    3d Terrain from 2d spot heights
    23 Posts 9 Posters 14.1k Views 9 Watching
      I did it any way -see if this is anything like you want ...Levels.zip
      • K
        Kenny
        That's great TIG, thanks very much. The geometry looks fine. I've also investigated whether the original survey is available in 3D and it's not, therefore I'd be very grateful if you could do the same for the latest plan attached.
        There are a couple of issues. It comes in too small (1000 times), possibly because I'm using metres and you've done it in mm. Also it would be great if it could be overlaid on the original survey base as a separate component so I know where the terrain sits in relation to the site plan features. I'me very grateful that you've taken the time to do this and I realise this will take you more time, I've sent you a PM.
        Kenny
        12708_OGL-REV3.zip
        http://www.townscapesolutions.co.uk/
          Here's a zip containing the original DWG stripped back.
          The DWG levels only moved in 3d to their true-Z.
          A SKP with these both imported [aligned] and 'meshed'...KennyTerrain.zip
          • K
            Kenny
            TIG, thanks again, that's perfect! I've tried PMing you however the messsages are not appearing in my sent box. Let me know if you don't receive them soon.
              PM got and replied...
              • W
                wloveland
                I have a similar problem, I have an autocad file that has a series of spot heights with the heights in text next to them.
                I have run the autolisp program on them and now have them at their spot heights. But then when I export them into sketchup and click the contour button on sand box. It says that you must first select the contours to use.
                Any Ideas what I am doing wrong?
                • GaieusG
                  Do you select them first? Are they not components or groups (in which case, explode first)?
                  (Welcome to SCF by the way - Will, isn't it?)
                  πŸ˜„
                  • W
                    wloveland
                    Thank you!
                    yeah I have selected them and they aren't in a group or component.
                    • GaieusG
                      But are they not individual ("small") groups/components either?
                      How about sharing the file here? (How big is it?)
                      • W
                        wloveland
                        I currently have this in Autocad, but when I transfer it to sketchup to use contours it doesn't work.
                        I have also tried to used point cloud and it doesn't work either.
                        Anyone have any ideas.
                        Spot heights.dwg
                        • GaieusG
                          It my answer to you here as "version 2" - i.e. if you have guide points (which are not geometry so the sandbox tools cannot handle them), use this plugin to triangulate the points
                          ( Select all > Plugins menu > Triangulate points).
                          (I did not know your units to import so imported in feet as far as I remember but it took a couple of seconds to triangulate only so you can redo)
                          mesh.skp
                            JackHill
                            I've tried really hard to sort a similar problem by searching the forums for answers but still can't do it. I have Auto CAD 3D spot heigh data and need to convert it into a 3d landscape terrain. I can't find any plugins that work on my Mac with Sketchup Pro 2016. Any help would be greatly appreciated.
                              If the CAD file's points are located in 3d you simply make copy of the DWG file and delete everything that isn't a 3d point - or perhaps save them as an external DWG.
                              Then import that DWG into an empty SKP file.
                              You now have a 3d cloud of guide-points...
                              Use one of the available extensions to make the mesh from the preselected points, e.g.
                              https://sketchucation.com/pluginstore?pln=TIG_points_cloud_triangulation
                              https://sketchucation.com/pluginstore?pln=TopoShaper
                              note that needs LibFredo too:
                              https://sketchucation.com/pluginstore?pln=LibFredo6
                              • H
                                hkarakion
                                Hello everyone,
                                any one can help me please in reflecting my topography CAD drawing into sketchup showing the real shape of the landscape based on the point levels supplied from the surveyor.
                                Thanks in advance.
                                Regards,
                                  @hkarakion said:
                                  any one can help me please...
                                  We can probably help you. You'd need to give us more information. What kind of file did you get from the surveyor? What version of SketchUp are you really using? Your profile says you are using 2020 Free/Make but there is no such version. If we know the correct version we can help you sort out what tools you have available to get the job done.
