of a coder. πŸ˜„
              Help me out, and I'll send you gold, and curvy blondes. Really.
              • utilerU
                utiler
                Hey stinkie, i don't know code either but you got me interested......!
                Just Curious...
                  Look inside **RoundCorner_Commom.rb** find the line #150
                  MYDEFPARAM.declare_:DEFAULT_Flag_Numseg, 6, 'I:>0<****30****'
                  and change the 30 to something else like 72 [that's what I have mine set to]...
                  Then in **RoundCorner_Tool.rb** find line #346
                  @dlgall.field_numeric "num_seg", T6[:DLG_All_Numseg], 6, 1, ****30****
                  and change the 30 to match - like 72...
                  and line #1032 find
                  if numseglock || numseg <= 0 || numseg > ****30****
                  PM me about the delivery address πŸ˜‰
                  • StinkieS
                    Stinkie
                    Thanks, TIG! Much obliged. 😍
                    Andrew - sorry, the blondes and the gold are being shipped to TIG's as we speak. I'm sure you understand the supply's limited. I do still have a bag of musty lint.
                    • utilerU
                      utiler
                      Thats' OK mate. Blonde's are hard work anyway.... I'll let someone else put up with there shit.... πŸ˜‰
                      Just Curious...
                      • fredo6F
                        NEW RELEASE: RoundCorner 2.2a- 12 Jan 11
                        This is mostly a new release in relation with the migration to LibFredo6 3.6 and to small SU8 issues.
                        There is no functional evolution, but it is advised to upgrade when you can in order to get a better support with up-to-date code. You will also get the two-phase loading in this version.
                        You will need to migrate to LibFredo6 3.6 or higher
                        Please see main post for download
                        • P
                          Pokery
                          When will work Piсk Profile?
                          Thank you!
                          • fredo6F
                            Thank you!
                            Do you refer to this function:
                            http://forums.sketchucation.com/viewtopic.php?f=323&t=20485&hilit=plugin&start=45#p172163
                            If so, this is on the list, but I am not sure that it would be terribly helpful, because with 1 or 2 edges, FollowMe can do it, and at 3-edges corners, the intersection may not be something that exist with real designs. In any case, the profile would have to be symmetrical.
                              MartinK
                              Thank You for a very useful plugin.
                              • N
                                nalkhayat
                                Hello,
                                I wasted all day trying to install this, and when I finally did, it didn't work. Must be a reason...
                                Before I waste your time...does the plugin only work on PRO versions? if so, you can disregard this.
                                I have google sketchup 8 (not Pro), on Windows 7. I had to create the DEFPARAM_Dir folder myself due to admin rights on my laptop.
                                I got it installed, and I have the tool on the program currently, including the preferences and such but nothing happens when I click on the icons. So if I have the select tool, or the erase tool or the arc tool selected, and then select the round corner tool, it is as if I selected nothing. The 3 icons from the plugin are now just decorative. I do not get any prompts to continue.
                                Any ideas?
                                  It works on free.
                                  Can you post a screenshot of your plugins folder where you installed the files?
                                  If you open the Ruby Console, do you see any error then when you try to activate the tool?
                                  • GaieusG
                                    Hi Nalkhayat,
                                    Did you also installed the LibFredo library as instructed on the first page of the plugin topic?
                                    And yes, it works on the Free version of SU, too.
                                    • N
                                      nalkhayat
                                      @thomthom said:
                                      It works on free.
