    JPEG EXPORT - options don't change a thing
    18 Posts 6 Posters 1.2k Views 6 Watching
    • cmeedC Offline
      cmeed
      I just had another go with compression all the way down. no file size difference and no difference in quality
      repeating this i when through to the window i attached and the slider had gone back to nine
      this makes me think it changed bacjk to a previous setting
      • jeff hammondJ Offline
        change the pixel dimensions to affect file size.. not resolution.
        i'm not sure what's up with the jpg compressor (i've just always had mine set to 10).. i'll check it out in a bit.
        • cmeedC Offline
          cmeed
          thank you.....
          • cmeedC Offline
            cmeed
            Compression doesen't do a thing?
              i think you're right.
              it makes no difference if i have it set to 1 or10.. same file size and the image looks identical.
              • cmeedC Offline
                cmeed
                So I'm not going mad.....
                what to do though??
                Is this a Mac thing? I'm Mac your Mac
                  Works fine here - Windows7 SU8
                  http://forums.sketchucation.com/download/file.php?id=60562
                  • cmeedC Offline
                    cmeed
                    thom thom that was just compression you where changing?
                      i just tried it using sketchup 7 as well.
                      same thing -- there's no difference at all with different compression settings.
                      might be worth filing a report to the google team.
                        Yup!
                          RickW
                          I've reported this to the Google folks. Hopefully, it will be a quick fix.
                          RickW
                          www.smustard.com
                            thanks Rick
                              chrisjk
                              On my Mac and surprisingly, the PNG export file is about a third the size of the JPEG - its usually the other way round when I export images from other apps.
                              • cmeedC Offline
                                cmeed
                                did anybody get any answers for this?
                                c
                                  PNG can be smaller than JPG. It all depends on the colourfulness of the image. With less, "pure" colours,png's are smaller but with more complex colour scenes/schemes (like photos), jpg's can be smaller.
                                  It all depends on what you export. If you export with image textures, I bet a jpg will be smaller. If you export in some monochrome, hidden line or even shaded (without textures), png might have the chance to be smaller.
