[Plugin][Code]SKMtools,Material/ImageTools
In what fun? User Sahi, one week ago has made plug-in JpgGif with similar functions!
http://forums.sketchucation.com/viewtopic.php?f=323&t=33054
What for to do a similar plug-in? Or in what of advantages of your plug-in? -
@bob james said:
Really neat effects, TIG, but I've loaded the SKM files into the plugins folder and I don't get any toolbar.
ONLY the SKMtools_loader.rb*** goes into Plugings!
ALL other files stay inside their sub-folders [SKMtools etc] inside Plugins...
You need to activate the toolbar from View > Toolbars too...***NOTE: in more recent version this is named "SKMtools.rb"
What for to do a similar plug-in? Or in what of advantages of your plug-in?I am well aware of Sahi's tool.
I haven't tried it, but I suspect that it'll be quite similar...
Now for my tool's advantages ?
The main one is it's written by me ??
It's 'donation-ware' - i.e. you probably won't pay anything for it!!
It's part of a greater set of new API class/methods to expand SKM/Material/Image tools and their use in scripts and web-dialogs...
It was work in progress when Sahi published and I won't waste the coding time even if it might perhaps tread on his toes...
Tig I get the same problem as Bob James.
I've extracted all to the plugins folder, but nothing to be seen anywhere.
Looked for it in View toolbars, windows preferences, doesn't seem to load. -
Looked for it in View toolbars, windows preferences, doesn't seem to load.Do you have menu in View ?
Sorry, TIG: Operator error - I was looking for "SKM...." in the View/Toolbars list not "ImageAnimator"
PEBCAC - Problem Exists Between the Computer and Chair [i.e. YOU
SO is it working now ?
Do you get the Menu entry too - see my recent post about this...
The Menu AND the Toolbar are both named 'ImageAnimator' -
I don't think its a PEBCAC for me, I've searched everywhere, not a sausage.
I've restarted, reextracted, copy and pasted instead of extract all, nothing nadda zilch
You should have only one new file in the../Plugins/folder -SKMtools_loader.rb***
Inside the Plugins folder you should have a new sub-folder calledSKMtools.
In that folder../Plugins/SKMtools/you should have the following files:In these sub-sub-folders you have...
andand an empty '
Temp' folder.
Make sure you don't have any of the files in the wrong places from an earlier mis-install - it will screw up the correctly placed ones! ...
There is anImageAnimatorsub-menu under the mainViewmenu AND also a new toolbar underView > Toolbars- which is also calledImageAnimator........
***NOTE: in more recent version it is namedSKMtools.rbNOT '_loader.rb' -
It's odd Tig, it's all as you say it should be, but still nothing showing up.
It's late for me now so I'll have another try with it tomorrow.Thanks
Hi!
I have a similar problem arose.I made it for myself decided thus
file SKMtools_loader.rb replaced path ="SKMtools" ΠΎΠ½
path = File.dirname(FILE) + "/SKMtools" -
@sahi said:
Hi!
path = File.dirname(FILE) + "/SKMtools"Thanks for the advice BUT
path="SKMtools"should work asload "SKMtools/xxx.rb"[whenpathand thefilenameare 'added together'] will start in any of the$LOAD_PATHlocations which will include../Plugins/whereSKMtools_loader.rbresides and thenSKMtoolsis that directory up and it looks for the 'file' - I use it all the time to load scripts from subfolders without problem ?
Why do you think it isn't working for just some users ??
It works fine for me...
@tig said:
@sahi said:
Hi!
path = File.dirname(FILE) + "/SKMtools"Thanks for the advice BUT...........
Your example will work - although I'd usepath=File.join(File.dirname(__FILE__),"SKMtools")BUT the other method will work anyway
I have it too did not work, until I made changes after that he earned.
I have a folder "Plugins" is a standard set of plug-ins, not something extra.
I've tried it again on a different computer and same result. Nothing.
Just to be sure, I downloaded the .zip, double click, select extract all, browse to Plugin folder, extract all. Should I be doing anything else, or perhaps there is another file from one of your other tools that I am missing.
Other thoughts would be,
I may have a conflicting plugin
or
I have sketchup installed in the default location, ie: in program files.
I just installed your other plugin, Manifold in exactly the same way and it works perfectly.
Sahi / Box
I think I have the cause...
If there's an obscure script [that I don't know of] that loads beforeSKMtools_loader.rband it has code outside of its methods that is permanently changing the current directory [ill-advisedly] then my method will fail when using 'Dir' [but not 'load']. Sahi's method [or something like it] will work as it uses an 'absolute' and not 'relative' path. To check what the current directory is after startup typeDir.pwdin the Ruby Console - it should return the../Plugins/folder whereSKMtools_loader.rbresides - if not then we know something is changing thepwd.There's now an updated
SKMtools_loader.rbfile - please replace the one in the../Plugins/folder with this one, and retry. I have included this file in an update of the zipped set in the first post too...
NOTE: more recent versions do NOT need/useSKMtools_loader.rb.
Only install the files from the RBZ set... -
http://forums.sketchucation.com/viewtopic.php?p=293677#p293677 Here is an updated version with the 'loader' script adjusted to avoid earlier loading scripts messing up the 'dir/load' paths...
Perfect Tig, thanks, works now.
Here's an update http://forums.sketchucation.com/viewtopic.php?p=293677#p293677
It includes new methods:-Material.save_texture_and_thumbnail(folder)
- saves Material's texture [if any] and its thumbnail [png] into a subfolder named after the material in 'folder' - returns that subfolder path or nil.
SKM.save_texture_and_thumbnail(path_skm, folder)
- saves SKM's texture [if any] and its thumbnail [png] to a subfolder named after the SKM in 'folder' - returns taht subfolder path or nil
SKM.extract(path_skm, 'folder')
- extracts all of the SKM's data into a 'hash': if the optional 'folder' is given the files from the SKM are extracted into a subfolder named after the SKM in 'folder'. All of the available SKM data is accessible from the 'hash', if 'folder' is given then the paths to the texture/thumbnail etc are accessible...
ImageAnimator
- new menu items 'Make_Unique' and 'Clone'.
See individual tools threads for more details...
Here's another update http://forums.sketchucation.com/viewtopic.php?p=293677#p293677
It contains a new tool 'gifxtractor' which lets you quickly extract PNG files for each frame in a given animated GIF file...
