    [Plugin] CleanUp
    974 Posts 217 Posters 788.7k Views 217 Watching
    • Chris FullmerC Offline
      I've found my tolerance flaw - it is my brain's intolerance for writing code til 4:00 in the morning. I am not having tolerance flaws, but I was having classify_point mis-use issues. I am getting closer to figuring it out.
        Ben Ritter
        Does this script erase co-linear lines or lines on top of each other?
          ? Edges on top of another edge? Is that pre SU7 models?
            Ben Ritter
            It's an imported .dwg file into an SU8 model.
              Jim
              Thom, could you explain what the option "ignore normals" means?
                "Normal" - refers to the direction of the face. You can have two co-planar faces next to each other, but one facing up, and one facing down. When "Ignore Normals" is enabled it means that coplanar faces with inverse normals will be merged.
                This is something I hope to be able to improve in V3 - better descriptions.
                  Jim
                  Thanks, makes sense.
                    Once you know it - but maybe not so intuitive when you don't... πŸ˜•
                      rv1974
                      May I humbly request a close-open functionality (with custom search radius defined by user)? Just similar to closeopens.rb
                      by Todd Burch.
                        by Todd Burch.
                        Funny you should mention that. I began on a small utility today:
                          rv1974
                          You are unhealthy unstoppable πŸ™‚ But don't make it a separate tool. Insert it in the cleanup. Those rubies pullulate like cockroaches πŸ™‚
                            I was planning on adding it to Edge Tools. One completely automatic, one where on can inspect, like solid inspector.
                            Could add the automatic version to CleanUp3.
                            • plot-parisP Offline
                              plot-paris
                              oh, will that be in the near future?
                                CleanUp 3 and Edge Tools 2 will be out next week. ( And the feature of closing small caps will be in Edge Tools. )
                                • Z Offline
                                  Zenhipster
                                  Tested the plug-in here on such a model. Does not work.
                                  Inside a lot of extra polygons.
                                  magicube
                                    There's nothing to clean up there. There's not a single line that is not part of the components (which are all perfectly solid so cannot be any stray geometry in them).
                                    If you want to get rid of the separating edges/faces, you need to explode the whole thing first and run another plugin:
                                    http://forums.sketchucation.com/viewtopic.php?f=180&t=12668&p=92295#p92295
                                    (Nice model, by the way!) πŸ˜‰
                                    • jason_marantoJ Offline
                                      jason_maranto
                                      Or you could just use the "outer shell" command from the solid tools in Sketchup 8.
                                      Best,
                                      Jason.
                                      • honoluludesktopH Offline
                                        honoluludesktop
                                        @zenhipster said:
                                        ............ Inside a lot of extra polygons.
                                        If you are trying to remove the polygons "out of view", this app will not do that.
                                          πŸ‘
                                            Well, had a closer look. Neither solution will work properly as the pieces are not aligned correctly (there are extremely small but gaps)
                                            • 11
                                            • 48
                                            • 49
                                            • 9 / 49