                                      Attached is the screenshot. I had installed both the Roundcorner and Fredolibrary plugin. Had no idea what the ruby console was but you're right! Here's the error I got:
                                      Error: #<Errno::EACCES: Permission denied - C:/Program Files/Google/Google SketchUp 8/Plugins/Fredo6Trace.txt>
                                      C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Core_36.rb:593:in initialize' C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Core_36.rb:593:in open'
                                      C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Core_36.rb:593:in trace6' C:/Program Files/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb:313:in init_palette'
                                      C:/Program Files/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb:128:in initialize' C:/Program Files/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb:42:in new'
                                      C:/Program Files/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb:42:in launch' C:/Program Files/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb:33:in action__mapping'
                                      C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Plugin.rb:117:in call' C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Plugin.rb:117:in launch_action'
                                      C:/Program Files/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/bootstrap_RoundCorner.rb:143:in launch_action' C:/Program Files/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/bootstrap_RoundCorner.rb:159:in startup'
                                      C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Plugin.rb:672:in call' C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Plugin.rb:672:in command_invoke'
                                      C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Plugin.rb:654:in build_config_commands' C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Traductor.rb:874:in call'
                                      C:/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_36/Lib6Traductor.rb:874:in `add_command'
                                      • N
                                        nalkhayat
                                        One more thing. I just noticed a second plugins folder…called sdk plugins. Is this relevant? Also, I’m very new to sketchup, and I normally would try to do this the old fashioned way and not bother with extras and posting the problems but I kinda need this, so thanks.
                                        • N
                                          natush
                                          Please, HELP!!!
                                          Installed this plugin on MAC OS 10.6.6 - it does not work. I copied all files into plugin folder, installed LibFredo6 (by the instruction provided at the link) - now when SketchUp starts up, it displays "Load Errors":
                                          Error Loading File __loader.rb
                                          uninitialized constant TraductorError Loading File bootstrap_RoundCorner.rb
                                          uninitialized constant RoundCorner::T6Error Loading File Lib6__obsolete.rb
                                          uninitialized constant Traductor::T6Error Loading File Lib6Config.rb
                                          uninitialized constant Traductor::T6Error Loading File Lib6EdgePicker.rb
                                          uninitialized constant Traductor::T6Error Loading File Lib6Input.rb
                                          uninitialized constant Traductor::T6Error Loading File Lib6Operation.rb
                                          uninitialized constant Traductor::T6Error Loading File Lib6Palette.rb
                                          uninitialized constant Traductor::T6Error Loading File Lib6Plugin.rb
                                          uninitialized constant Traductor::T6Error Loading File Lib6Protractor.rb
                                          uninitialized constant Traductor::T6Error Loading File Lib6Selmode.rb
                                          uninitialized constant Traductor::T6Error Loading File Lib6Startup.rb
                                          uninitialized constant Traductor::T6Error Loading File Lib6Tool.rb
                                          uninitialized constant Traductor::T6Error Loading File Lib6Web.rb
                                          (yes, the message looks truncated) and then starts up normally. Of course, there is no "Tools > Fredo6 Collection" menu item.
                                          SketchUp version 8.0.3161. BTW, I copied libraries into Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/plugins (not "Google SketchUp 7" as was suggested. Could it be caused by this?..
                                            natush πŸ˜’
                                            If you are wanting to use it in v8 then put it into the v8 ../Plugins/ folder [conversely for v7 use the v7 ../Plugins/ folder - the installation guide is based on v7 but it expects you to have enough brain cells to substitute the appropriate 'version' number when not using it in v7 πŸ˜• ].
                                            The 'error message' is trying to tell you that you don't have many of the files that are needed loading...
                                            The 'Traductor' referred to is what would load from the correct 'Lib' IF you had installed that properly.
                                            Go back to the download page [first page] and read it all.
                                            Immediately after the link to download the tool itself it tells you that you must also install 'LibFredo6' 3.6 or higher - there is a link to its thread go to its download page - and download it, unzip the downloaded zip file and put the one folder [LIBFREDO6_Dir_36] and the one associated script [LibFredo6.rb] which loads the Library Contents - into the appropriate ../Plugins/ folder [i.e. to suit the 'version' of Sketchup].
                                            Restart Sketchup and see if it works then... BUT Please note, that as also explained on the download page, Fredo's tools are often 'Extensions'; which means that this tool might need 'activating' [just the one time] before it thereafter appears as a menu item or makes its toolbar - Window > Preferences > Extensions > Roundcorner Tool and 'tick' + OK to close - now there should be its menu/toolbars available to use...
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 74
                                            • 75
                                            • 16 / 75
