    [Plugin] CleanUp
    974 Posts 217 Posters 1.1m Views 217 Watching
      @jim said:
      Thom, could you explain what the option "ignore normals" means?
      "Normal" - refers to the direction of the face. You can have two co-planar faces next to each other, but one facing up, and one facing down. When "Ignore Normals" is enabled it means that coplanar faces with inverse normals will be merged.
      This is something I hope to be able to improve in V3 - better descriptions.
        Jim
        Thanks, makes sense.
          Once you know it - but maybe not so intuitive when you don't... πŸ˜•
            rv1974
            May I humbly request a close-open functionality (with custom search radius defined by user)? Just similar to closeopens.rb
            by Todd Burch.
              by Todd Burch.
              Funny you should mention that. I began on a small utility today:
                rv1974
                You are unhealthy unstoppable πŸ™‚ But don't make it a separate tool. Insert it in the cleanup. Those rubies pullulate like cockroaches πŸ™‚
                  I was planning on adding it to Edge Tools. One completely automatic, one where on can inspect, like solid inspector.
                  Could add the automatic version to CleanUp3.
                  • plot-parisP Offline
                    plot-paris
                    oh, will that be in the near future?
                      CleanUp 3 and Edge Tools 2 will be out next week. ( And the feature of closing small caps will be in Edge Tools. )
                      • Z Offline
                        Zenhipster
                        Tested the plug-in here on such a model. Does not work.
                        Inside a lot of extra polygons.
                        magicube
                          There's nothing to clean up there. There's not a single line that is not part of the components (which are all perfectly solid so cannot be any stray geometry in them).
                          If you want to get rid of the separating edges/faces, you need to explode the whole thing first and run another plugin:
                          http://forums.sketchucation.com/viewtopic.php?f=180&t=12668&p=92295#p92295
                          (Nice model, by the way!) πŸ˜‰
                          • jason_marantoJ Offline
                            jason_maranto
                            Or you could just use the "outer shell" command from the solid tools in Sketchup 8.
                            Best,
                            Jason.
                            • honoluludesktopH Offline
                              honoluludesktop
                              @zenhipster said:
                              ............ Inside a lot of extra polygons.
                              If you are trying to remove the polygons "out of view", this app will not do that.
                                πŸ‘
                                  Well, had a closer look. Neither solution will work properly as the pieces are not aligned correctly (there are extremely small but gaps)
                                  • Arty2A Offline
                                    Arty2
                                    Not sure if it's the proper thread for this tip, but here goes.
                                    Wow, it looks promising. One suggestion, though: you could use big buttons instead of radio buttons and check-boxes. Such elements need more precision to click them (because they are small) and when using such plugin several times it can come more handy.
                                    This was a request about v3 in another thread, that is very easily solvable by just using some proper HTML and keeping the radio buttons / checkboxes too.
                                    Just make use of the <label> tag like this:
                                    <label for="idname">Descriptive text here; <input type="radio" name="whatever" id="idname" /></label>
                                    and that should keep everyone happy πŸ˜„
                                      That it uses already, and thatΓ¦s what the initial v3 will be using. πŸ˜„
                                      • Arty2A Offline
                                        Arty2
                                        That's great then, you should advertise it as "click the text and the checkbox is magically selected"
                                        Keep it up mate :]
                                          Keep it up mate :]
                                          I'll be doing a video presentation.
                                          Another issue with the UI is displaying extra information. At the moment I use tooltips for each element, but I want to provide a better interface for this as well. But now I just need to get this first version out, otherwise it'll never be done.
                                          (Btw, you're a webdesigner? Scripter/programmer? Doing any SketchUp plugins?)
                                          Cheers!
                                            Version 3
                                            • New UI
                                            • More cleaning
                                            Remember to update TT_Lib2
                                            • 48
                                            • 49
                                            • 8 / 49
