    [Plugin] fixSolid v1.7 - updated 20/10/2012
    46 Posts 24 Posters 63.5k Views 24 Watching
      Sorry - I made a typo. It's Sketchup - not SketchUp - the thing is case sensitive.
        Btw, here's some stats to how slow .typename is compared to .is_a? http://forums.sketchucation.com/viewtopic.php?f=180&t=19576&view=unread#p162235
        In case you where curious.
          GWD
          • V Offline
            vidy
            The plugin works only on SU 8, because the function i use the check if it's a solid is a new function in v8.
            thanks for your confirmation πŸ˜„
            still so much to learn..
              kobus
              respect ! where thomthoms inspector was heading I presume.
              you should be interested in the future. you will spend the rest of your life there
                @thomthom said:
                @pherim said:
                That's because solids had not been included in SU 7 and are only available since SU 8.
                Should be able to work anyway. There is not difference in the geometry, it's just that SU8 knows how to recognize solids.
                You could use the method I use with Solid Inspector - check that all edges have two faces connected. Then it'd work on older versions. Of course for SU8 and newer you want to use the built in version that's very quick.
                  Nice plugin. It could be very useful. I tried it on a model that someone sent to me the other day. It fixed a few things in one component but still left errors. There were a lot of errors in that component to begin with and it certainly would reduce the time required to manually fix it. Unfortunately the plugin doesn't always seem to recognize that a component is not solid. At least it doesn't recognize that the component in the attached SKP is not solid although you can easily see several problems that keep it from being considered solid.
                  Not Solid.skp
                    GWD
                    At this moment fixSolid only work on groups not on components. I'll make it work on components to.
                      Thank you.
                      • N Offline
                        nektares
                        this might become handy when importing external geometry from other apps, thanks a lot!
                        • AnssiA Offline
                          Anssi
                          Guy,
                          You saved my day today! Thanks a lot!
                          Anssi
                          • Z Offline
                            zapwizard
                            I haven't downloaded it yet, but I am very interested in using this plug-in to help heal solids for use in BSP based video game making.
                            • mariochaM Offline
                              mariocha
                              Tried it. V1.5 works pretty well.
                              This is indeed gone be very, very useful.
                              Many thanks πŸ˜„
                              %(#008000)[Mario C.
                              • N Offline
                                niks
                                thank you... very nice plugin
                                  rubiks
                                  😍 SO HAPPY, SO FRAKIN HAPPY. tried everything to fix <2 days> and i just couldn't do it. I find fixSolid. "right click - FIX - DONE" THANK YOU!!!!!!!!!!!!!
                                  • majidM Offline
                                    majid
                                    😍 πŸ‘ πŸ‘ πŸ‘ πŸ‘ worthy and timesaving, esp for me when impoert/export between wings3d and Sketchup in some cases!!!!
                                    i.e when I was modeling this chair part,... it was a big bother... I must use wings for its sud... and SU for boleans... it was really confusing , to me to model this, and find small gaps and fix them when import/export datas
                                    • F Offline
                                      fumaru
                                      OMG this is awsome.
                                      Great Plugin thanks man.
                                      Thanks to this, I dont need to rebuild my forms when it is just one small line that cause it to go out of place.
                                      I use this in conjunction with Solid Inspector http://forums.sketchucation.com/viewtopic.php?t=30504 , this is a great combo.
                                      • H Offline
                                        hygicell
                                        excellent plugin, many thanks
                                        though it would be nice to try and mention on the front page that this version doesn't work on components (yet), only on groups
                                        Frank
                                          Frank, don't hold your breath. It's going on two years since the OP said he'd make the plugin work on components and it hasn't happened. It probably won't.
                                            GWD
                                            This plugin try to fix non-manifold solids (groups and components) to manifold solids.
                                            fixSolid fix the following problems:
                                            • heal missing faces
                                            • remove single edges
                                            • remove separate faces
                                            • remove edges between coplanar faces
                                            • remove innerfaces
                                            • remove all edges with only 1 face connected (RISKY FIX)
                                            Install:
                                            The plugin is a SU Extensions. Go to the SketchUp Extensions and choose Install Extension... Choose the file fixSolid.rbz and the plugin will automatically be installed.
                                            on OS X (Mac): SketchUp -> Preferences -> Extensions
                                            on Windows: Window -> Preferences -> Extensions
                                            Usage:
                                            1. Select solid
                                            2. Right-Click Context-Menu. If the solid is broken the option 'FIX SOLID' is present. If the option isn't present there are no problems with he solid.
                                            3. Select 'Fix Solid'
                                            4. You can set two options:
                                            • Risky fix: if you choose a risky fix it's possible that a part of the solid wil be deleted. This action can be undone with the normal SU undo function. The risky fix try to fix all problems, the normal fix only fixes problems with no risk.
                                            • Fix coplanar faces: If you choose no, the edges between coplanar will not be removed.
                                            Remark:
                                            Please send me solids which can't be fixed at this moment so I can try to expand the numbers of solids which can be fixed.
                                            fixSolid.rbz
                                            • 2 / 3
