    Linear Fluorescent IES Light
    renderpluginsextensions
    9 Posts 3 Posters 4.1k Views 3 Watching
    • H Offline
      harnstein
      it's good to work with IES lights, we all know.
      But what about linear ies lights? I found some files, but how can i use them?
      Like e.g. for a stroke of light under the ceiling made of fluorescent T8 tubes.
      If i load an ies file for linear fluorescent into vray, all i get is still a spot.
      Even if i change the ies-light-component-cone into a linear box- which is not a surprise, i know..
      Any ideas?
      still sketchin'
      • halroachH Offline
        halroach
        I've also been facing this same problem. I've tried changing the ies light geometry but that didn't help in any way.
        Have you found any solutions?
        FlexTools - Super Quick Windows, Doors, Slats...
          Have you asked ASGVis support?
          • halroachH Offline
            halroach
            ׊ׁAnswers in the sketchucation forum are usually quicker and more to the point, But I posted the question there too now.
              I think this is a more specialised question that they would answer better. Might even be a bug - in which case they need to know about it.
              Note that the forum is not an official support channel, but use the email instead.
              • halroachH Offline
                halroach
                They answered:
                http://forum.asgvis.com/index.php?topic=9491.0
                @andybot said:
                No. IES lights currently are point lights like the spotlight and omni-light. I mentioned having an option for linear ies light source in the wishlist thread a little while ago. I don't know how involved it would be (or how high a priority) it is from the developer end.
                -Andy
                That's good to know! Thanks Thom!
                • H Offline
                  harnstein
                  just the ordinary one- modelling a tube with the right dimensions and adding an emissive material.
                  as far as there are no linear ies lights in sight, maybe we should build a library on our own. if i find the time i will share some. warm / cold light color, different watts, sizes etc.
                  is it possible to save a "vray-component" to the warehouse? i mean, does it save the information of the emissive vray material? (i never did before.. 😉 )
                  does anybody know how to interpret the "intensity" value in the emissive-layer-dialog?
                  if i look at the data of e.g. philips lights there is always light color/temperature, lumens/candela and watts- if i dont miss something.
                  how to compare that to "intensity"?
                  still sketchin'
                    If you use version 1.48.xx
                    • H Offline
                      harnstein
                      ok, thanks.
                      if you know how to interpret the "intensity" thing please let me know..
                      still sketchin'
