    [Plugin] fixSolid v1.7 - updated 20/10/2012
    46 Posts 24 Posters 66.2k Views 24 Watching
    • EscapeArtistE
      EscapeArtist
      Looks like a good plugin. Will give it a try as it progresses with TT's suggestions.
      • V
        vidy
        thanks Guy, for the plugin, but is it only for SU 8?? can not see it in the plugin menu? im using SU 7.1
        regards,
        still so much to learn..
        • P
          Pherim
          That's because solids had not been included in SU 7 and are only available since SU 8.
            Should be able to work anyway. There is not difference in the geometry, it's just that SU8 knows how to recognize solids.
            • G
              GWD
              The plugin works only on SU 8, because the function i use the check if it's a solid is a new function in v8.
              • G
                GWD
                @thomthom said:
                Nice plugin. πŸ‘
                Got a couple of notes:
                1. It's advisable to wrap your plugin into a module and use module variables instead of global variables - this ensures there will be no conflict with other plugins.
                2. Detecting edges between co-planar faces: You are using this: if faces[0].normal == faces[1].normal then
                  I used that for CleanUp, but I ran into issues where it's either erase edges between non-coplanar faces or leave some edges that should have been erased in some cases. As it turns out, the correct way - according to the Googler I spoke to - is to take all the vertices of the two faces you compare and check if they all lie on the same plane.
                3. e.typename == "Edge" - .typename is very slow because you do string comparisons. Instead, compare it's class: e.is_a?( SketchUp::Edge )
                ThomThom,
                1. How can i wrap my plugin in a module?
                2. OK -> v1.4
                3. I tried to switch .typename == "Edge" but then I get errors, i also can't find info about the .is_a? function?
                regards,
                Guy
                • dereiD
                  derei
                  3.can't find info about the .is_a? function?
                  http://ruby-doc.org/core/classes/Object.html#M000373 -first result after search on google πŸ’š
                  DESIGNER AND ARTIST DEREI.UK
                    1. e.typename == "Edge" - .typename is very slow because you do string comparisons. Instead, compare it's class: e.is_a?( SketchUp::Edge )
                    [/quote]
                    What kind of error and what did you switch to?
                    As for modules:
                    http://ruby-doc.org/docs/ProgrammingRuby/html/tut_modules.html
                    http://forums.sketchucation.com/viewtopic.php?f=180&t=12423#p89313
                    Many other useful links in this sticky at the Developers section:
                    http://forums.sketchucation.com/viewtopic.php?f=180&t=10142
                    • G
                      GWD
                      As for modules:
                      ThomThom,
                      The module works, but when I recplace the .typename with the .is_a? I get the following error:
                      Error: #<NameError: uninitialized constant FixSolids::SketchUp>
                      (eval):373
                      (eval):318:in `call'
                      (eval):318
                      regards,
                      Guy
                      [mod=:2660fdfj]%(#FF0040)[**NOTE:
                      A newer version [posted under the OP's new login] is available here...**]
                      http://sketchucation.com/forums/viewtopic.php?p=436001#p436001
                      TIG[/mod:2660fdfj]
                      v1.5 NOTE: newer versions available...
                        Sorry - I made a typo. It's Sketchup - not SketchUp - the thing is case sensitive.
                          Btw, here's some stats to how slow .typename is compared to .is_a? http://forums.sketchucation.com/viewtopic.php?f=180&t=19576&view=unread#p162235
                          In case you where curious.
                          • G
                            GWD
                            • V
                              vidy
                              thanks for your confirmation πŸ˜„
                              • K
                                kobus
                                respect ! where thomthoms inspector was heading I presume.
                                you should be interested in the future. you will spend the rest of your life there
                                  You could use the method I use with Solid Inspector - check that all edges have two faces connected. Then it'd work on older versions. Of course for SU8 and newer you want to use the built in version that's very quick.
                                    Nice plugin. It could be very useful. I tried it on a model that someone sent to me the other day. It fixed a few things in one component but still left errors. There were a lot of errors in that component to begin with and it certainly would reduce the time required to manually fix it. Unfortunately the plugin doesn't always seem to recognize that a component is not solid. At least it doesn't recognize that the component in the attached SKP is not solid although you can easily see several problems that keep it from being considered solid.
                                    Not Solid.skp
                                    • G
                                      GWD
                                      At this moment fixSolid only work on groups not on components. I'll make it work on components to.
                                        Thank you.
                                        • N
                                          nektares
                                          this might become handy when importing external geometry from other apps, thanks a lot!
                                          • AnssiA
                                            Anssi
                                            Guy,
                                            You saved my day today! Thanks a lot!
                                            Anssi
                                            • 1 / 3
